Show your new tool arrivals
Stubby1743
UK
During the last couple of weeks.
Small Trusco steel box; Anex PH2 stainless steel driver with glow in dark handle (for my nephew's new boat); Vessel micro driver set; Engineer DM-20 micro PH drivers #0000 to #1; KTC black plastic bit holder. All from Amazon Japan.
Wera metric 1/4" drive sockets and Titan swivel head bit driver with #1 and #2 stubby bits from Amazon UK (the Titan driver was shipped from the USA).
In the KTC bit holder, the top two bits are the weird ones for some games consuls (not sure what they are properly called). The third bit is an adaptor to hold the micro bits for use the 1/42 hex drivers. The bottom one is a Vessel 1/4" hex to 1/4" sq. adaptor.
SC Fly Guy
Aiken, SC & Lakewood, NY
Buying several pair at once, I could pay $5.50/pair for the snap on socks. I've since moved on to Samsox, USA made, available on Amazon. They're about $15/pair though.
Snap on socks when new are great, but they seem to lose thread volume too easily and lose the inherent "plumpness" of the material.
If you want quality, made in the USA socks, I would suggest that you look at Darn Tough socks. Made in Vermont and unconditionally guaranteed for life. They’re $15-20 /pair (or more), but they hold up well and the guarantee is a no questions asked return through my local retailer. As a guy who spends a lot of time outside, I take a ‘feet first’ approach … quality boots and socks are paramount!!
$5.99 each at O'Reilly's Auto Parts
UltraSteel UC1202TA (1/4F x 3/8M)
UltraSteel UC1203TA (3/8F x 1/2M)
(telescoping magnetic back scratcher also $5.99) ;)
shakenfake
Shlumpt, TX
I've been eyeing this Astro wireless charging work light for a while, finally pulled the trigger.
The empty slot on the charge is just taunting me to buy a 2nd now!
Can the other spot charge a phone? Is the magnet good enough to hold it? That’s the main reason I was looking at the Matco ProCharge line. I can find it in Europe for cheaper than Matco but not in the US.
Smokeshow69
Thanks for the info. Will only be for inside home use when my feet are cold. I rarely wear socks at home. It doesn't get cold here much which is really not even cold so only a few months a year I might wear them.
I probably won't buy another pair, I'm too cheap when it comes to things like this.
Since you are taking sock recommendations - thorlos on Amazon are my go to brand. Made in usa with various levels of cushion depending on what you select. The “tennis cushion “ ones are my favorites
ForrestT
Waldo
Finally got around to ordering this for Christmas with some Christmas gift money. Highly recommend. Both trailer tires within .1 psi and I didn’t fool with evening them out perfectly. Truck is next.
Steve_P
I've said this a lot here, but merino wool is the best material for socks- and the most expensive. Wool is naturally anti-microbial- it doesn't stink nearly as bad as cotton or synthetic when you sweat; and merino wool is soft and comfy- not your father's wool. I wore synthetic Thorlo socks for hiking for several years until I finally decided to listen to the smartwool fan club; and they were 110% correct. If you don't want to spend the $$ for Smartwool, then find something with equivalent wool content on Amazon.
Madjik Man
Merino wool is the only way to go.
I have several pairs of boxer briefs made from merino wool. Started off as my backpacking pairs only. But slowly buying more and replacing my regular every day ones.
joel63
Central FL
It’s been a long time since the caged incandescent light bulb on a long cord was the light of choice in the automotive field. When the neck lights came out I didn’t think very much of them. Just wasn’t a big fan.
Since the wife has spent some time on occasion holding lights for me on various projects,
she thought it would be a cool idea. Well, lo and behold, after trying it out on a few jobs, I’m convinced, this
Is the way to go.
Thank you wife.
bpwoodworking
Picked up a mountz torque screwdriver. I have a few of these and find them to be excellent. I set them up for various common tasks where inch lb torque is critical, such as installing carbide inserts or setting scope rings.
This one has a range up to 120inch lbs and is considered a clean room version. I didn’t need the clean room aspect to it, and likely ruined that aspect of it immediately upon opening it, but it came at the right price.
PiperCub49
Norfolk, VA
Without asking you too personal of a question, how do you like the underwear? Big difference compared to cotton?
Madjik Man
Huge (no pun intended)
So much more breathable and without getting to gnarly… when the boys are hot and bothered the moisture wicking/drying is superior.
I’d only have merino wool underwear if it wasn’t so expensive.
darkzero
SoCal
Is the way to go.
Yep me too, didn't care for them. Started a new job last year, almost everyone wears them. So I thought ok I'll try one but I ain't spending no $100 on one. I bought the EZ-RED on Amazon for $37, which I hear makes em for Snap-on anyway. But the EZ-RED aren't deattachable & still use micro-usb plugs.
All of my coworkers that have em have at least 2 of them to get them through the day. So I ordered one from our Snap-on guy. That was months ago. On of my coworkers left the company a month ago & I inherited his Snap-on neck light. Then the one I ordered finally came in this past Friday. So this new one I guess I will keep/use at home.
I do like the Snap-on better but The EZ-RED stays on my head better when I wear them above my ears & I'm laying on the ground under a car or under the dash. So I'm keeping the EZ-RED at work as my backup.
The Snap-on the pivot gets loose over time. Even when new they have side to side play. But I have a fix for that. The EZ-RED doesn't have this problem, at least mine haven't.
darkzero
SoCal
Ran into a tight situation the other day at work & could of used a bit ratchet with thumb wheel or a finger bit holder. So I bought both to have.
Williams 1/4" hex & square ratcheting wrench & a Craftsman finger bit holder thing.
I noticed it said 5/16 on the square drive side & I was wondering why. Then I noticed it said 5/16 bit on the wheel. Ah, it's a removable bit that's pretty cool. I don't have any 5/16 bits anyways besides the ones that my impact driver (handheld Lisle) uses. Last month stupid me not paying attention bought a 1/4 power bit holder that had a 5/16 shank. I could use it with this so not a totally useless but I don't ever see why/when I would. But whatever, I really like this wrench.
RANT time: I have no interest in any SB&D Craftsman, will only buy if I have no other choice which is not often (same for Apex Tool group).
So the SB&D Craftsman finger bit holder, what a joke, wish I still had more of the Sears Craftsman ones left. They couldn't even laser on the logo some what straight? Doesn't affect functionality & it's a low dollar item but really? At first I thought it was funny, then disappointing, then it pissed me off, enough to open up a return. Well Amazon ended up refunding me but let me keep the item.
"Proudly made in the USA", ****, they should be ashamed! :lol::rant:
rharman
SoCal
Ordered these today. Woodpeckers Fat Head ruler set w/rack - 6", 12", 18". They had a 1-day sale.
I've had my eye on these since they came out 4 years ago but never pulled the trigger - until tonight.
They're backordered about 2 weeks.
I like Woodpeckers' stuff but, dang, they're not a cheap date!
@SC Fly Guy -
I just got back from Home Depot and they had nothing like that.
Closest they had was a set containing about 40 or so pieces that was $19.97
I looked up and down all the racks of "bits" - nada.
Did find a new 1" spade bit, though.
lardy1
New to me Blackhawk goodies from the local auction house. I couldn't resist the price. The magnetic bit holder still has the original bits with it.
SC Fly Guy
@SC Fly Guy -
I actually went back and got another for my son. I think it may have been the last one and was actually locked in one of the cages? It’s surprising that the clearance deals vary so greatly among HD stores. It’s showing up at $39.97 on the HD website.
If you have access to more than one HD, you may want to check around. I’d offer to go back and try to find more, but the shipping costs would likely defeat any savings.
mikeinri
Dang!! Not sure why my store was blowing them out?!?
I can't figure HD out. Seems like only people who have worked there can make any sense of it.
The HD site says there are none in any nearby stores, but says there are over 3,000 units available to ship here at full price ($39.**).
The BS site shows some (one store with 16, a handful of others with the dreaded "Limited Supply") in a few stores, lists them as "Clearance" without a price. Not worth my time or gas money, based on experiences chasing similar ghosts over the past few years.
Mike
SC Fly Guy
Mike
Amen to that!! I’m in the plaza that houses HD several times a week and I make a quick walk through. Like you, I’ve chased the ghosts of Milwaukee, Klein, Knipex, etc. close outs to the point of frustration too often. Now, I walk around looking for the yellow tags and if I see something, I grab it!!
Squankum
Southeast
Today's wool doesn't have the itch, folks! Give it a try! Between sheep breeding and fiber processing, the itch is gone, leaving only wicking and warmth and also coziness/temp regulation.
The most expensive wool: yak.
Then comes American buffalo, which I have a few socks in, not cheap, but outstanding socks.
https://thebuffalowoolco.com/
After that, merino baa-sheep wool -- Darn Tough, SmartWool, REI and LLB house brands, they're all good. For years at my desk job I wore SmartWool liner socks like they were black dress socks, all year round. Very thin and very durable.
Also a really versatile piece of gear for cool and cold weather: base layer. Sale time is upon us and prices maybe dropping.
This can be the base layer under many layers in heavy winter conditions, or it can just be a shirt for cool weather, or you can wear it for work/workouts in cool weather. People who try these tend to love them and wear them for years.
Meursault74
Southern California
Did you hear about that shepherd giving his flock iron supplements with their feed?
He was trying to expand into the steel wool market.
mikegt4
sw ohio
And a new catalog. Never been so excited to get a catalog before (well except the time I got the 1st one). But whatever the excitement only lasted a few minutes and I'll probably never use the catalog anyway. Will just sit on the shelf with the other one.
Back in the mid 2000's my boss would receive a new issue McM catalog as they came out and he would routinely throw the old (last issue) book in the trash. I saw him do that one day and told him that people would kill for one of those. He looked at me with a perplexed face so I told him to do a search on E-bay for McM catalog. About 5 minute's later he was pulling it back out of the trash. IIRC he got about $60 for his old one.
