Show your new tool arrivals
Kracin
Omaha, NE
nice, probably runs 300-500 new, i miss using large stuff like that all the time.... then again... i don't at the same time lol
Wayfastwhitie440
Florida
Found me some blue today too! Finally. Had to find a different driver. Been looking for orange to match my regular set but love the blue too. Good thing my alma mater is blue and orange:)
Also got a Mother's Day gift with it.
He had a few other blue items but my wallet had issues. Hammers. Adjustable wrenches, regular blue driver set. Wire striper and a few pliers. Hopefully be some left next week. Hoping he gets a blue ratcheting driver as well.
Whats the part number on them blue screwdriver set if you dont mind please and thanks.
Ovalinaz
Arizona
Oh damn I want those blue Snappy screwdrivers!!!!!!
Not a tool but I picked up this Bosch Router Bit Cabinet at Goodwill for $8!!
ATC
VA
My new 3/8" M18 Fuel :drool:
EJM02
If your into 4x4, I could see that being a really kick *** stick shift knob.
ATC
VA
If you're talking about that massive 1.5" impact swivel...no way! It's way too heavy. It would pop out of gear with every bump you hit, and play hell with your syncro's!
EJM02
Well ya, but it would look cool
Rezeppa
Newport, MI
Matco 4s, diggin the extra space
I am not the guy to talk to about buying a new toolbox I am pretty big on organizing and i feel most people over buy but, that blackout 4S triple bay has got my attention. If I thought I could get away with it from the old lady I would already have one. Nice box Crewcheif that is Awsome.
durallymax
Got a new full face respirator for polishing, 3M Ultimate FX, this thing is very nice, but the "latches" are very stiff right now.
I liked my magicring ball headed allen Wiha's so I got the SAE set of them. I also got a set of the magic ring torx and ball headed torx. Both scare me a little and I wonder how well they will work, if it wouldn't be for them being from Wiha I wouldn't have gotten them, but their stuff has impressed me.
91bronc300
Love those 3M respirators, they're great. I use one with 'organic' filters while welding and can't smell a thing.
eddie1278
New mint condition pair of 10WR peterson USA vise grips i won on Ebay
$17 total included shipping.
durallymax
A little different "tool" but they just finished installing our new Lube/DEF/Waste oil setup today. Turned out nice. Switched to a better company with better products, all Chevron Delo now.
91bronc300
Well I apologize for only adding comments to this thread instead of pictures, but. I didn't know those racks could handle THAT much weight :scared: How much does each tote weigh when it's full?
durallymax
Pallet racking can hold insane amounts of weight when spec'd right, look at how much is stacked on the stuff in warehouses.
Oil is not super heavy but washer fluid and antifreeze both are as is DEF even though it is on the floor.
Even so there is no more than 3000lbs on each shelf. Each side column is rated for 18,000lbs in the configuration we have it set at which put the first beam high off the ground. If we put a beam at 36" off the ground they would each be rated for over 38,000lbs. Each beam is rated for 12,000lbs each. That would mean 24,000lbs per shelf or 48,000lbs total.
Needless to say I am not worried, but years back before I knew anything about pallet racking I had the same doubts as you.
91bronc300
Cool, thanks for answering. That is a deceiving amount of strength for racks that don't really look that substantial.
bobbyg313
Sunex 21mm, 22mm, and, 24mm 1/2" drive swivel sockets.
Matco had a BOGO deal on there 16" needle nose pliers. I traded in an old/broke Gearwrench long needle nose, so the set ended up costing me, $81. Not a bad deal.
amlv20
CEN-CAL
Finally pulled the trigger and got this new snappy krsc33, I'm not one that likes change especially after the junk Mac cart that scarred me.so it's going to take a while before I break in and love it, for right now I like it and seems to have great maneuverability.
eddie1278
You talk about the ratings of the actual steel I assume but what can those pins that lock it in place hold? You know those bolts/pins whatever you call them that stick out and slide into the holes on the columns. I would be concerned about them not the actual steel columns and beams themselves. All the weight is resting on those pins.
durallymax
The ratings are for the beam, I would assume it includes the pins. Im not worried about them either, They are built as strong as the rest. Again engineering over material. Look at a rotary lift versus a cheaper model. The cheaper one has more steel and is larger but does that make it better?.
The main reason I have no worries is due to the amount of installs they have done this way. They out a lot more weight on them in other shop setups with no issues. They design and build lube systems daily.
ATC
VA
In our warehouse, ours are put together with standard 1/2" Grade 5 bolts. The stickers on them say they are good for 8800lbs per shelf. The pallets of drinks you see are 2100lbs each.
A typical Grade 5 bolt is rated for just under 15,000lbs shear strength. I'm fine with that. 4 bolts can lift your typical tractor-trailer ;)
ADSR
nice finger:p
cburnscrx
Indianapolis
I'll throw in my .02. We put 2,000lb boxes of chocolate on those pallet racks and never gave it a second thought. Not even a wobble, but we also had the racks anchored into the floor. The value of pallet racks is amazing, especially if you can get them used. We bought a whole bunch of them used and had them refurbished (ie painted).
humpty
Minneapolis, MN
The silver pin on the shelf in the picture above only prevent the shelf from lifting up, the shelf itself has fingers built in that grab the upright columns.
The shelf in question is not even close to being stressed.
humpty
durallymax
humpty
Correct, the bolt in this application isn't really even needed. The tanks are never going to move. In a warehouse I could see it being needed as things are loaded and unloaded often.
garthg
Winchester MA
Sears Craftsman USA "Line Up" tool (punch). With $4 in Sears points they gave me, only $5. Curiously, it was marked, "Not for impact use", although the web site says, "Chrome vanadium steel, double heat-treated for durability and impact resistance."
Sears Craftsman Medium Duty Air Hammer. Composite body with a nice, solid feel. "Assembled in USA". $34 online. I'll match it up with some ebay Snap On chisels. I don't work in a muffler shop. It should last me forever.
Craftsman Professional USA 10 and 13MM combo wrenches. Also strange, the two that I purchased out of open stock were a different pattern, and better quality, than those purchased in a set of the same description (see top of picture):
Armstrong USA (appears very similar to Craftsman USA) 1/4" ratchet, new in plastic bag. $10 on ebay:
