Show your new tool arrivals
cmandp
New Jersey
Bought at Lowes to put in my small toolkit for my truck. Was immediately disappointed with the rather large (at least .002") gap at the tips. Not really sure what is normal with knife and anvil style cutting edges :dunno:.
jjjrmx5
Cincinnati, OH
I have several pair of the Greenlee brand (Taiwan made) same pliers (sharpend edge with anvil other side) and I just went down and checked and all lined up with no gap when gently closed and held up to the light like you show.
Huh.
Motor-Mechanic
England
Picked this up today, should have been £24.99, got it for £19.99 with my trade card.
nanofrog
I would exchange them. they will not work as well with a gap.
+1 :thumbup:
A spike would remain, and the wire bent back and forth to separate the two pieces. Remaining uncut insulation would be a problem too, and if smaller gauges were being cut, may not cut at all (i.e. say 26AWG and smaller).
B18c_tuner
Thanks. A little bit of smooth talking can go a long way haha. And yes this is another CL deal.
beelsr
NE PA, USA
Return them. The gap is exactly backwards. You want cutting edges to meet at the tip and gradually, ever so slightly separate so that as the tips wear, the rest of the cutting area meet.
cmandp
New Jersey
Definitely going to return or exchange them depending on whether or not Lowes has more in stock when I go (these where the last pair).
RobertMo1988
probably none, to me the student sets are kinda priced high and it leaves you with weird things like a single pry bars or a single adjustable wrenches as pictured, thats over 4k right there and id agree its the master tech starter thru the student discount
jjjrmx5
Cincinnati, OH
Thanks RobertMo. I figured it was a student discount and a std set but was curious as to the price. If that cost $4,000 or more , the loud snap you just heard was my ******** slammin' shut.
Fark that's a load of debt to take on as a student.
jrherald420
Louisville,KY
Pretty sure its the Master tech u.s. 2 set, lol and its not 4000.00
PN 9200AGSO
U.S. Set 2
$2,631.16 | Add To Cart
View Larger Image
Image shown may not be actual product but represents product or set which includes product
Description:
More than 200 pieces. Includes all tools in the 9100GSO Apprentice Set and 9000GS2 Add-on Group. Tools only.
Included in this set:
Carbon Scraper, Rigid, Black, 7/8in Blade Width, 7 5/8in (CSA8C)
Driver, Standard Shank, Instinct Soft Grip Handle, 1/4in drive, 7in (SGT4BR)
Extension, Knurled, 6in (TMXK60)
Extension, Knurled, Friction Ball, 11in (FXK11)
Gauge, Feeler, Combination Spark/Ignition, 18 blades (.010in thru .035in) (FB316B)
Gauge, Feeler, U.S./Metric, 25 blades (.0015in thru .025in) (FB325A)
Gauge, Gapper (FB361A)
Gauge, Wire Gap for Electronic Ignition Systems (FB303B)
Goggles, Chemical Splash (GAC1580)
Hacksaw, Bi-Mold Handle (HSG319)
Hammer, Ball Peen, 16 oz. (BP16B)
Hammer, Plastic Tip, 16 oz. (HBPT16)
Kit, Battery Service, 4 pcs. (2004BSKA)
Mirror, Round, 14in extension (Mirror: 2 1/4in Diameter) (GA295)
Pick Up Tool, Magnetic, Telescopic, Chrome (PT5C)
Pick, Radiator Hose, Soft Grip, 10.30in (SGA173BR)
Pliers, Adjustable Joint, Interlocking Channel, Industrial Finish, 9 1/4in (91ACP)
Pliers, Locking, Curved Jaw with cutter, 10in long (LP10WR)
Pliers, Needle Nose, Vinyl Grips, 8in (97CCP)
Pliers, Retaining Ring, Convertible, 3/8in-2in Internal, 1/4in - 2in external, 8in (PRH57A)
Prybar, 16in (1650)
PUNCH/CHISEL SET/KIT BAG (PPC710BK)
Ratchet, Sealed Head, Dual 80(TM) Technology, Long, Flex-Head, 3/8in drive (FLF80)
Ratchet, Sealed Head, Dual 80(TM) Technology, Standard Handle, 3/8in drive, 7 11/32in (F80)
SCRAPER (PK53A)
Screwdriver, Ratcheting, Soft Grip, Standard, Red (SGDMRC44B)
Set, Adaptor/Extension (6 pcs.) (206EAU)
Set, Cutters/Pliers, 3 pcs. (PL300CF)
Set, General Service, 6-Point (14 pcs. In plastic tray) (114ATMP)
Set, General Service, 6-Point (17 pcs.) (317MSPC)
Set, Metric, Wrench, L-Shape, Hex, Long (11 pcs. in BHK11 Metal Index) (2 to 12 mm) (AWM110DHK)
Set, Miniature Pick, Instinct Soft Grip, Orange, 4 pcs. (SGASA204AO)
3W LED 2D Cell Flashlight (ECF201A)
3X7 ROW WELDERS TOOTH BRUSH SS (AC5C)
Adaptor, Industrial Finish, 1/2in Internal drive x 3/8in External drive, 1 1/2in (GSAF1E)
Socket, Spark Plug, Standard, Retention, 5/8", 6-Point (S9706KRA)
Tape Rule, Inches/Stud Markings, 12 ft. (TPMA12)
Tester, Circuit, for 6V and 12V Systems (EECT4H)
Wire Stripper/Cutter, (AWG 10 to 20), 6" (PWC6)
Wrench, Adjustable, FLANK DRIVE Plus, Cushion Grip, 12" (FADH12A)
Wrench, Combination, Standard Length, 1", 12-Point (OEX32B)
Wrench, Combination, Standard Length, 15/16", 12-Point (OEX30B)
Set, Screwdriver, Combination, Instinct(TM) Hard Handle, Orange, 8 pcs. (SHDX80O)
Set, Socket Driver, TORX, Standard, 1/4in-3/8in Drive, T8 to T55 (12 pcs.) (212EFTXY)
Set, Socket, Deep, 6-Point (10 pcs.) (3/16in to 9/16in) (110STMY)
Set, Socket, Deep, 6-Point (11 pcs.) (1/4in to 7/8in) (211SFSY)
Set, Socket, Metric, Deep, 6-Point (12 pcs.) (8 to 19 mm) (212SFSMY)
Set, Socket, Metric, Shallow, 6-Point (12 pcs.) (5 to 15 mm) (112TMMY)
Set, Socket, Metric, Shallow, 6-Point (12 pcs.) (8 to 19 mm) (212FSMY)
Set, Socket, Shallow, 6-Point (11 pcs.) (1/4in to 7/8in) (211FSY)
Set, Wrench, Combination, 12-Point (9 pcs. In tray) (3/8in to 7/8in) (OEX709B)
Set, Wrench, Flare Nut Double End, 6-Point (5 pcs.) (1/4in-5/16in to 3/4in-13/16in) (RXFS605B)
Set, Wrench, L-Shape, Hex (15 pcs. In BHK15 Metal Index) (.028in to 3/8in) (AW1015DHK)
Set, Wrench, Metric, Combination, 12-Point (10 pcs. In tray) (10-19 mm) (OEXM710B)
Socket, Spark Plug, Shallow, 13/16", 6-Point (S9704KA)
RobertMo1988
pretty sure its actually two sets
PN 9200AGSO
U.S. Set 2
AND
Add-on Group 3, U.S.
$1,699.98 | Add To Cart
you dont get the pry bar or adjustable in the same set. they come in seperate sets. and he has both pictured. and im pretty sure in the top right by the pry bar is the MG725 in the box which you get in the group 3
$1,699.98 + $2,631.16 = $4,331.14
Syndicate
Yea I think Robert is correct on this one. Either way dude has a very very very good starting set that will last him many many many years to come for his trade. Probably will make 20 times that in wages, and all he needs now is a big fat harbor freight box to keep it all in :lol_hitti :lol_hitti
Nice pick up on the set.
Fedwrench
Valley of the sun
That's a beautiful Snap on set.:thumbup:
However, it's not very realistic for a student set for someone entering the auto repair field.
Entry level techs do lube, tires, and quick lane type stuff. There's No impact wrench, no torque sticks, flip sockets, no lube tools. I didn't even see a tire pressure gauge/inflator. How's the new tech going to get wheels off and on?
It is a beautiful set even though it might not be the most practical one.
Nice purchase, now get em dirty!!!:beer:
jrherald420
Louisville,KY
Hell i used all of my allowed Snap-on student discount. Only thing i can get now is a upper and lower box and theres no way im buying them new. I did buy a 3 drawer cart but its been full for awhile now.
Tomato
Yes those are the student sets, I am grateful to have been able to get them. I'm not trying to show off I figured all of it was too pretty not to post though!
