The title really painted a different picture than what I was expecting when I made the click in here.
https://www.harborfreight.com/spring-loaded-center-punch-621.html
Otherwise, I'll bust the nut driver assortment out.
Center punches and nut drivers aren't screw starters...
What have you got? I have a few different designs, but all function fine.
I place the screw on the tip of the screwdriver or bit in impact driver, hold it there with my left forefinger, and drive it in.
.......possibly "thinking outside the box" or just plain improvising?
I'm going to try that one........possibly "thinking outside the box" or just plain improvising?
As the picture shows an individual does a lot of work on electrical equipment did not want to use a magnetic screwdriver around components where it might cause damage. He solved the problem of keeping a screw on a non-magnetized screwdriver by sliding a paper clip over the screwdriver shaft. He secures the screw head between the screwdriver tip and the bent end of the paper clip. This technique is particularly useful in tight places.
