Show your new tool arrivals
shibertus
Where did you get the Lang pocket pry bars? I haven't seen them on Amazon. Only seen them rebranded on the Matco truck.
LeeG
Phoenix, AZ
Over the past few years, I've been supplementing my standard Hansen carbon steel tap/die set with HSS versions from McMaster or MSC. I've got most of the SAE sizes in UNC and UNF. Expanded the top size to 1". At nearly $100 each, I'm not buying the 3 tap set in this size.
I also added to my metric collection.
I have a few older tools to restore, and they have some pretty stuck fasteners, so I added this hand impact driver to my collection, along with some other bit sizes and some standard impact driver style straight bits.
Lee
Steve_P
Too bad that with shipping they are only a few dollars off the Matco truck.
A bit cheaper from Epstein's, but I'd have to buy something else to make that shipping cost worth it.
I have the Lang two piece set. I can't remember where I bought it, maybe Jersey Discount Tools? If not, probably Epstein's with some other stuff.
MWEric
Wyoming, MN
On the road for work. I had to order a 3/4”dr. 17mm hex socket. Got this Wright from McMaster. Not sure how well the new (ie: round) shank will hold up vs. the older hex, I guess I will find out this week. Got a bunch of bolts to torque to 500ish lbs/ft.
Buckgnarly
VT
How is that bit secured in the socket if it's round?
shakenfake
Shlumpt, TX
Picked up a seemingly unused T72 Snap-On 1/4" ratchet.
Purchased a Mac 5.5mm socket off eBay, was decently used but no red flags. Showed up cracked and with owner markings. Went to return it and seller just refunded and said keep it. Free 5.5mm socket that I'll warranty.
Meursault74
Southern California
Purchased a Mac 5.5mm socket off eBay, was decently used but no worries. Showed up cracked and with owner markings. Went to return it and seller just refunded and said keep it. Free 5.5mm socket that I'll warranty.
You've been hanging out with @BlakeTheCarGuy ? That's his warranty move :ROFLMAO:
Squankum
Southeast
After seeing this 90 degree gearless drive mentioned here on GJ, I had to check it out for myself. Don't know if I'll ever use them but fascinating tools nonetheless.
The 1/4" version needed lubricant and still doesn't rotate as freely as the 3/8" version. They also make a 45 degree version.
Ordered via Amazon: CalVan 90 Degree Gearless Drive
And if you didn't see it before, here's how it works: YouTube Demo
Another tool for tight quarters like that is the FACOM rotator ratchet:
I got one. and like all FACOM, it's well built, but the one time I really was in a somewhat tight spot and wanted to put it to use, I needed to put my other hand up in there to steady it (I think I had deep socket on it) and well, trying to fit two hands up in there, if I had that kind of room, well, you know, a regular ratchet...
But sure, someday it might save the day!
Dh3256
Unfortunately the warranty is only for the original purchaser, so you don't have a warranty on a resold tool
BobsYourUncle69
Westchester New York
This I got a while ago and never really posted it here as I didn't think it worth tge mention but it's since become the 1st screw driver I pick up now and it inspires as much confidence as my US made SK , US made Stanley and Klein screw drivers. Quality has far exceeded my expectations for a $5.99 screw driver. I've destroyed "better "screw drivers doing less.
While I was pleasantly surprised I think this highlights the problem of consistency with these HD and lowes brands as one never knows what they'll get as my other set of husky screw drivers was absolutely horrid that I bought on the same day. Same name on the box , vast difference in quality.
One can watch a YouTube channel like project farms but ive found that a 2 year review is outdated as they keep changing countries of manufacturer etc and for example the craftsman screw drivers he reviewed 2 years ago as made in Taiwan and scroing very high are now made in China or India etc and are essectialy a different product , and in Craftsmans case , a different product with the same model number as are the wrenches etc.
I'm not bashing anyone on country of manufacture but rather lack of consistency.
captain14
I usually pick those up those whenever they are on sale. They were one of the extended BF deals. One for the shed, garage, drawer and tool bags.
And two different sizes of nut drivers.
decableguy2000
I want to know how you crack a socket on a bolt that small with out snapping the bolt.
Fedwrench
Valley of the sun
New astro 78113 13-piece 1/4 drive low profile Nano metric impact socket set on a nice aluminum rail. Sizes run, 4, 5, 5.5-15mm. Gold sizes marking & stamped size markings on each socket. 18.5 mm overall length. 1/4 square drive inside an 11 mm hex so, you can use the 11mm ratcheting tool of your choice for a lower profile version. VIM RW1113 for example, the USAG 237FK flex head ratchet, or any USAG/FACOM/OEM tools ratcheting wrench with the retaining wire in the ratcheting boxed end. CR-MO. :beer:
shakenfake
Shlumpt, TX
I bet they snapped the hell out of that bolt.
That fraud is on your conscience then, but if people keep doing that they will start requiring receipts or limiting warranties like so many companies have had to do because of this kind of fraud.
Edit: OMG noooo SB&D is gonna lose $20 that would have been lost if the original owner warrantied it omgomgomg noooooooooo
