durallymax
- Joined
- Mar 11, 2011
- Messages
- 918
I cant make up mind if I want the HC50 or the Zebralight H600FW Mk II or H602W. Those Zebralights put out a whopping 1000 lumens but are more expensive. I was thinking of using mine for some outdoor activities as well.
I have an older version H600W and have an H602W coming tomorrow. I like the H600W but it was a spot and not nice for working up close, The H602W is a serious flood so it should be fun I think
Order off ebay or through a distributor because ZL themselves can be pretty poor with their customer service.
I bought Panasonic 3400's off Amazon - they are fine except the positive end doesn't have a protruding button like you would expect. It flat just like teh negative end. The first time I put one in the HC50, nothing happened - no power -- wtf?.....I took it out and examined it closely and realized the flat positive end would not connect to the pins inside the light since it has some funky contacts which make using CR123's or 18650's possible. I pried under the edge a few spots around the tip of the battery with a small pick and now it connects just fine.
I am also really liking going to all 18650s for all of my lights![]()
I like the panasonics, the ZLs are picky on length. They have a spring for the positive end so the flat tops work. When i got the Nitecore P12 I put one in and nothing happened then realized they don't use a spring.
I like 18650s the best as well.
