Show your new tool arrivals
wire
Just got this set at a super price:
Didn't realize there were so many bad reviews when I ordered. $13 for this set that is usually $50 or more. Came quick, nicely packaged, perfect condition. He had 11 left when I ordered mine.
I'm sure those will be fine. The only real complaint about them was not fitting in tight spaces. I bought this set a few years back for $8.64. Also got a E-Star Wrench Set $11.52. I haven't needed to use them much but when you do there are few substitutes.
a57belair2
Dear Zoro, I love you... they canceled this part of my order but to my surprise it showed up yesterday anyway. My hands don't like holding small things anymore so I figured this would be good to have. No more struggling or looking on the floor when one falls!
Got these bad boys from HJE, loving the locking wobble. After I kept pulling a socket off a bolt I figured these would come in handy. Spendy though so it took me months to pull the trigger. I didn't know HJE has a Koken discount code so that sealed the deal and make them cheeper that Koken USA even with a 20% discount. Man these feel nice!
Steel_Rain
Damn! I want those. I know HJE had them in stock and the discount is appreciated.
cody1325
Southwest Virginia
Another handful of new tools... Klein this time. Some hits, some misses.
Wharncliffe/sheepsfoot (sorta), AXIS style lock, and bit driver. Now, we're talking something close to perfect for my uses!
Does it lock shut? I've got the hawkbill, and it makes it impossible to open with the thumb slot in the blade--I have to pull the lock bar back and wrist-flick for one-hand opening.
willf650
Here is a neat one if you're an electrician.
These are cable tie holders to clip on your bag or belt. They are spring tensioned so you just pull a wire tie out the front as you use them.
I had some of these already but they were plastic and a couple got wrecked when attached to my bag and it was slammed in the back of my truck.
These are aluminum so hopefully they are more durable.
LXCam
That looks handy, where’d you get those from?
Semi-hole mechanic
I’m not an electrician but we use zip ties to hang signage at work (TSC) and I’m always sticking the whole bag or a handful in my back pocket and dropping them everywhere, especially when trying to hang onto a stack of signs outside in the wind.
Beerhippie
Far NE Oregon
There's a very simple cure for that: I open the "wrong" end of the bag the ties come in--the head end. I can then stuff the bag in my pocket and pull out one and only one at a time.
Thusly:
Cut the other end of the bag and pull one out by the tail and five fall to the ground. The vertical cut also helps to pull out one at a time vs. a horizontal cut.
gilbo
The Koken locking wobble extension is my next purchase. Been eyeing it for a while on HJE.
Squankum
Southeast
I would like to aks you a question. That wobble fix, do you get to choose between normal and wobble via some feature of the locking collar? Or by just pushing the extension harder into the socket? I've had the latter on some cheap impact extensions and I did not like it. But I sure do love wobble extensions. And locking extensions.
I normally recommend the HF $20 (well, used to be $20) set of four 3/8" locking extensions. They're my go-to and I like 'em plenty. (Like some other HF products, kind of a kit you have to finish -- remove tiny set screws with Allen key holes, reinstall with Loctite.)
UPDATE:
Oops. I checked the HJE website listing:
  • Fix Mode: The socket is held firmly and precisely in line with the drive, eliminating movement for accurate torque transmission. In this mode, the socket cannot be detached from the drive, ensuring maximum security during high-torque applications.
  • Wobble Mode: The socket can pivot freely up to 15°, providing improved access to fasteners in confined or awkward spaces. Once in Wobble Mode, the locking mechanism prevents the socket from being pushed back into Fix Mode, ensuring consistent operation and preventing accidental mode changes during use
I must now endeavor to resist the temptations of the flesh Japanese steel!
Steel_Rain
UPDATE:
You sons of ***** got me!
KnurledNut
n/a
Thusly:
I cut the bag in the middle like a tissue box. Nothing can fall out. :beer:
a57belair2
UPDATE:
Yeah the lock is mostly for the wobble fixed mostly stays put but you can pull it back into wobble. I am liking them!
Squankum
Southeast
Electrician’s shears, protective jaw covers for 10” Cobras, and an 8mm T-handle.
I need to stop before my Veto is 50lbs…
A reminder that I have bought both the Knipex, then the HF "Doyle" version, and I'm usually hestitant to talk this way, but definitely coming off the same assembly line with tiny differences. Knipex has more and nicer laser printing on the side of a blade, and the plastic holders are slightly different. "Doyle" version is $14.99.
I've been buying them as gifts for non-tool-fiend friends.
Squankum
Southeast
Cross-post from the FACOM thread
FACOM 440 /SAE
I was looking for:
>Wrenches with a normal open end
>Satin
>Comfortable in the hand
>Quality at a reasonable price
Bill of Lading showed COO as Taiwan
That fits with my memory of these FACOM wrenches: the small sizes are long, the large sizes are too short. Those CMan raised panels are normal sized wrenches, not long pattern!
Firebird1975
MA/NH Border
SK was kind enough to toss me a new 11/16 socket because they recognized that my older SK Wayne equivalent is a hateful, evil thing.
More importantly, they gave me a repair kit for a ratchet that was falling apart.
The difference it made is absurd.
Were the replacements made in the USA? I believe that they have moved most of their new production overseas.
Winterborne
The length did cause me to pause when I was looking at these wrenches . But I had some thoughts about this:
> Martin Tools wrenches were double the price, even with international shipping. So I needed to make a compromise
> Back in my industrial line maintenance days, shorter wrenches were often times a benefit
> FACOM sells the 440 wrenches all over Europe. If the wrenches truly posed a disadvantage, why are they so well-regarded
Tarantula
Yes, I did receive USA replacements. SK does have a facility in PA for producing a limited range of legacy items (ratchets, chrome sockets, pliers, etc. if the website's COO labels are to be believed) but I have no idea what scale they're working at, if this was recently produced, a NOS socket pulled from the shelves, or if it was a coin toss between a US socket or one of the imports.
A great deal of the modern SK catalog is from China, probably made in the factories that GreatStar already employs for Workpro and Duratech. At least a lot of these new items look visually distinct from the traditional SK style so it's somewhat easy to tell.
I hope the remaining classics don't vanish in the future, I would be interested in buying some brand new tools rather than just the flea market specials, since it seems they've still got the magic.
YesIHaveAHammer
Facom 65 Metric Angled Head Ratchet Ring Wrenches 14x15, 16x18mm
Facom 467B Facom 65 Metric Angled Head Ratchet Ring Wrenches 8mm
Promotion on so I filled some gaps in lesser used sizes. No need for an 8x9mm ratcheting so I got the 8mm combi. It has a removable thin wire ring inside the box end to prevent slipping past a nut.
Facom 440 combination wrench 21mm
Another gap filler.
Facom 39 stubby combination wrench 10mm
These are usually damn expensive individually, and the sets don't focus on sizes most likely to come in useful to me.
Facom 40 combination wrench 13mm
Facom 40R speed combination wrench 13mm
Nearly new condition discontinued eBay finds. The bottom one is stamped France on the other side.
