Show your Machine Shop!
goodfellow
NoVA
After "e-tek" pointed out my laziness about not posting pics of my small machine shop in the "Two Car Garage" thread, I'm compelled to start a new thread. :lol_hitti
I'm not a machinist, so I don't have pro tools. But I do know enough to make/modify parts for my old cars and to make some tooling along the way.
It's nothing much; cheap HF mill/drill and a 3-in-1 lathe/mill/drill machine.
The bandsaws are set up for metal, as is the mitre saw (aluminum cutting)
I haven't been to a pro machine shop for anything but cylinder head decking in years. Everything else I've managed to do myself.
I'm sure there is plenty of interest in seeing other GJ members' machine shops as well.
However, we all know who's got the "best dang" machine shop around -- don't we? --- OCG
BTW -- I also restore my old Sun Testing equipment in there -- the current Sun 1160 machine is being rebuilt for a friend who returned from Iraq last September.
toadjammer
WI
Here is the machines I have at home. I am eventually going to be moving them over to the shop to have everything together. I just kept the basics at home for now so I still have room to have space to work on my car at home.
tdkkart
Eastern Iowa
Some of you have seen the pictures, may not have noticed the machine tools:
HF blast cabinet, Atlas 12x24 "wet noodle" lathe, Burke Millrite milling machine, Atlas drill press, Bike lift for the Harley. Also not in the pictures the obligatory HF 4x6 bandsaw, a couple sanders and grinders. Offshore 120V mig, and Miller 180SD TIG.
Primarily, most often useage is building racing go kart engines,
.......and the occasional oddball project:
rsanter
visalia ca
Bport mill on rolling base that I made.
older cman/atlas lathe on rolling workbench
pressure feed blast cabinet that I made
drillpress (for metal)
8'' grinder
now for what you do not see (they are in the other shop)
I also have a 12x30 pratt&whitney lathe with taper attachment that has also been converted to have a backlash eliminator
van norman 777 boring bar
Sioux and B&D sets of valve grinding equipment, bowl hogs to open uo port bowls for larger valves as well as seat and guide replacement tooling
tobenarcing fixture for adjusting the center to center lenth of rods
woodworking equip
2 table saws
2 bandsaws
edge sander
shaper
thickness planer
jointer
horizontal edge router (I made it)
drillpress (for wood)
bob
tdkkart
Eastern Iowa
I guess not too many machinist nuts here, all afraid to get their SO tools dirty and scratched up.............might get chips in their foam drawer liners.
cyclopsblown34
Russellville, Missouri
There are several of us machine tool dreamers on here as well. My shop isn't large enough and neither is my budget so I stick to body, paint, electrical , mobile entertainment, engine and light chassis work,
sirswank
the littlest state
i hope to be picking up a b-port in the near future that will be the crown jewel of my meager collection of sears and H-F light duty machines. still looking for a lathe tho... suggestions?
jhchoppers
Maryville, IL
Nice setup Old Car Guy!
Here is mine. SuperMAX Mill, BP Series II CNC MILL, BP Vertical Machining Center, 13x40 Gap Bend Engine Lathe, ..
Machine/Parts Shop
Paint Booth (work in progress)
smooth72
Newcastle, Oklahoma
JHchoppers, all I can say is wow, you done a great job. Keep the pics coming, especially details on paint booth, details details, that pull curtain looks like a great solution for a dual use garage.
OldCarGuy
Nice shop JHChoppers.
You have a lot more CNC milling machines capacity than I do. I only own one Bridgeport EZ TRAK DX CNC milling machine. Though I do own a second standard Bridgeport mill and a Kearney & Trecker Rotary Head Mill. Much of what I make are one-offs and normally forgo the CNC route and use one of my manual milling machines. Even though I have Master Cam programing capabilities. I can usually crank it out by hand in less time than to program, download, then run it on my CNC mill. But then again I’m from the old school...
G
goodfellow
NoVA
Very nice!!!! That is a class act, only second to OCG's setup.
BTW -- is all that equipment setup in your home garage, or a commercial building?
kvom
*******, GA
My camera is in for repairs. What I have is BP manual mill, Monarch 10ee lathe, Johnson bandsaw, small arbor press. Mine is just a hobbyist shop.
G
goodfellow
NoVA
A Monarch 10EE and a BP put you in an enviable position -- definitley quality tools for any shop --
jhchoppers
Maryville, IL
Could you tell me more about the clear curtains in this photo?
Autoist, the curtains are Goff Curtain Walls. These are the real deal, chemical resistant to paint, and work great for protecting the Machine Shop when I do welding and grinding.
http://www.goffscurtainwalls.com/
I got mine from at Marathon Finishing (no association with), they had the best customer service and the best price, ask for Marie (tell her JH Choppers sent you).
http://www.marathonfinishing.com/
We needed 2 curves in the track, I found the best price at Drill Spot. The track is made by TMI, so you can get special parts just about anywhere.
http://www.drillspot.com/
I plan to do a full write up when its all done and tested...
Thanks, I hope this helps you,
Joel
uparms
Delaware, USA
JCCHOPP and Autoist,
You both have that paint booth curtain at I saw and a Autobody trade catalog.
You like it? Looks like it covers up to the ceiling great, how about down to the floor.
JC and anyone else?? If I was going to build my own ceiling / floor - - dust / fume collector, how do you decide exhaust tubing size and pump size and filter inlet sizes.
I would want one enough for fumes and paint spray. Would also think about tieing the same pump into a floor collector for dust and small particles.
Vinko
Los Angeles
I like that idea of the curtain for the the shop. I've got nothing like it, and I was looking at exhaust systems which are considerably expensive. And you get the government crawling up your *** to boot.
