Show your new tool arrivals
pfbz
I have this one, been working great. Made in the USA. At least mine is. Jb tools has a good price on it right now.
CTA Tools 8240 53pc Universal Rethreading Set | JB Tools https://share.google/tVYYHkuuBpj5VZfBD
Lang rebrand I believe
I also recently picked up one... Lang set from Zoro. If you can score one of their fairly ubiquitous 20% off coupons, an even better deal. $138 -20% = $110, free shipping.
Honestly I've always used my tap and die set for rethreading, and haven't had a chance to try the Lang yet, but figured for ~$100 I could step up to a proper re-threader, especially a top quality one.
Steve_P
A buddy is selling up as he starts thinking about retiring, so I went over with cash:
The tech angle and 3/4” ratchet were the two items I specifically wanted, both freshly refurbished by SO. The other bits were a little more impulsive but I think they look handy. The only bit I’m not sure on is the ratchet wrenches, they’re not a tool I use often.
What is the set in the red case on the upper RH of the pic? Some sort of specialty drill guide set?
moemc
A new Rennsteig PEW12 joins its brothers in the automotive wiring hand tool cart. This one with metricpack 280 dies. Not my personal taste in connectors, but sometimes you have to work with what the OEM used.
F-22
The ten inch seems to be most versatile.
I have an older pair with the smooth dip coated handles. Don’t like the new dip coated ones with the rough texture, so I would go for the comfort grips on any new purchase!
Of course depends on what you need, but I find the capacity of the 7 inch (180mm) really good. Big enough to give some decent leverage but small enough to slip in the pocket. In a production automation setting, I find the need to snug up big nuts to a light torque quite often (especially various induction/laser/capacitive sensors have these big thin nuts of random sizes where a big regular wrench feels awkward to use...). I use them all the time and can forget they're in my pocket when I don't need them. But the 10 inch is not a tool most people would get in a pocket.
ETJ
TQFRN350E (60-350Nm)
Snap-on BF636 vertical chisel shrinking hammer (aka Martin 154SFG in disguise). I am not fan of waffle iron faced shrinking hammers, but I like the vertical chisel and it was cheap.
unused older version heavy duty die grinder.
and another 9R.
RMERR
Northern CA
I already own a tap / die set. How is a thread chaser / rethread tool different (better?) enough to warrant the extra purchase?
I do have split dies, which DEFINITELY help (you can put it behind damaged threads at the end of a fastener / spindle.
But, why do I want / need a different type of tap?
Mike
I kinda wondered the same thing Mike. But what I decided I liked was the hex heads/shape. My tap and die holders are T-handles, in limited access or with nearby obstructions there sometimes isn't room for a T-handle. With these, I can use sockets/ratchets with extensions and T-handles to get to the hole and clean up a bad thread. I have a few, but don't have a complete set of bottom taps, so in blind or shallow holes with obstructions behind these could also help.
These come up for me on occasion, but I can imagine these may never come up for others.
Snapped-off
Indiana
Picked up a long neck ¼" ratchet to add to my 14v set. It's an older model, CTR717. Only cost $100. (It was a trade-in)
Also got a Simpson 4200psi 4gpm pressure washer with a Cat pump and the big Thai Honda GX390.
Not pictured is a new Toro 21" Recycler push mower. Non self propelled, cheapest one they sell. I killed my $20 Troy-Bilt on a stump, shearing the flywheel key last week.
I'll probably set it out front. I've been waiting for it to die for the past 5-6 years. I wanted to replace it with a Honda, but there's none left around here.
WWheeler
Middleofnowhere USA
Solary H7 Induction heater w/ 8 coils, and an additional 8 coil accessory set. I wanted the same induction heater with 10 coils, which came with two of the flat coils that didn't come with this one, but they wanted $37 more for it ($143 vs $180), and an accessory set of 8 coils including one of the flat coils was $38, so didn't have to think about that for too long.
moemc
I was sleeping on the Cobra ES, but after seeing the update to the twin grip style jaws, I wanted to order a set of the 250s before the revision saturated inventories. Not to say that I don’t like the new jaw, but just that I feel I will like these with flat tip jaws in some applications. Now that it’s here in my hand, I feel like I was missing out and might have used these over standard Cobras in most uses. Like if I could only have 1 Cobra, Im thinking these would be the choice. The longer tips is going to widen the use scope in engine bays.
While I’m here I wanted to show a set of “channel lock” with cobra style adjustment button that I use every day and why. A couple years ago I saw this Husky that has the peak of a serration at the end tip of the lower jaw. Its the perfect tool for popping the back cover off these plastic electrical connectors I handle daily. A light duty job that I literally used my teeth on for years. I dreamed of having a pliers to do this exact task quickly for me, and saw it in the store and had to have it. Ya I could have ground some standard channel locks down but for whatever reason it didn’t occur to me exactly what I needed until I saw it.
Squankum
Southeast
I have 7" and 10" and am happy with them. Smaller than 7" kind of vanishes in my large hand.
(Same with Cobras, 7" and 10". I also have the foot-long Cobras and at least for the work I do, they hardly ever come up.)
Lisle 13120
^ Just ordered one for my buddy from O'Reilly's.
$12 bucks.
He called me yesterday.
Said "Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! and Thank you!!"
I was a bit confused so I asked "What's this all about?"
"You remember that goofy screwball pair of pliers you gave me a few months back?"
"uhhhhh... yeah?"
"You just saved my bacon on this job."
Every single time I give him some screwball "electrical connection tool" I get the same phone call about 6 months later. Every time!
Squankum
Southeast
Mike
The impression I get (and I have the Craftsman/Kastar set) is that these aren't built to cut new threads or be really sharp and dig into metal. They're mean to clean dirt out of existing threads, or maybe bully some damaged threads back into position, but no much the sharp toothed cutting or cleaning of threads. See also, spark plug thread chasers. Not super sharp, meant to get existing threads clean and on the right track, but not cutting into the metal .
olsenmotorsports
Chicago, IL
You have room for one more!
HILARIOUS 😂
I was talking about that the other day, it is a 68x30” drawer so it is fairly large, I could move a few rows around and and make more room, but seriously this is getting out of hand. Time to purge. Like antenna sockets - haven’t used them in probably 15 years, same with the. Weatherhead once in a blue moon when I am doing plumbing work…. I NEED probably a 1/4 of this stuff but it’s 25 years of acquiring the right bits of kit and I like having options available.
Just when I think I’m done, i get bored and jump on here and hang out with you assholes and I just cant control myself
Last couple years I hardly even work on cars! Ridiculous!
wandrur
Fredericksburg, VA
ChefRex
HILARIOUS 😂
I'm glad my same drawer isn't that full of sockets,
or am I?
