That there is a post by a REAL CGer. Don’t need it…but…l have the 894. Not a bad impact either. l probably don't need the 891-892 either, but l want it.
Nice Napa haul today. Was waiting on me at home. Only part one of my order haha. Other part should be here tomorrow. I keep losing my number 2 Phillips heads so I bought an extra one again lol. I ordered one from Snap-on about a month ago but he hasn’t been back since so I’ve pretty much written that off. Then a set of metric ball Allen sockets. So for those who asked if I buy sets yes I do. This set I looked at it in person at a very rude Napa store so I chose to use my coupon and order it online instead of that rude store. I managed to get all of this for just $8 more than the entire set so $158 for everything. The Carlyle set appears very well made. I looked at the set at Auto Zone and Advance and they did not seem quality at all and seemed very weak so I chose the middle ground set. It was either this Snap-on or Mac or Matco and they are all priced $110 more than these so since they aren’t an everyday use tool I chose these. I’ve had excellent luck with Carlyle tools just they are expensive which is why I don’t buy them often. Then I got a 12mm socket for one set I need to complete at the house. And the tool coming tomorrow is for Subaru as I’m still a Subaru tech since the Toyota isn’t permanent.
3mm-10mm. That’s another advantage cause the sets from the truck skip a few smaller sizes....Um... No hablo the Carlyle set box (in either pic)...
What sizes are included?
Mike
Just be sure to use the **** out of it as soon as it arrives, test all the processes within the return period.
If addicted to tools, it's not a matter of need, but a matter of want. I could return it, but the extra torque could come in handy. For how much I use my tools, overkill is a word that comes to mind.l have the 894. Not a bad impact either. l probably don't need the 891-892 either, but l want it.
Took a look. That's pretty cool. Too bad I didn't know about that first, but now I know for next time. Thanks!as a fellow euro guy, Strutmonkey.com is the go too if you want preassembled stuff, guy uses all oem stuff or w/e aftermarket combos u want.
Well call me crazy but I bought myself a welder - Hobart 210 MVP. Gonna do a little self-learning and then try that cat replacement myself. If that works I’ve got years worth of “when I finally learn how to weld” projects to try out…
I am not a welder (yet) but I did stumble across this tool a few years ago and kicked myself in the *** for not having invented it myself:
Summit Racing SUM-693322 Summit Racing™ Exhaust Welding Clamps | Summit Racing
Free Shipping - Summit Racing™ Exhaust Welding Clamps with qualifying orders of $125. Shop Exhaust Welding Clamps at Summit Racing.www.summitracing.com
Dang, I could have sworn these used to be $12.99.
Blake, it's very easy to make that blue dot into a red dot... Then, all will be right with the world.
New tools from eBay and Napa online. Bought the 1 1/2 combination wrench on eBay for $10 old stock Duralast made in Taiwan not China. Really quality made like all their tools. Just hate the blue dotslol. Red should be SAE but they always had it backwards. I also ordered a Cornwell socket the same day from a different seller and it hasn’t even shipped yet so I’m beyond angry have already reached out to the seller and no response so will be filing a claim shortly. I really needed it this weekend I wanted the 6 point socket as my 12 point 1 1/2 is very sloppy fitment. 1 1/2 is for dads truck multiple places. We have to pull the other drain plug this oil change because the seal formed a leak so instead of just using the quick drain we are gonna pull the other plug this go around. I can’t source a 1 1/2 6 point locally anywhere. I paid almost $30 with shipping for that socket. A better fitting 12 point would probably be ok but I’ve had some bad luck with 12 points so I don’t even like trying them. I will try this wrench but it’s very tight. Auto Zone has since discontinued this big of a wrench. Biggest SAE size I’ve seen lately is 1 inch.
Then a Carlyle 13mm square plug socket for Subaru. This is what you need for Subaru differentials. A 1/2 square would probably work but I like tools and like having the right tools. I’m still a Subaru tech and always will be but I’m just helping out at Toyota temporarily. Thankfully it’s only temporary I don’t want to represent that brand any longer. I will be glad to be back to Subaru soon.
I've been eyeing that one myself.WEN 6” jointer planer with spiral cutter, just tried it and I was very impressed
It's a sickness you contract through the internet - via www.garagejournal.com
I would never spend that kind of money on new Snap On pliers!
Got some new Knipex today; finally getting some TwinGrips
And if 13mm is a little too loose, because the drain plug has been distorted, Koken makes a 13.5mm square socket.Then a Carlyle 13mm square plug socket for Subaru. This is what you need for Subaru differentials. A 1/2 square would probably work but I like tools and like having the right tools. I’m still a Subaru tech....
I bought a Titan branded set of those from O’Reilly Auto Parts last Fall and I have found many uses for them as well. As a matter of fact, I don’t think that I’ve used them on an o-ring as of yet.In theory, sure. If you're reusing the O-ring. Or have good reason to worry about scratching up the piece. But they are neat! They have many, many uses. These and some el cheapo pocket prybars like everybody else at GJ discovered this winter have been some of my funnest, handiest, many-uses tool additions of the past 6 months.
You cannot go wrong with Proto. After a few years of trying out various brands, I've come to realize that Proto is very good quality and has become one of my two go-to brands. I totally regret that I started with a simple Proto set and then moved over to all these others like Williams and Stahlwille because I was swayed by how jazzed everyone was about them on these boards. I would've saved a ton of money if I had just stuck to my initial instinct and Proto. Nice purchases!Finally decided to upgrade some of my sockets. Been taking a closer look at one of my local Proto dealers and with a recent sale, the pricing looked good enough to pull the trigger.
Took over a month to arrive, but I wasn't going to push.
1/4" drive metric 6 point sockets 4mm to 14mm - no skips (J47200) $41.17 delivered.
3/8" drive metric 12 point sockets 6mm to 26mm - no skips (J52215) $99.25 delivered.
3/8" drive torx bit sockets T15 to T50 (J5239C) $44.06 delivered.
1/2" drive metric 12 point sockets 10mm to 36mm -some skips 31, 33-35mm (J54212) $229.77 delivered.
Napa hex bit sockets are pretty sweet. I've been abusing the **** out of the 5/64" and a 5/32" sockets in my set and they have been bulletproof. I'm also a fan that the bits aren't stepped at the smaller sizes so if I can't warranty one right away I can take an old Bondhus, cut it down, and shove it in the socket. I'm a little miffed that the ball-end sockets are so much more money than the regular sets.
So, what's the deal with working with Toyota? Not a fan of the shop, the culture, or the cars?Then a Carlyle 13mm square plug socket for Subaru. This is what you need for Subaru differentials. A 1/2 square would probably work but I like tools and like having the right tools. I’m still a Subaru tech and always will be but I’m just helping out at Toyota temporarily. Thankfully it’s only temporary I don’t want to represent that brand any longer. I will be glad to be back to Subaru soon.
The way Toyota acts. They are very picky about warranty, and very picky about shop layout and training and all that. Won’t help customers out like Subaru will. And harder to work on than Subaru. I’ve had them down on my list ever since they denied to warranty my moms fraying serpentine belt on her brand new car. They are so knit picky on warranty. I’ve seen a lot of stuff denied that should have been warrantied. Whereas Subaru would generally be like ok well we will take care of it even if the car was just out of warranty they would still usually do it once. And I don’t like the managers over here either. That has a lot to do with it too.So, what's the deal with working with Toyota? Not a fan of the shop, the culture, or the cars?
Hmmm... Wondering if the rod my Rabbit diesel threw in '89 at similar mileage had the same issue. That car wasn't in great shape, so I junked it and got a better car...Long ago, mid 80's, I was a flunky boy at VW dealer. Customer with a Rabbit diesel had a rod bolt fail at less than 85,000 miles. Car was out of warranty, but service adviser called the VWNA mothership and all agreed that that was really not normal, and warrantied it. I was kinda impressed.
