Oldtuleguy - I'm fairly confident about the connection to Riverside on that particular model ratchet. In the "Duro Ratchet?" thread, I posted dozens and dozens and dozens of images of various iterations of the Duro-Indestro "pressed flange" ratchet (patent 1902878) to show the different designs that were used.
Lesserstore: Your 360 "Slip-On" set (patent 111026) is the third (and last) iteration of that model: the clear and white handle dates from the 1960s-1970s.
Curiously, the datamp.org page for that patent says the driver shank does not have a screwdriver tip end. I have to assume the previous owner of their example must have ground it off. I own two of the early versions (one with an orange painted handle and one with a RED painted handle
and they both have screwdriver tip ends, as does my "middle era")(clear yellow plastic handle) model as well as the two later (clear-and-white plastic handle) models like yours.
Beware of cheap imitations!
and they both have screwdriver tip ends, as does my "middle era")(clear yellow plastic handle) model as well as the two later (clear-and-white plastic handle) models like yours.Beware of cheap imitations!
Indestro 360 'Slip-On' SAE socket set (patent 111026) 01.jpg280.1 KB · Views: 39 -
Indestro 360 'Slip-On' SAE socket set (patent 111026) 02.jpg247.1 KB · Views: 21 -
Indestro 360 'Slip-On' SAE socket set (patent 111026) 03.jpg509.5 KB · Views: 16 -
Indestro 360 'Slip-On' SAE socket set (patent 111026) 04.jpg454.9 KB · Views: 17 -
No Name U.S. made 1.4 hex dr SAE socket set (Indestro 360 knock-off) 01.jpg324.2 KB · Views: 13 -
No Name U.S. made 1.4 hex dr SAE socket set (Indestro 360 knock-off) 02.jpg381 KB · Views: 13
