Did some Amazon arbitrage again and was able to purchase some items overseas at lower costs than in the US. Note: I am currently overseas, so this is local shipping, not cost to the US
Knipex bolt cutters 71 72 910 for $145.05. These things are frickin' huge! I do see the appeal of the 24" ones.
Klein 89556 tin cutters for $18.85, and Ridgid tubing cutter 32950 for $29.13.
Also, the Estwing 25oz Big Blue framing hammer for $15.19.
That's the 910mm - around 35.8" - set. They are WAY big. Ordering the 460mm set as I think that could be the perfect length unless you need the extra leverage.Can't really read that label in that pic (glare). Is that the 24-inch bolt cutter, or larger?
Mike
ThanksVERY nice, compact setup!
Mike
Doubles (duplicates) never hurts. At least in my world.A story about my dead. He was a man of action. Not patient with the fiddly details, but got a lot done.
One day we drove down to the coast to sail his little sailboat. For that kind of trip, he would put on shorts in the morning, then put trousers over them, so when he got to the marina, he could just drop the trousers in the parking lot. So we drove down, did some sailing, at the end of the day, we were standing by the trunk of the car, and he was putting his trousers on, zip, button, belt, belt... what? "Why am I fastening a second belt?!"
He had dropped the trousers on the floor the night before, and the next morning, in a hurry, put some shorts on, put his pants on, fastened the belt, reached in the closet, grabbed a belt...
That's very odd. I'd assume everyone here when they get a new tool will immediately find something that needs fixing or building with said tool whether it's needed it or not.![]()
I have a few things like that around here. The deals threads here are sometimes, but not always, the catalyst.
Don't tell my wife, LOL...
Mike
New Tekton 3/8s locking extensions...
I bought the 520 some 30 years ago, when I was living in a tiny townhouse in MD. Since moving to AZ with much more room, I have added the Kennedy "middle" (two drawer) box, and a bottom roll-about, to make the Kennedy stack complete.Apartment dweller here, small crafts/electronics hobbyist.
Finally put my dream box together. Kennedy 520.
The middle drawer is my next stepI bought the 520 some 30 years ago, when I was living in a tiny townhouse in MD. Since moving to AZ with much more room, I have added the Kennedy "middle" (two drawer) box, and a bottom roll-about, to make the Kennedy stack complete.
Are the male and female square drives aligned?
Just looked at it. They’re about (eyeball) three degrees offset. Two of them I. The clockwise direction and one in the counterclockwise direction.
So I checked all my extensions.
My original 90s craftsman are offset similarly too…and some are even wanged/curved (probably from an idiot move on my part).
Same with my Crafstman 1/4s and 1/2s… offset.
I have one Carlyle locking 1/4 extension…offset.
My Tekton impact extensions are lined up perfectly.
My Kokens are lined up perfectly.
I never noticed the offset in the 30 years of owning and using these extensions. Thanks for triggering my OCD now![]()
It's hit or miss, even with Snap-on, where they're supposed to be aligned.
It probably doesn't hardly matter. One place it can matter is if you're using a crowfoot on a non ratcheting torque wrench and need it to be straight or 90 degrees. I've run into this a few times and so I seek out aligned extensions.
My Kokens are not lined up...
It probably hardly matters. One place it can matter is if you're using a crowfoot on a non ratcheting torque wrench and need it to be straight or 90 degrees. I've run into this a few times and so I seek out aligned extensions.
Well, like I said, using a crowfoot (or torque adapter) on an extension with a non ratcheting torque wrench. It's probably up there on the "hardly ever to almost never" scale.Why would they need to be aligned? I agree that maybe from an aesthetic standpoint it's nice, but functionally? I'm sure if you can dream up a situation where it would; if so, you could also come up with another one where it being offset would be better. I'm guessing this is something that 99.9....% of tool owners have never thought about, including me. Are the hex flats on 6 point sockets supposed to be aligned with the square end?
Where's the drawer for the label maker tape?Not exactly new, but I took advantage of a cold weekend (the golf course is closed!) to tame the small, but functional garage workbench. The storage cabinets are freebies from a local tractor dealership that my son worked at. I also finished cleaning up the Snap-On and Crescent finds from earlier this week.
You ****!
I have never bothered to notice but now maybe?Are the male and female square drives aligned?
I don't think it would ever matter with a socket, as the fastener center is in line with the anvil regardless of the clocking.
Is that cork or something similar?Picked up this set of Witte screwdrivers from KC Tool.
And you could also say that in that same example it would work better if it was offset 45*- depending on the clearances and how the flats of the nut were aligned to them. I don't think we really need to consider these things, but that's just me![]()
This looks very familiar. My cylinder had a major leak. I replaced it with a 20ton air actuated Jack.
Would love to know your opinion on those. I have been wanting to pull the trigger but am not sure I will like them. Wish someone I knew had them to try.Picked up this set of Witte screwdrivers from KC Tool.
Yeah this one has fresh seals in the master and a new hose going to the slave. So far so good.This looks very familiar. My cylinder had a major leak. I replaced it with a 20ton air actuated Jack.
