Show us your welding projects
NakeDiesel
oklahoma
Here's a little project I started working on over the weekend and today. I decided I need a lumber/metal cart. I have a bunch of lumber laying around all over my shop. It's laying in the floor, leaning against walls, also have two piles of metal trim I've bought for my house when I begin skinning it in steel ag panels, pipe for building corrals on my farm, dom tubing left over from building roll cages in mine and my daughters race trucks, etc...
Looked at purchasing one, this one was about 800 bucks and rated for 3600lbs I think if I remember right, it's 36" wide by 60" long:
So I took that idea, then modified it in my head because I want to also store some plywood I have and some plastic coated mdf I've used to build stuff out of and also used it to build flat forms for carbon fiber bed sides on my race truck. so I widened it 44" and will add an upright on that side to hold the plywood.
Ordered a set of casters rated at 5k lbs between the 4 of them.
Ignore my horrible welds, it's been quite a while since I've had the welder out and done anything with it.
Here are progress pics so far:
Still have one more tier to build and tie the 3 supports together at the top, and the plywood outside support.
GeoBruin
Work in progress. I recently picked up a Burke Millrite and needed a way to move it into the corner of my shop (where the bridge crane won't reach) and ultimately level it.
I've seen a lot of designs with 4 big casters on goosnecks on the 4 corners but I didn't have the material on hand and the casters would have been very expensive, so I went with a "tank turn" design. I had all the steel in the scrap/treasure pile and a bunch of the casters I pillaged the wheels from. The 4 corner wheels will be smaller diameter so they sit off the ground when rolling straight and level but can help get up over cracks and bumps. Still need to add the levelling feet (and paint).
Edit: Added the final pics with the levelling feet and paint.
steel 35
Between the PNW and the Emerald Triangle
My project; started as a commitment a few years ago,
What Welder should I get? ; So We went shopping.
210 MVP it was, told him If he didn't like it I would buy it if he wanted to get rid of it.
Still Has the same tip !
Waiting For a Spool Runner 115 Plug & It's 220 plug won't fit Mine :poop:
I am seriously planning On downsizing these two Dina-sours
for the little guy with more power and n0 time.
WoodsTruck
I've been really happy with my Hobart 210 MVP. I've had to change out a couple tips. I ended up buying a 50' extension cord so I can run 220v to the curb if I need to do something I can't get in the garage.
ObnoxiousFumes
Southwest Sask
Thanks for this, I’ve been trying to think of a better way to store my small tubing drops and such.
GeoBruin
Love my Millrite. If your's doesn't have a dro and you plan on putting one on, let me know.. been there done that. There's not a flat surface on those things.
I'm coming from a benchtop mill with a DRO so I definitely feel "dependant". Would love to hear your input on the process.
First order of business is to just to go through and clean everything up, and then there's the whole matter of a VFD since it's wired for 3 phase.
ObnoxiousFumes
Southwest Sask
Ok I’ll play. Finished this up yesterday. Still learning to weld 😝It’s only for moving trailers around the yard/pasture so not super critical, won’t be using it for heavy/loaded trailers. And yes the pin for the top link should be further back for the right geometry but the holes in that upright tube were already there so I thought I’d use them rather than welding and drilling more flatbar. The ball on top is for moving gooseneck trailers.
sqznby
Coastal NC
Cutting and polishing fun out of a used welded and cut piece of 3/8" 316 pre-polished stainless.
It's some kind of steering mount for a boat. That's all I know about it, I'm not a boat guy.
Sorry if the pics aren't clear, didn't have my glasses on.
solo machinist
North West, Ohio
Thanks.
Of course, while I was doing the job, I was focused on the challenge and getting it done. Only after the fact did it occur to me that the process might be interesting to others. The attached photo shows how, using some door-skin strips and hot glue, I was able to transfer a mirror image of the mating surfaces to my shop, where I then used 5-minute epoxy, hot glue and plywood to create a fixture upon which to build these parts.
My 50-ton hydraulic press, that I adapted for bending, is also shown.
Wow, 50 ton! what size cylinder are you using to get that tonnage?
I have dies, just need to build a press. 50 ton would be great!
sanddan
Oregon
Not exactly a welding project, but related.
I projected an image onto the side of an old, rusted fuel tank, traced it with a Sharpie, and then cut it out with the plasma torch. It turned out so well, I've postponed my scrap metal run, perhaps indefinitely!
What did you use to do the projection?
BD55
Northern Utah
TIG welded up some lumber racks to get wood off the floor and out of the way. I think I had an ok amount of filler? Still learning lots every time! Just need to get them installed. Using Spax lags into the studs and seems to be plenty strong. I can hang off the end of one of the racks no problem (250 lbs 😬) IMG_8852.jpeg
Boosted1
Georgetown, KY
Mounted up lumber racks. I ended up chickening out just using the French cleats I put on all the walls, so the brackets are Spax lagged into the studs. I didn’t feel comfortable with the idea of several hundred pounds of wood falling on kids, me, or equipment.
Very nicely done. looks like you could add another row of brackets between the bottom and top row you have.
BD55
Northern Utah
Thanks! I may do that in the future or just add a set of shelving for other stuff; or move the bottom racks up a foot and add shelving below.
solo machinist
North West, Ohio
Very nice! The tig looks good. I like the french cleat. What degree did you cut the angle at? 45?
