Show us your handplanes
CRSINMICH
Southeastern Michigan
milkovich: I have a 41/2 (US Stanley version). I use it fairly frequently; usually for rougher work but not always. I used it yesterday for flattening and smoothing common lumber. As you said, it went through knots easily. I like its heft although my increasingly arthritic wrists are less than thrilled.
ararat
Ararat NC
The mouth is too narrow for a typical toothing plane blade. The current scraper blade just about fills it up. The geometry of the mouth and wedge doesn't work with the tapered toothing blade either.
One of the screws by the mouth is protruding just a bit. I'll try to tighten it down or give it the sandpaper treatment.
ararat
Ararat NC
There are two popular ones I know of, the Rob Cosman "AdjustStar" and the Reed adjuster with a much finer thread pitch. It's probably not necessary if you're used to the regular adjustment wheels but I wanted to try it out on a "low value" plane and it's a neat gizmo. I can see it being useful on a smoother but not on a typical jack/fore or jointer plane. I'm not sure if you follow GR Woodworking but he uses a Clifton 4 1/2 and it made me really want a heavy smoother (without the Clifton price tag obviously) and some kind brits on the Stanley FB group weighed their 4 1/2s and confirmed the earlier (thick cheek) 4 1/2s were indeed heavier than the US versions or later English versions but not quite as heavy as the 4 1/2H (which are over 5 lbs I think). Is heavy good? That's also a point of debate, but it does feel like you have a little better shot at plowing through knots or those pesky sudden grain reversals and an amateur like me is not doing enough woodworking to be super picky about my lumber or I'm using trash like branchwood or forks I milled myself.
I watched one of the videos in the link. He was using the 4 1/2 for everything. I like using the No 3, the 4 1/2, and for larger plane the 6 and 27. 27 is really light since it is wood body. One of my no 6 planes is from the 40's I think and it has a good bit thicker casting than my other ones. It's USA and not marked with an H 🤷‍♂️
crguy
SW Washington
The condition of those screw heads makes it look like definitely an amateur job. Maybe the maker just didn't allow enough mouth clearance? The toothing blades Stanley used in their 112s weren't thick tapered. One of those might work in that plane.
Old tool guy
Looks like all the screws probably need tightening, the one in front of the blade appears to have been scraping finish off something. And the edges of the slot are dinged.
ararat
Ararat NC
That's the only screw sticking up and I gave it 1/8 of a turn and it is below the surface now. Taking this picture I noticed some marks. "B" on each side of the handle. Probably the owner/maker. 20250123_184504.jpg
milkovich
Akron Ohio
The weight is definitely the appeal to me. I also put a very minute camber on it so it's also nice to have such a wide iron. If you have an early US version (type 15 or earlier) they're a little lighter and much higher quality than my english version.
ctuai
Des Moines, IA
Picked it up this morning. A Stanley no. 3 (type 14). Comes with the sweetheart blade. Sweeet. Ready to be cleaned up. Give it a bit of steel wool to get rid of the light rust; 220 grit the sides and bed; into the evaporust. Solvent for the paint; light steel wool (careful around the sticker); French polish totes. Wire wheel brass and steel. Light coat of oil.
It really is a lovely plane.
Stanley no. 3 Smooth Plane (type 14).
Screen Shot 2025-01-25 at 8.16.23 PM.pngScreen Shot 2025-01-25 at 8.13.16 PM.png
ararat
Ararat NC
Arrived today. Stanley #19 block plane. Patented 1886. Excelsior body style. Got it narrowed down to 1889-1898 for when it was made. I have been looking for an 18, which is basically the same except a little shorter. All the pieces are there I think and I don't see any cracks or broken parts.
ararat
Ararat NC
The scraper is cleaned up and I lightly sanded the places where the previous owner rough sanded it and then gave it some boiled linseed oil. It works good, the blade is sharpened correctly and is not too dull. I'll sharpen it sometime.
milkovich
Akron Ohio
It‘s okay to
let a one hundred year old plane look its age. Sharpen/hone the iron, lubricate where necessary, and start using it.
that's generally my approach. Sadly, the planes that folks sell have to get slicked up unless it's a really high end plane. Ebay buyers typically don't appreciate the brown/black oxides. Luckily, a warm patina equals pretty nice savings when you're looking for something specific but common.
Jim C.
I can’t argue with you. I think you’re probably right about that.
JimC.
What is the very square bodied plane in the left front corner?
That’s a Stanley #9 block plane.
He's being very ¿coy, demure, evasive? about that . Correctly it's a Cabiner Maker's block plane, and some consider it a Grail of plane collecting. I heard of one guy who sold one for enough to buy his wife a decent car, 30ish years ago. Very rare, much more than a #1.
Jim C.
crguy,
I don’t buy refinished planes and I never refinish them. My users are all in top condition and are typically outfitted with their original parts to include period correct cutting irons. A relatively high percentage of the planes in my collection are still in their original Stanley boxes. As a result, the planes were protected for decades and in several instances some appear to have never been used. If you’d like to see some of these planes, click on the Hand Plane thread link below. 👍
Jim C.
crguy
SW Washington
crguy,
Jim C.
Sounds good. The pictures aren't clear enough to tell, and Beerhippie said "you ruined the collector value". I wanted to clear that up. You have some very nice planes.
Jim C.
Thanks. Sorry about the photos. Maybe I’ll try taking a couple from a closer distance. Following up on the boxes. With exception of a very few planes, those I’ve found in their original boxes have typically been in better than just good condition. They’ve avoided paint splatters, dust/dirt, shop related gunk, and usually retain their accessories and small parts. Most of them appear to have been used sparingly. Whenever I see an original box, I get excited, and more often than not, find a plane inside that delivers on my high expectations. Of the twenty eight block planes depicted in the photos I posted above, I think more than half of them still have their original boxes.
Jim C.
Jim C.
Did you collect those over time or hit a gold mine sale that had a bunch of them for sale?
Really cool to have the original boxes.
Thanks. No gold mine. I’ve been collecting planes since I was in my mid to late twenties. I’m in my early sixties now now. If you collect long enough you’re bound to find a few really nice ones along the way.
Jim C.
milkovich
Akron Ohio
Jim C.
Has anyone done a video tour of your collection? There is a youtube channel (Batcave Creations) that has done some really great tours but you have to have one of the most thorough stanley collections on the planet. I hope it ends up in a museum at some point, because it'd be a shame to have any of it fall into the clutches of hamfisted hillbillies like me.
milkovich
Akron Ohio
Speaking of hillbilly hamfist, look at this monstrosity! (I put the Woodyah "tote turner" on my 5 1/2). For us dirtballs who can't dig up a genuine shooting plane, this is a pretty good alternative. If I had a beef, it's that unlike a "hot dog" you aren't putting much force toward the work, so I'll probably glue a strip of wood on the outside to make a "chute" for the plane to slide in. Comfort wise, it's really great.IMG_7492.jpg
crguy
SW Washington
That's the same idea as a scarce Hunter patent tilting handle adapter that was put on a few #10 planes years ago.7420259A-0BF4-4715-B8AF-68CFF67E4B36_4_5005_c.jpeg
ararat
Ararat NC
Interesting. I might need to order one. I have an extra 5 1/2 that I was going to sell, but now I may just upgrade it.
ararat
Ararat NC
It's not a #19 it's a #18. Here it is all cleaned up hanging out with my Excelsior style #15. I left the remnants of nickel plating on the cap and knob. Nickel on brass seems weird. 20250131_154415.jpg20250131_154421.jpg
Holy hell, how am I just now hearing of these people?
I see so many items I need to purchase, aside from the Tote Turner, as I have a LV shooting plane. 67 parts, 10-28 screws, etc.
Thanks
ararat
Ararat NC
Thanks
The 140 fence. Almost every 140 I see is missing the fence.
crguy
SW Washington
Thanks
I know the guy that is behind Woodyah from one of the Facebook groups, and he's a great guy.
Jim C.
Has anyone done a video tour of your collection? There is a youtube channel (Batcave Creations) that has done some really great tours but you have to have one of the most thorough stanley collections on the planet. I hope it ends up in a museum at some point, because it'd be ina shame to have any of it fall into the clutches of hamfisted hillbillies like me.
No, I don’t have a video of my collection. I really don’t do social media, YouTube, etc. Like I said earlier, the best way to see several of the planes in my collection would be to click on the Hand Plane Thread link below.
Jim C.
milkovich
Akron Ohio
Took a risk on the ugliest Record 073 on eBay and it's cleaning up nice. I've wanted one forever, but now that I've used it, it feels comically oversized and at least 2 pounds heavier than it needs to be. It is pretty and it takes micron thick shavings with the grain but cross grain, I'm not sure it's much better than a wooden skew rabbet plane you can find for $10. I'll keep messing with it but I'm considering this part of my weight lifting protocol for 2025.
