Show your new tool arrivals
lund
this is probably also an example of snap-on prices not necessarily being because they are the best tools but because they have factored in their warranty and business model.
yes, you are paying for a good tool, but you are also paying for services you may not want, may not have available or may not apply to your needs.
For sure. I can see where Snap On makes good sense to pro auto shops that are regularly visited by a tool truck. But for DIY me doing long flurries of work late at night and weekends, it does not make sense to pay that premium ... especially with some high end tools like the models shown in this example likely being higher quality at only a fraction of the cost. I do not need to pay for a warranty or pro advice (i.e., tool truck guy that I presume knows the craft and what works) that I will never cash in.
Jarhead0408
Who knows?
Decided to finally pick these push/pull spring tools up after the last leaking wheel cylinder I replaced.
Picked these up from the Zon (Edit: eBay actually.) to pop CV axles out. They look like they could be useful, but best to use with caution so you don't crack a transmission housing.
The ones on the left offer more positions to put the ratchet or breaker bar in.
Next up are two Tekton 3/4 12 point sockets to help fill a pegboard display up. And a Tekton 1/2 T55 impact socket that is replacing a similar HF socket that broke tightening the rear crossmember on a Peterbilt. I also picked up this Diehard low profile set based on another members recommendation. The 11mm ratcheting wrench will fit the 1/4 Astro Nano sockets as well.
Snagged a set of HF Icon pliers. I think some folks use them to grip broken screws like the Vampliers do. I bought them because you can never have too many types of pliers. I also picked up two sets of sockets from Tekton. While installing a +4 quart 4L80E pan from Mag-Hytec I found that my 3/8 metric allen set came a little too close to the pan. So, a set of 1/4 should buy a little more room. And to get around the heatshield near the rear of the pan, a full set of metric and standard long ball allens. As little as I use ball allens, much less regular allens, I decided not to buy GripEdge, Snap On, or Bondhus. These will be fine to run down and then I'll get inventive to torque to spec.
And...thanks to my son running the torque wrench below minimum spec...I decided to pick up this HF 3/8 torque adapter as a way to check the torque without having to sent the torque wrench to Angle Repair up in Beckley, W.Va.
Last but not least, I picked up two different rolling seats from HF. They're both nice, but if you can afford the Vypers get them haha. The little 3 drawer job is actually pretty nice. The big red seat is okay too, but the wheels seems to have a lot of drag to them. Maybe I can lube them up better?
Jarhead0408
Who knows?
@Jarhead0408
Quite a haul John 👍. Hey were did you get those pry tools at. You said Zon, but what is that? Those would be really handy for something we do on slider door adjustments.
Thanks bud.
@LXCam
Anytime. Man, I've been meaning to send you a message with a few tool recommendations that I think you might find useful, but I've got to find the video again.
Yep. Quite a bit this time. I rarely have time to post what I buy. Usually it goes straight to use or straight to the toolbox. By the time I get back each week there's a decent pile of boxes that have come in and my wife is ready to see them move along haha.
Sorry, I thought I bought them from (Ama)zon, but it turns out it was from eBay. No idea whether there's much difference in this versus other offerings, but 6 versions across 3 drive sizes seemed interesting. Here's the link: https://www.ebay.com/itm/389452754545
Jarhead0408
Who knows?
Thank ya brother. 🍻
I’m gonna get a set and see if it’ll do what we need.
You're welcome. I hope it works out for you. Let me know if it does. Bonus points if you can get away with snapping a photo or two so I can understand the application of the tool here.
I thought they were gimmicky at first, but eventually I recognized the utility of them.
mikeinri
I also saw this open box 3/8 drive ICON Metric impact socket set on 35% markdown. The end of the box was ripped but the set looked complete. They let me examine the set and the sockets were brand new and still covered in shipping (anti corrosion) oil. The set appeared to be complete so I pulled the trigger.
They don't play like that around here, unfortunately. Whoever is in charge of discounting open box items follows a strict percentage calculation.
If a 10-piece set is missing one tool, it's priced 10% off. Two tools missing, 20% off. Makes zero difference if the largest tool (highest value) is missing.
I'm pretty sure I've seen open boxed items priced at full price, or like $1 off, even if clearly used and dirty. Ridiculous.
Mike
LXCam
I had trouble figuring them out, then I remembered YouTube probably knows...
[This one was all but useless...]
Mike
John, that second video is exactly what I envisioned and need.
Thanks to you both 👍
51dueller
Saskatchewan
I thought I was done buying sockets for a while but I had to find out there were Matco 1/4 dual drive sockets from a thread here. Even the Matco dealer didn't know about them yet. This time Matco added a 4.5mm, 16mm and 17mm which the Astro version doesn't include. I will say if they come out with 1/2 drive, I won't be buying them as I can't fit them in my socket drawer unless Ernst comes out with a 4 rail socket boss tray....
Hakeem
Chicago
The 32 (it actually measures 33). I was going to get the 40 but it was damaged :(
I think the 32” is the better choice. The 40” is so big as to be unwieldy. They list it as a cart but it’s essentially a roll cab with a flip top.
Congrats on your acquisition, and be sure to post some pictures when you’ve got it filled!
neophyte
Pennsylvannia
Knipex made in Taiwan…. Did I get a fake or something ? Bought from Amazon IMG_1410.jpegIMG_1411.jpeg
One of the major manufacturers of that type of scissor/shear, is located in Taiwan, and manufactures similar shears for a number of different brands.
As Knipex manufactures numerous tools for electrical wiring, they likely wanted to offer a functional scissor/shear to their customers under the Knipex brand.
Knipex may have designed the handles.
This is not uncommon.
Knipex uses Jokari to manufacture some of their wire strippers and tools.
rword
Thanks for the info. Still deciding whether to keep. I didn't need but Amazon had for $25 so I got lol. Was expecting Germany or another European country so just was thrown off by Taiwan. I have many Taiwan tools but had never seen Knipex Taiwan.
T45
Immitation is the sincerest form of flattery, and the HF knockoff of that is really pretty decent
{originally wrote that applying to the 6drawer snap-on 32 in cart, only to see its applicable to the knipex scissors, too}
what a time to be alive...:LOL::ROFLMAO:
Jeffrey D
Christiana, TN
Jeff,
Do you have a link to where you got it from? Is it magnetic?
Did you try it? Is it too gimmicky or moderately so?
Thank you.
I have not tried it yet, but it seems well built. It is magnetic but also has the locking collar and holds the bit firmly.
I don't think it is gimmicky and can see situations where it will be useful. Again, I haven't used it yet, but I'm happy with the purchase so far. The second collar locks it to act as a regular extension.
Here is the link to where I found them.
rust in the eye
Chicagoland
I’ve gotten a lot of mileage out of these small pliers, but I’ve often found myself wanting for cutters to make a quick cut here or there. Enter these 4” cutters from Snapon:
Placed next to my fastback for reference. Haven’t really used them yet but they fit in my cargo pocket without me noticing their presence, which is what i was looking for. Just wish they were offered in a bare steel handle like the pliers ….
A soak in hot water might allow you to remove the handles without damage in case you want to put them back.
Beerhippie
Far NE Oregon
Safety Siphon for fuel transfers from Gerry can to tank.
Now I need to find out if my old Gerry cans (US style, not real Gerry cans) still hold fuel. They've been sitting in a dirt-floor garage for a few years.
I'd like to have a couple more of the 10L NATO style cans like the German Army Sandrik one I picked up at a YS a while back
for $15, but that's a tenth the cost (ten times cheaper for the youngs) of a new one!
Two little cans would be much easier to carry up the ladder to the roof rack than one big one. I may have to build a jib crane to mount to the roof rack for things like that.
rust in the eye
Chicagoland
I was at farm and fleet and happened to come by this in the automotive section. Kind of a impulse buy but I think I can make use with this.
Those are very useful BUT don't stick those ear pieces into your ears, resting in the bit behind the earholes will do.
Not listening for heartbeats here. You'll soon learn what I mean.
