Show us your welding projects
Robert Haas
I saw another member build a welding cart that held his MIG and his plasma cutter, thought to myself what a fantastic build it was so decided to copy the living **** out of it.
So with no shame what so ever here is my version
water separator/purifier caged for protection
Side table designed to carry a load
place for the Spool Gun to sit
The shelf is mandatory for me, I always need to toss my helmet and clamps onto something, not to mention it serves as a small fab area if needed so it will support quite a bit (note the 2" x 2" diagonal brace)
nine4gmc
Dallas
Damn Robert, first one was fine, now I've seen two and I'm looking for scrap metal to build me one :lol_hitti :thumbup:
alpinewhite
Orange County, California, USA
At home next to its big brother
What is that red box doing in this sea of blue equipment? :lol_hitti
F-117HWK
Virginia
First one was toomanytoys, but I switched internet providers, lost my email addy and forgot my password. My current one is toomanytoyzz, and has been active since 2004. I wish I could get the first username password sent, but the mods will not budge. I had a REALLY low member number in 2001.
Ah man that *****. I dont really post much as I am still gathering as much info as my brain can hold for a build down the road.
metalhead212121
DesertSparky57- That tubing bender looks AWSOME! Do you have any pics of it bending pipes? I'd love to see it in action! I don't know why but I have a goal of one day bending steel pipes in my garage. Why do I want to do it? I have no clue... One guess I have is because I watched to much American Chopper over the years....
"If you build it... they will come... If you want somebody to build it for you... Press one." Anybody remember what TV sitcom that was from? It was only on ONE episode of this particular sitcom.
DesertSparky57
Las Vegas
Metalhead212121, so far I have only bent one small piece on it. I have tube dies, 1.75x5.5 and 1.5x4.5, they are amazingly machined and should be for what they cost, but I only had a small piece of 1 1/4" pipe, I couldn't resist and popped it in and put a small kick on it. Even with no air just using the painfully slow manual handle the bender moved like there was nothing in it.
I've got a short vacation but after that I'll be picking up a compressor to run the air/hydraulic jack. I'd be happy to put a video up, it would be of my first test bends on 1.75x.120 seamless :) I will admit, I've bent lots for my day job, but never have I seen a bender that will do 210*!! Thank you for the compliment, my fab skills are painstakingly slooooowwwww, but so far have seemed to be worth the time I put in.
Again, thanks for the compliment :beer:
2manytoyz
Central FL
What kind of paint are you guys using on your welded shop equipment? Looks like enamel. If so, are you spraying it?
I've tried spray bombs, and brushing on enamel paint. Not getting the nice results that some of you are...
PCO6
Newmarket, Ontario
This hydraulic lift table came with a chrome handle for maneuvering it. The lift release was hand operated and attached to the handle. The handle was in the way for most of the things I needed the table for so I removed it. I welded up new lift and release mechanisms that are now foot operated and out of the way. It works a lot better now. :D
C.I.TR3
I have been lurking on this site and on this thread in particular for quite a while and can finally post my very first welding project. In addition to wanting to learn to work with metal via welding I am wanting to learn to forge steel. So I figured what better way to start than to build my own forge. I have finished the shell and am waiting on the liner material and a few parts for the burner. Really had a great time putting it together and can't wait to build more projects. Its amazing what a lot of grinding and a coat of black paint can do to cover up all my beginner mistakes.
N
neonnblack
Reno, NV
What could i possibly be welding up?
The jig is for 45* cuts. I bought a 7 1/4 diablo steel demon blade for the worm drive, much easier and quicker then setting up the 4x6 band saw and WAAAAAAY easier to do 45's.
Sheet is 18ga 4x10. Tube is 1 inch .060
Dimension is around 20x31x13. frame is not complete yet.
metal tech
I had bought a set of ****** 2462 headers and wasn't really happy with them. I got some new flanges with port shapes that match the heads and were thicker, along with new collectors.
Bobhdus
Missouri
Making some decorative stuff for some customers. Used some old copper pipe, annealed cut and flattened, and tig welding it to stainless fork with silver braze. Used propane torch to heat tines for bending. Polished up real nice!
Dirtybird103
Here are a couple things I built. First a baby gate and then a removable table for my horizontal/vertical metal bandsaw.
Here is the bandsaw table. It will have a metal top I just haven't made it to metalmart to get some plate.
Almost forgot this. Modified a friends gaming setup so it's more stable.
kyrbz
midwest US
I notice in a lot of the "in action" welding pics of newcomers to the MIG welding world that they are quite far away from the work and only using one hand. I always use two hands (if possible). . .one on the trigger and the other lightly supporting the nozzle in the gooseneck area. This allows more precise control of the gun for a consistent weld bead.
I also shove my helmet as close to the work as possible and still be able to focus my eyes so I can see exactly where the joint is and what the puddle is doing. We have to wear safety glasses at all times on the shop floor, and I've found that a good pair of clear/semi-mirrored safety glasses worn under the helmet will allow me to turn the shade down on my adjustable helmet and not get flash burn.
Keep up the welding! It is a great skill to have.
I feel handicapped if I have to do a weld where I can't support the torch with my second hand. Makes for a much cleaner and consistent weld bead.
exophyusical
Probably the coolest project I ever worked on was rebuilding a "Comander" that had tracks on it. If your not from northern Alberta you probably don't know what a commander is, picture an industrial grade monster truck that moves drilling rigs. Heres a few pictures of comanders, like I said the one I helped rebuild was on tracks and not tires, I used to have a picture of my welding truck parked under the thing.
http://www.google.ca/imgres?imgurl=...U0UoDKCYGCiwLr9oHgAg&ved=0CE0Q9QEwBA&dur=5099
http://www.google.ca/imgres?imgurl=...U0UoDKCYGCiwLr9oHgAg&ved=0CFAQ9QEwBQ&dur=1733
http://www.google.ca/imgres?imgurl=...U0UoDKCYGCiwLr9oHgAg&ved=0CFYQ9QEwBw&dur=1000
toomanytoyzz
Malvern, PA
They are some serious vehicles:shocking:!! Imagine what a set (obviously more than 4 would be a set) of tires would cost.
I'd like to see the pic of your welding rig under it for scale.
exophyusical
The company that I worked on the Commander for also had a bed truck that wasn't quite the size of a Commander but it was the biggest bed truck I have ever seen, they called it "Gravedigger". I watched them rotate tires on it one time, they had to use a good sized bobcat and the tires were actualy taller than the bobcat. Another really cool thing I worked on was a Nabors well servicing rig that could be broken down and moved by helicopter into remote wells in pieces.
I spent my second year building regular Well servicing rigs, It should have been a sweet job but it was very frustrating. I never saw a print or drawing the whole time, and even the riggers that work on them will tell you that there are not two identical service rigs in all of Alberta. Nevertheless they are impressive machines and I do take pride when I see one that I worked on in action.
http://www.google.ca/imgres?imgurl=...c1UvqKIsm9iwKLu4GgCQ&ved=0CG4Q9QEwDQ&dur=1186
http://www.google.ca/imgres?imgurl=...c1UvqKIsm9iwKLu4GgCQ&ved=0CFsQ9QEwBw&dur=1309
SatisTraction
Put a few final touches on the bender/notcher cart. I am happy with how it turned out. Still have a few more small things like the air line, a small chip tray under the hole saw area, a holster for the drill when it's not in use and maybe even a small magnetic mount tray for a tape measure and sharpie or soapstone for when I'm in the driveway bending and notching.
The return springs work excellent. Picked up from McMaster.
The upright for the notcher is bolted on, if a wacky piece of tube hits it I can make it go away for a bend if needed.
:rocker: Rock On GJ. One step closer...
I have the same bender and notcher. do you have plans for that stand or did you fab it on the fly? I would like to do that. I have my bender on a horizontal stand right now.
DesertSparky57
Las Vegas
SatisTraction, I had plans for the stand but they were quite vague. The only aspect of it that I sketched out was the geometry of the ram vs. the bender arm, it is a fairly conservative angle I ended up at and in hindsight I sort of wish I would have set up a more aggressive push angle for more overall degrees of forming die rotation per full stroke.
I have yet to really use it, life outside the garage is constantly stealing my shop time from me :dunno:
My favorite part of the whole stand is that I set it up so it can be moved but it is very stable once you set it down. You use the flat handle on the front side to lift and the whole thing rocks back on to the wheels. The balance point is set so that the plates for the casters are parallel to the floor when you stand it up. It looks bulky but it is actually very easy to roll it around. It sits on four rubber feet once you lay the front back down. It's just one of those things that came together real nice and was really quite fun to build. Here's a shot of the bottom.
zmotorsports
Northern Utah
Been working on my buggy for about 2.5 years! I hope to have it finished early next year.
Started with this.
Most recent.
Absolutely awesome looking buggy.:thumbup: However, you can't just throw up before and after pictures on something like that. You have to include ALL of the during pictures along with the closeups and descriptions. I am just sayin.
Mike.
vogelj
Indianapolis Indiana
Mike.
I hear ya! If you have some free time I have a build on pirate.
http://www.pirate4x4.com/forum/jeep-********-tech/1059102-project-cant-make-up-my-mind.html
vogelj
Sweet looking rig! I wish I would have cut more of my body out like you did. Now I have floors in the front and nothing in the back and its hard to tie them together and make them look nice.
s_blaylock
Montgomery, TX
careful what you wish for. I cut all the floors out and wish i had kept most of the factory floor. Because I had to have something, I had to build a floor from scratch. Oh and thanks! I really like yours too! Looks like we have similar tubework in the rear
Zebedeewesty
Wales, UK
Finally got my trailer finished. Just need to screw on some buttons for the shock cord on the tarp. Cost £150 (about $300) in total.
64Trvlr
Northern AZ
Here are some pics of the rear bumper I built for my camper. I also junked the cheap coupler on the tongue and battery spot. I put different battery boxes and a Bulldog couple on.
  • start of camper bumper 8:13.jpg
  • camper bumper construction shot 8:13.jpg
  • camper rear bumper 9:13.jpg
  • camper bumper dr side 9:13.jpg
  • camper bumper pass side 9:13.jpg
