Show your new tool arrivals
stovebolt6
Canada
Had to replace some cheaper/worn out pliers, naturally I had to hold back from a true blue handle binge. I prefer CL over pretty much everything.
ClrkLndeKmt'su
Dayton, TN
So truck came by with a deal I couldn't pass up.
I'm beyond impressed with the power and realitive small size. It's taken off bolts I've always used my MG725 on, and has helped me speed up my work time. I will say my only complaint is it only has 2 batteries.
Sent from my greasy Galaxy S4 using Tapatalk
Rickster
SE PA
My new IR Cut Off Tool with 14v Li Ion Battery arrived the other day! I originally got the HF corded version but had to return it due to it constantly blowing garage breaker. Then the cabinet door above my battery charging station punctured a plastic spray bottle of Westley's Tire Bleach White and it leaked down onto my IR charger. I didn't notice it at first and when I fired up the charger for a drill battery it started smoking and now it doesn't work. So I had to replace the charger..... costing $88. Since I had to buy the charger, I decided to combine it with the cut-off tool and add in an extra battery. Haven't had a chance to use it yet. Got the kit from Jack-X-change.
Sterff
PA
Nice! I have the 3/8" impact, cut off tool, 3/8" ratchet, and the right angle die grinder. Love them.
stovebolt6
Canada
Nice blue handle goodies!!:beer:
Thanks. I almost didn't get the 8" slip joint but then I realized how much I actually use them for general destruction/dismantling of things where condition isn't important/a second set of hands. Right up there with vice grips as far as versatility goes.
Caparris
Greensboro, NC
What model are those? I have the 4410 and 6850. They are nice for sure. Batteries charge fast at least
ClrkLndeKmt'su
Dayton, TN
Ct8810 and ct7850. I didnt even look and see what the light was lol. Battery life is so far impressive, which is needed cause I'm a road mechanic. I carry the charger in case I work a 24 hour shift or longer.
canuckian
East coast of Canaaada
Hey canuckian does the red snap on box with the flex head hard handle have a part number
It's not actually a flex head. It's a low profile/pass through ratchet. The part number on the set is AFRBM113PB. The part number on the case itself is PB101. Both unfortunately were discontinued a while back as far as I know.
efb16acrx
Hope you have better luck with yours than I did with mine. Couldn't even make it through a 1/4" bolt without getting so hot it would cut out. Traded in on another one that did the same thing.
90zcar
My intro to Knipex...
Sent from my SCH-I535 using Tapatalk
Very nice!! There is some dough spent there!
Wish I could find the cobras at a store locally:(
All I can find is the alligators at sears
ChevyEFI
Phoenix, AZ
I wanted a speed open end for clearance around a hinge spring compressor tool so I picked up a used SRXM13.
I'd have been okay with a flare / speed combo but they're a little tougher to find.
disston
Silver Spring, Md
I've owned this for about 6 months. It is not made in China. It is an OTC 5230 rated at 16.5 tons. I'll challenge any of your 20T Chinese presses anytime.
I'm new here. I'm a tool fiend. I own lots and lots of hand tools, many of them old, some power tools and battery tools and air tools. I don't own much in the Shop Tools category. But I can dream.
