Show your new tool arrivals
LXCam
Been wanting a Bolt Buster since the first time I saw one 10 years ago. I just found out other companies make them and they aren't $4-500.
Where did you get that at Brady, I’ve always want one but never bit the bullet.
dukefx
Got myself a few disappointments. Wera hex bits and Engineer screw extractors. There was a partially rounded screw I needed to take out. Wera Hex Plus failed, so did the Engineer bit. The Wera bits aren't meant for screw extraction but I expected better than rounding it even further. The largest screw extractor that is meant for #5 seems to be a bit smaller. Couldn't bite.
NYBODYMAN
NY
I bought this on Amazon two years ago. One of the best tool purchases I ever made. This thing is a life saver and safer than using a flame.
Squankum
Southeast
CTA Tools Extra Deep 3/8ths metric.
I love this set.
I was just pondering this concept last night... the "very long stud" reason for deep sockets doesn't come up as nearly as much as "needed the reach."
At what point do you just use an extension?
OTOH, no slop, and that can be appealing sometimes. (Sometimes slop is like a tiny wobble.)
Marvin Berry
Northern NY
This is why I bought them, I always either grab a deep socket, or a 3" extension, just to keep my knuckles out of the way (ESPECIALLY when using a flex head ratchet, they always beat up my knuckles).
The length of these is absolutely perfect, great clearance and no slop.
My only trouble is, I can't find them in SAE.
WWheeler
Middleofnowhere USA
I've used them for recessed bolts on some bumpers and lamps where they were a necessity. Also came in handy getting to an injector fuel rail that was a PITA having to use a stick magnet to get a regular deep socket back after it repeatedly came off the extension every time because the socket had push against the harness to get on those recessed bolts. The CTA extra deeps stuck out enough I could grab them with my fingers.
GeoBruin
Compresor cevik de 50 litros y 3 caballos de fuerza. Creo que mis próximas compras serán herramientas neumáticas.
Interesting design. I've never seen a direct drive one like that. That's over 12-1/2 cfm which is pretty good for "3hp", although they don't specify at what pressure.
There must be a gear reduction or something. The motor is advertised as spinning 2950 rpm. No way the pump is spinning that fast.
housewolf
East Texas
Icon semi deep 3/8” metric sockets. It’s obvious they copied SO and I really wish I could have justified the cost of SO for these. I recently bought SO semi deeps in 1/4” drive and they kind of became my “go to” in 1/4” dr. (maybe because they are new to me?) If I find myself using these a lot and am the least bit disappointed, maybe I’ll bite the bullet & buy SO 🤷‍♂️
Shown next to SO shallow & deep sockets
jgeoffr
Starting the unboxing and cataloging:
Picked up a bunch of socket, screwdriver and pliers storage options. Wanted to try the different manufacturers (Ernst, Ares, Tekton, Olsa) and see what works best before committing to a specific system. This is directly because of my newfound hatred of the metal spring tension socket rails.
Drivers galore. Bondhus SAE and metric hex, as well as square drive. Vessel ball drive and impact JIS screwdrivers, and a set of precision too. Klein pocket screwdriver and combo tip driver (and an Ideal for good measure). Irwin square drive bits and Mayhew screw extractors. Some Craftsman bit blocks (regular and security) and a Sunflag valve stem remover.
lasagna
Hoto Precision Screwdriver Set, 24-in-1 Manual Screwdriver
I was hesitant to make this purchase because Hoto is a Chinese brand, but I'm impressed with this precision screwdriver so far. The magnets used for bit storage are powerful, and the magnet that holds the bit in place for screwing makes for a secure fitting. The bit storage pulls out (as opposed to screwing in with threads). The cap at the top swivels, which can be handy when screwing or unscrewing, depending on which kind of grip you use. The screwdriver body is an aluminum alloy and the bits are stainless steel.
ForrestT
Waldo
New 90 tooth long flex head DieHard 3/8” drive ratchet. $23.69 out the door using 1May code and a $10 speed perk. Can’t beat it for that price. Nice stuff. I can see why Capri went with Williams for their new ratchets. I’m honestly liking it better than my long handle Tekton with the detents.
CHI_Tool&Die
Chicago, IL
Those Bondhus drivers are pretty nice but I find the handles on the larger ones kinda too square. It’s kind of difficult for me to spin them. I had some issues with the smallest ones being bent too. But they fit SHCSs so well. Nice work!
jgeoffr
Thanks! I debated whether to go with a set with uniform handles or these with various sizes. The cost for US made sets primarily drove my decision.
vjquan
Those basically come bone dry, so be sure to lube it up. I couldn't find any connection with Diehard, Capri, or Milwaukee being Williams made, so wondering if there's any truth to that.
BlakeTheCarGuy
Roanoke Virginia
Nice. Every time I go to get one of those they are out of them at all the Advance stores around. Lucky find there. They seem like well made ratchets.
LWB
ON, Canada
Picked up a gooselight from Lee valley. I hope the neck doesn't get floppy, in time. In the instructions it says it may not work with rechargeable batteries. It doesn't, they're too wide. However, it works with 2 rechargeable' s and a normal battery. I like that I can use this for wood working machines too.
I can see! Bleeding brakes. I tried using other style flashlights but the entire wheel well has a plastic liner.
Wiz02
Southeastern PA
Great idea! 💡
Meursault74
Southern California
I used the caulk tool set today. Redid the bathtub and kitchen sink. Did a good job of scarping off the old material in the crack. The flat surface, I used a razor blade at times as the flat part on the tool was just ok. Good thing about being plastic is that I wasn't going to damage the porcelain. Bad thing about being plastic is there is visible wear after the two tasks. The squeegee tool did a good job of smoothing out the silicone bead. Certainly much better than using my finger. That's what I did years ago when I didn't know they made these tools.
Right angle attachment for my Dremel. Have to get the cutter into a tight spot. I'm hoping this attachment will allow me to do that. Have not had a chance to use it.
Kasal
Galicia, España
Diseño interesante. Nunca he visto uno de transmisión directa como ese. Eso es más de 12-1/2 cfm, lo cual es bastante bueno para "3hp", aunque no especifican a qué presión.
Debe haber una reducción de engranajes o algo así. El motor se anuncia girando a 2950 rpm. No hay forma de que la bomba gire tan rápido.
la presión máxima es 130PSI-9bar
