What you're describing *is* the outer case of really old capacitors (especially electrolytics), so it's good you didn't try to open it up. Capacitors that old are almost guaranteed to be bad, so it would be worth replacing if you can find one. Note that caps usually have a pretty broad tolerance range (often -20% to +80% of stated value), so you can often get away with one that is close to the stated uF value, provided that the voltage rating is at least the same as the one being replaced.Thanks for the tip on the values. I looked all over for those. My capacitor is inside what looks like the cardboard inside a toilet paper roll. Same size too. I didn't have the guts to pull out that can of worms to check inside because I thought it might disintegrate in my hands or would not go back together again.
