Show your new tool arrivals
dscheidt
Yeah, I wonder how they installed things at the factory sometimes, and always try to install things so the next mechanic (me) can get at them with my particular set of tools, or, best case scenario, some other mechanic out there can get at them with the crudest of tools.
I'm not sure how all of the other car companies do it, but I've learned from a friend that Mazda sells their hose clamps like this, preloaded:
Which makes me suspect that on the assembly lines, they're merely pulling that tab and the hose clamp snaps shut. Hose clamp in that pic looks double-layered, not sure if that is relevant.
Almost all constant tension hose clamps are installed either with a hold open device like that, or one built into the clamp (that's what the hole in the bigger side of the squeeze part is for, the other side sticks into it). Put in place, squeeze with a pliers, done. This being GJ, I'll point out Snap-on (and probably others) sell a hold open much like that. The snap on ones install from the side, so you can put it on while you're holding it open with the pliers. Just $75 for a set of three...
Squankum
Southeast
These?
mikegt4
sw ohio
It’s interesting to see the VEVOR name come up frequently these days on several items from ultrasonic tanks to reels to fluid extractors.
I recently watched a YouTube video (one of the tool testing channels) that went through the history of VEVOR, apparently they have been around for a while under various names (VEVOR is the name of one of the owners) and have been ramping up their presence here in the US. The YouTuber did a lot of research on their business history and he found it a bit sketchy, lots of levels of shell companies and a lot of complaints. It's a Chinese based company selling Chinese products of varying degrees of quality, some are pretty good. I can't remember which channel it was but probably could be found with a quick search.
mikeinri
Wow. Alrighty then...
I've been using some recent purchases (and a gift from Mrs. Claus) over the past couple of days, working on some electrical repairs...
Milwaukee markers (GJSS got me curious, these things are AMAZING!)
I bought the Fluke GFCI tester over the summer, the Ideal non-contact voltage tester recently (on clearance!), and the Milwaukee screwdriver was part of this set from Mrs. Claus.
That screwdriver is amazing (designed for screws on electrical receptacles). Do they make a bit (for a power tool) with that profile?
Also picked up my first bucket tool organizer. Not sure how much I'll like this, but it was under $15...
Also in that last pic, some small zippered bags to protect the new testers.
Lastly, right before Christmas, I replaced a bathroom faucet with this Ridgid tool (purchased a while ago, just trying it for the first time), blows basin wrenches away!
Mike
BrandonV
Arizona
Their website layout is frighteningly similar to HF.
Farmall450
Marengo, Illinois
They send a lot of the farming channels free stuff, but they seem to mostly provide low quality Chinese stuff. I bought a drum dolly (because it was cheap) and yeah, it *****.
saltwater4life
Noticed the box had been retaped, then saw loose hardware out of the bag. Then a super small crack in the wheel. Turned it on to see if it would grenade. And of course it did lol.
Also bought the 12 amp Hercules router and it’s a beast. Super happy with it.
bbrins
MD
The Rover light and Power Probe test leads were Christmas gifts. I already have another Testo multimeter like this one, I just got this one so I would have the same one in each of my work trucks. The little Owon clamp meter, I got to replace a missing Uni-T UT210e, no idea if it is any good.
threewood
Yuma, AZ
Brand new Williams 3/8" JHWWSB-13RC Superchrome 12 pt set. I already have the long set, found a 12 point bolt where the long won't work (60's Mopar steering box mount bolts) so I got this set. Made in USA.
One oddity, there is an extra 1/2" socket in its own bag. Taiwan, and has 4 relief holes drilled for the ratchet ball retainer. Never seen one drilled.
20231228_104549.jpg20231228_104605.jpg20231228_104610.jpg20231228_104617.jpg20231228_104720.jpg
dscheidt
the TH suffix stands for tools at height. the matching ratchet or power driver has a spring loaded pin that engages the hole, and requires a tool to poke the pin in so it can be removed. some impact wrenches are like this, which keeps the socket from flying across the shop when it's spun fast in free space, which is why most impact sockets have a hole in their side. four holes means you don't have to pay attention to which way it goes on...
Squankum
Southeast
Finally got my Wright wrenches that I ordered back on July 31. The 1/4 wrench was back ordered and held up the shipment. Got 6mm through 32mm and 1/4 through 1 1/4. These things definitely have some heft. First thing I've imported that didn't have duty. Much nicer than Gray Canada and half the price.
Jack Nicholson nods approvingly!
Mr. Roboto
New Hampshire
2 more GW arrivals…. Hose pinch off pliers (I’ve only ever had the cheap plastic ones) and another style of hose clamp pliers. I kind of regret the hose clamp pliers before even using them. The heads of the jaws are so tiny that I think it will only work on very small hose diameter clamps… but we shall see. IMG_4793.jpeg
89MustangGX
Stanwood, WA
If you have doubts about those hose clamp pliers, I recommend looking into the Blue Point HCP9. They are USA made and about $30. I have been very pleased with them. Not sure who the OEM is for them, but that could be a way to get them even cheaper if someone knows. Otherwise, if you don't have access to a SO truck the shipping stings a little, but they are a nice set of pliers.
designer485
Orange County, CA
CAT 8T9293 (Same as the older Snap-On TQFR250, other than the head) 1/2" 40-250 ft/lb torque wrench. Gently Used.
Along with my other Precision Instruments based torque wrenches.
WeatherTech Tool Trays
Snap-On Mini Tool Box Set (Roll Cab, Mid Box, Side Box, Top Box) in White / Black to match my main toolboxes.
Southwire Red, White and Blue (Made in the USA) 12/3 Extension Cord
LXCam
Bought my guys a new toy. None of them have enough *** to bend 1” emt without rolling it let alone rigid and the next project has thousands of feet of both to run.
And it runs off of a power threader head.
And thank ya zoro, that 20%’r was a nice save 😉
M6erfan
'Merica!
Right. I honestly don't care for the Milwaukee EXC tip. Not enough engagement IME. The Wiha's I linked to are better, IMHO. Honestly I think that the simple Robertson is the best tip for those jobs.
Wamsutta
Amarillo, Texas
You know I was looking at that. Those holes look too big to be for a friction ball retainer. Have you tried it yet?
threewood
Yuma, AZ
As Dscheidt mentioned above, it is the Tools at Height version. Tools that require attachment that come loose and bang someone in the head. There are TH ratchets with attachments and it looks like the holes lock in the socket when attached.
I haven't tried it yet, been sick.
Wamsutta
Amarillo, Texas
You mean the holes for a pin-lock square drive right? That makes sense, it's just that I've never seen retention holes that big, unless your camera is playing tricks on me. Look at these Cornwell sockets; that's what I'm used to seeing.
Jr5
Triplett multimeter test lead set to accompany my Fluke (some items pictured I already had and added to the kit)
Nice quality 4’ leads with interchangeable test tips. 17 bucks from Lowe’s online.
