Show your new tool arrivals
Squankum
Southeast
That's stupid. There's only 6 lights but it's a 7 pin connector. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . yes i know it's the ground
My Uncle Chris was an astronaut and he could diagnose anything electrical and he only had two lights!
NUTTSGT
Northern Central Ohio
What is this enclosed trailer being used for that you would need sockets?
. . . enclosed race trailer. . . .
If you're bored.
A little grease always helps.
Hmmm... not the place for it, really. That kit is designed for "clean" work - electronics, cell phones, cameras, and such.
My buddy needs to get inside a surveillance camera - the unit is only about the size of a tennis ball.
Unfortunately, the tiny "Torx" head screws are recessed down in a hole, and the bits in that set are about a quarter-of-an-inch shy of being able to engage the head of the screw, so he's going to need something along the line of a "long reach" bit - in a teeny-tiny size.
Not even sure if something like that is made. It would have to be a smaller drive size (like the 4mm drive bits in that kit) because the size of the hole won't allow for the standard 1/4" hex bits which are more common.
My comment about the zipper was because... there are zippers, and there are zippers.
I have zippers on outdoor equipment that have lasted for years and years and years and years without problems, and I've had zippers fail.
Cost me $80 bucks to get the zipper replaced on my day pack. I'd be lucky to even find anyone to do the work these days.
Replacing the zipper on that little kit would be a non-starter. Ergo: I'm hoping they are using a good-quality zipper.
mikeinri
I hear you on the zippers. I have a sewing machine (no clue how to use it, but willing to learn). Unfortunately, I haven't found a YouTube video showing how to replace a zipper.
My mother was a sewing freak, even made a wedding dress for my oldest cousin. But, she despised working with zippers.
And you're right, finding a professional (or even an amateur with a side hustle) seamstress isn't as easy as it used to be, either.
BTW, do any of you have GOOD suggestions on how to free a stuck zipper on something that's been exposed to salt?
Mike
Professor Gascan
Mike
I freed up a frozen zipper with a few drops of wd40. After I got it moving I rubbed some candle wax on the teeth and worked it until it was smooth again.
Beerhippie
Far NE Oregon
Someone put those tiny fasteners in there--so the tool exists.
For zippers, I use a light application of silicone spray lube--put it on a cloth and rub into the zipper teeth.
BobsYourUncle69
Westchester New York
I haven't a clue why i bought this. It seemed like a good idea at the time
Gedore 1B 50mm , Ive included a 25mm for size comparison. Thought it would be something nice to hang on the wall, I'm not likely to ever use it unless I want to start pulling subway stations apart.
Etchase
Hawaii
Cheaper than a lot of art work and inspiring in its own way.
dscheidt
wax is the usual lubricant for zippers. You can buy special zipper lubricant, but a candle, a block of beeswax or gulf paraffin wax work just about as well.
There are some longer 4mm bits, but an actual screwdriver is usually a better choice. ifixit sell a number of them in tiny sizes, probably including the ones you need.
Ohio Andy
Columbus, Ohio
I remember correctly the iFixit set has gray lettering with a black background and I found it difficult to read on my set from. I fix it. Everything seems nice, just hard to read, but I have the bits, not the individual drivers.
I considered buying the t1 on the t2 bits but decided to stick with just the bits.
Squankum
Southeast
I"m not sure if there was a misunderstanding here. I was suggesting greasing the zipper, and gave an Amazon link to a small grease stick that is good for zippers, windows in old houses, etc. It doesn't take much, and it gives struggling zippers or perhaps cheap zippers a better chance at functioning well. Others have since chimed in with other good zipper lubes.
I'd never thought of it until I bought that grease stick for some very old house windows, read the packaging. Would love to do the sleeping bags' zippers, but I don't know what it means to a bear's nose.
Fedwrench
Valley of the sun
Astro Greatness in the form of their 78105 1/4 5 piece NANO drive size adapter set and their 78305 3/8 drive 5 piece NANO drive adapter set. These are great little sets that will enhance the capabilities of your NANO socket ratchets and drive tools. The 1/4 drive set includes: a 1/4 hex magnetic bit holding socket, a 1/4 square drive male, a 3/8 square drive male, a 1/4 square wobble plus, and a 1/2 drive male. All NANO adapters feature 1/4 square drive or the 11mm hex base. Gives you a very wide range of options for the VIM FRW11, or any of the other 11 mm dual drive/NANO drive tools with a very low profile tool. The 78305 set offers you the same adapters in 3/8 drive or 17mm hex base. Both sets come on a nice aluminum rail. Now, if only Astro would release the 78320 NANO hex/torx/triple square bit set, I would be NANO complete. :lol: :beer:
Squankum
Southeast
Got a #2 Philllips stubby by Stanley for my road bag. My old Wiha for comparison. The Wiha's about 3mm fatter in the handle but I can't complain, the Stanley is equally grippy.
I couldn't find any COO so I can't say it's FACOM/Bost made in Fronce. Tip does have some coating, the rest of my new Stanleys were blasted but are otherwise slippery/chromey.
$10ish Amazon.
cody1325
Southwest Virginia
Honestly, that's most of my old Williams wrenches, save for two '50s Superrenches I cleaned up and put in my box as regular-use wrenches. They're so old, they're USS sizes (not across-the flats). As I understand, they came off the railroad, and were likely used on old steam engines of the era.
The only one I use is a "7/8" (USS, so actually more than 1") spud-type wrench. I use the spud end to align bolt holes or stuff I slide pins into.
Heck, the last time I recall even dragging out a wrench over 1" was when I dragged out my 1 1/8 to remove the hitch ball from the UTV to replace it with a hook.
spyerx
SoCal
Couldn’t resist the truck while at the shop i use for my old cars…. These are the best ratcheting screwdrivers and i have a lot of them (pb Swiss Klein etc). The hard handle is older and had that a while. I use these with PB Swiss bits.
These icon copies of the snap on are way nicer than the $20 indicate. One tool vs 2 or 3 now (especially for smaller wires).
