Show your new tool arrivals
Fedwrench
Valley of the sun
Wera Goodness from Chad's Toolbox. 8009 Zyklop Pocket set 1. It fits my hand well. It's not the usually ribbed handle. It's more rectangular feeling with curves in the right spots. ample bit storage. Bunch of You Tube videos on this tool. Bits or sockets are magnetically retained by the ratchet head, The 3/8 square drive has a 1/4 hex hole in the center of it to use with bits. I like it. :beer:
JWC86
Took me forever to decide on a Bearing puller for motorcycle work. Seemed like all I could find was either really cheap Chinese kits with really bad reviews, mid priced stuff that was just the same kits as the cheap Chinese stuff with equally bad reviews or really expensive kits that were actually very well made but usually very small range and again, very expense.
Finally I came across this mid priced made in Taiwan kit that has very good reviews and seems to be made OK. I really like how it has a bridge setup as well as the slide hammer.
ALPHA MOTO Motorcycle Blind Bearing & Bridge Puller Remover Removal Tool
Next up is a leak down tester from OTC
And finally a metric thread chaser kit from Lang.
I tried out the M8 right away on a bung that was packed full of old lock tight and it worked great. This set will get a lot of use.
zmotorsports
Northern Utah
I have this same Alpha blind bearing removal kit and it has worked well for me for many years now. My only complaint was the hinges on the blow molded case failed early on but by looking at yours it appears as though they changed the design. Yours appears to be a plastic pin/hinge style whereas my older kit has the thin plastic webbing style. Despite the cases' shortcomings the actual puller and pieces have worked well and held up very well over the years.
JWC86
^ Taiwan and Japan are way ahead of the pack right now where it concerns tool innovation. Damn nice-looking puller set there. :thumbup:
I agree.
It's too bad Motion pro seems to have gone to Chinese manufacturing for a lot of its stuff(while keeping the same prices) it used to be if it was Motion Pro you know it was going to be good. Now there puller set is just the same Chinese kit you can get on amazon for $50.
zmotorsports
Northern Utah
I agree.
Agreed, Motion Pro used to be a much higher bar. Glad I purchased all mine years ago because I have not been impressed with the newer stuff I've seen.
JWC86
Awesome, good to hear. Not a lot of reviews on the Alpha kit but the ones you can find seem good.
The case and hinges seem very adequate for shop use.
jmf535
That bearing puller looks just like the Tusk one that I have (minus the bridge puller). I know that the Tusk one on offer now is different (aka cheaper), but I purchased mine ~10 years ago, and it has served me very well. It doesn't see a ton of use, but it's always performed when called upon, and shows little sign of wear.
And I agree with Motion Pro...not at all what they used to be. I actively avoid them, if possible, these days
bobg03
conway sc
I can't comment on the tool, but I agree with you on the cases they use. I have thinned my last roller out to a minimum amount of what I need and use, the hinges allow me to remove the lid and just set the bottom half of whatever is in it in a draw without spending a fortune on organizers. I throw the lids in an mt file cab drawer and if my lifestyle ever changes I have all the cases.
Squankum
Southeast
I've got that leakdown tester and it's nice. I recently used it for a valve stem seal job on one of my cars, too. (Because my old Craftsman compression gauge's hose didn't play nicely with my Milton high flow fittings and rather than search for/build that adapter, I just ran and grabbed my OTC leakdown box and was in business at 75 psi into the cylinder like I needed, right away.)
Squankum
Southeast
Just metric? Boy, I'm a Eurofoofoo but I'm glad I bought the full kit. (Then again, there are some semi-old Detroit things in my life now, thanks to the woman. I lived a very metric life before her.)
I forget if Lang makes them all or Kastar makes them all and all the other brands sell them under their label, but I got my (Kastar?) set from/as Sears and am glad I did. GJ can make you aware of so many things you didn't know you needed....
Squankum
Southeast
Grabbed this little bench-top 30V 10A DC power supply.
Mr. Roboto, what do you use such a power supply for?
I'm thinking I could use it for auto electrical diagnosis when I want 5 volts... maybe someday, but right now, to test the old timey idle air bypass control rotary valves in my 80's cars, which rotate a certain amount based on voltage input. Pic from the internet:
Mr. Roboto
New Hampshire
So the current need was to diagnose a few Jeep power seat bases I have. I need to be able to monitor and limit the current draw to them while testing them out of the vehicle. Also, to build and test some custom 12v electronics. There are cheaper ways to do this of course, but for $60ish you can’t beat the convenience. I’ve also had several uses in the past where this would have come in handy, as I usually “Hotwire” a Milwaukee 12v battery to use.
demarpaint
Long Island
Nice pullers, but don't forget the white bread trick!
It works! I did a clutch job over the summer and used bread, and a 3/8" extension, the end that fits onto the ratchet fit nicely into the bearing. I had to pack bread into the extension as well. Once the bread was packed I started hitting the extension with a hammer and packed in more bread. It took a few slices and a few good smacks with a hammer to get it out. I was very happy with the results.
Squankum
Southeast
Domo arigato, Mr. Roboto.
SRU1436
Bay Area, CA
I used my cobra 6 inch pliers the other day for the first time, I really like them and since they were so good (my first pair), I decided to get the 10 incher since they were on sale. I also got 3m electrical tape for a steal ($55) on Amazon as well.
tamaraw
Got this torque wrench adapter at work earlier via Amazon. Motion Pro 08-0380
Its basically a clamp with a 3/8" drive input meant to hold normal wrenches as an alternative to dedicated crows foot and square drive box ends. The machining is mostly clean and it has good tolerances on the drive broaching. One screw doesn't thread quite as easily as the other but they can both be set finger tight, you don't really need an allen key. It did come with a packet of white grease that I haven't tried yet.
With a small 8x10:
With a larger 22x24. KTC M150 series with relative flat edges:
Vintage Proto with rounded edges, holds just as well:
There is a little bit of play with a tapered handle if you push on it (no duh) but it won't rattle or fall out on it's own:
It can even grip some smaller round bars. Crazy example with a 1/2" extension:
Example usage mounted on a torque wrench:
A little pricey for what it is and probably not perfect for every situation but it takes up way less space than a full set of dedicated torque adapters and I'm sure I'll be glad to have it at some point.
Squankum
Southeast
I had that on my wish list for a year or so, but the price for this (and a similar one) always seemed too high and never dipped. I learned about it on the YouTube channel Heidi & Franny's Garage. Franny was doing work on a 911 motor -- out of the car -- so she had all the room in the world. That's what got me buying torque adapters first, because in today's cramped engine bays, you know...
But what if I need a size I don't have in my metric torque adapter set? Or really need, you know - an open-end wrench? WHAT IF? So I got the cheaper K-Tool recently. No set screws, just bent lips in both directions. No law saying you can't put a stubby wrench in it, too!
I keep it next to my torque adapters. :D
zmotorsports
Northern Utah
With a small 8x10:
I looked at one of those from Motion Pro a few years back when I was building a lot of off-road powersports motors as some of the jugs were bulged to the point where a socket wouldn't fit on the cylinder base nut. I ended up purchasing a set of torque adapters instead and have been using those, but I did waffle on this adapter.
JWC86
With a small 8x10:
I really need to pick up one of these, I'm always finding myself in situations that it would be useful and I end up forgoing using the correct torque values because I can't fit the torque wrench in there. Happened yesterday with a valve cover on a DRZ400.
qqzj
You can just get a pair of Sunex torque extension sets. I got both metric and SAE versions for $80 from CL.
saltwater4life
New budget wilton from Amazon, 4/5 probably not American made and feels kinda crunchy but it’ll work for my needs and some long reach sunex pliers.
Rkcubed
Missouri
Picked up a set of good looking green Heyco screwdrivers from KCTool.
Didn’t really need some more screwdrivers, but I really like the green.
I have some Heyco screwdrivers from the 60s that have red handles.
Also picked up a micro Knipex pliers and a NWS pliers.
krupa530
Orem, UT
Just ordered the same green set today.
Squankum
Southeast
Steve_P
^ the intended purpose is for plumbing, like sink and shower traps, and Amphenol type electrical plugs
tamaraw
