Beerhippie
I've just given in and gone straight to oxy-fuel these days. Ever try to open the packaging on an adhesive bandage while trying to hold a cut finger together?I used a dremel.
I used a dremel.
I guess Larry David isn't much of a tool guy, although he did seem to have some lying around, but they weren't up to the taskI've just given in and gone straight to oxy-fuel these days. Ever try to open the packaging on an adhesive bandage while trying to hold a cut finger together?
I think I've only got up to a 4. I'll have to check when I get back home in a few days.You have the 5?....that thing must be ridiculous!
I have the green 17" (PWZ2GA) coming when the truck comes this ThursdayPWZ4...shown next to PWZ0....it's a beast.
I've been on a bit of a pliers kick here lately.
Icon 9" PLS19
And a bunch of electrical disconnect pliers:
Merry Tools HS120C
Merry Tools HS175C
(Clip pliers.) Merry Tools JR60
KTC AD101
Lisle 37990
I've got the other 2 or 3 new Lisle offerings, but I'm pretty sure I've posted them previously.
Also picked up two sets of chrome Icon adapters in trays and a similar set for the impacts.![]()
I believe it. I haven't used the Merry's yet though. When I took the connector off of the brake pedal all I had at the time were the Lisles. I look forward to putting the HS175C through its paces.Have the Lisle's and the Merry HS175C and its not even close, the Merry's are leaps and bounds better than the Lisle's.
I find they work well IF you have access for the particular plier. Electrical connectors can be exasperating. Old brittle plastic gets locked on and can easily crack. Your hand slips off wiggling them when pulling and then you get gouged/scraped in tight confines. The pliers really help if they fit. But like anything, you have to use with some touch and not just squeeze as hard as you can on a stuck one or it may not end well. It adds an extra trick to solve problems without taking all surrounding components off.I am very curious about the electrical disconnect pliers in the real world. I have been looking at them for a year or 2, wondering if they would get any use. I feel like the scenarios where a connector is a pain in my *** and I wish I had a tool for it, there isnt room for a set of pliers. I also worry about breaking/cracking the connectors putting too much pressure in a focused spot (but of course that would be the users fault for using too much force). But I am open to giving them a shot if anyone has tried them and says "yes they are genuinely useful in practice."
I think it would be cool if someone made a clear plastic version of those connectors, similar to the acrylic practice locks for lock picking, so that you could see where the clips are and know better where you need to press. There are probably way too many unique connectors for it to work, though.One comment though: I recommend strongly studying the connector and similar connectors you can find in more open areas before jumping in and using pliers with a lot of force. That can save a lot of grief.
Update on this tool: It claims to fit 1/4" - 3/4" and 7mm - 19mm. It doesn't fit either 3/4" or 19mm.I can throw out all the sockets in my "road kit" now:
Covers 1/4-3/4" AND 7-19mm, no skips!
The old guys at the yard sale where I got this in a box-lot were waxing poetic about how amazing these were--not noticing, I guess, that it's unused--for a reason.
I'll stick it on a ratchet just to see how bad it is--then give it away as a "white elephant".
He didn't even cut himself!I guess Larry David isn't much of a tool guy, although he did seem to have some lying around, but they weren't up to the task
Hope you have another pair to cut the package open!
A related comment: I recommend strongly studying the connector and similar connectors you can find in more open areas before jumping in and using pliers with a lot of force. That can save a lot of grief. I use a mirror and headlamp and if I am desperate I use a borescope to carefully study the layout. When I do that I often find I was approaching it wrong and doomed to fail. A good pair of gloves is also essential in case you slip and to provide a little padding while wiggling and pulling.
I had, I think it was a Harbor Freight LED light. The Braun small rectangle ones with the yellow rubber ring around it. I had the hardest time cutting them open on one I stepped on the plastic, I was seconds away from using a hacksaw.I guess Larry David isn't much of a tool guy, although he did seem to have some lying around, but they weren't up to the task
I find this and the low profile bits really handy as well. If you want additional stubby bits check out the Linus Tech Tips bit sets at lttstore.com
FWIW - That’s an 11mm ratchet for low profile sockets, not a 1/4” bit driver. Not sure if that’s where you were going with that?I find this and the low profile bits really handy as well. If you want additional stubby bits check out the Linus Tech Tips bit sets at lttstore.com
The set which this ratchet is part of comes with a low profile bit holder. Snapon also sells a set of short bits.FWIW - That’s an 11mm ratchet for low profile sockets, not a 1/4” bit driver. Not sure if that’s where you were going with that?
Don't forget the Teeny Turner from PicquicA few weeks ago I was watching a shop organization video and the guy had another video and he talked about the Picquic brand of screwdrivers. They looked interesting, and seeing how I didn't have that specific set, it was really all the justification I needed to order a set.
I have had them a few weeks, and they are nice, they fit well in my hand and seem well made. That being said, the hex and torx versions are less practical, at least so far. It is difficult to see the size of a bit while it is stored, and it takes longer than I want to spend finding the correct size. For in-the-shop use, that's not going to work for me, but they'll be great in a go-bag - I'm putting them in my truck bag.
The original Sixpac Plus doesn't have that issue, as all the bits are easily discerned by a quick glance, so if you just stick with that, it will be fine anywhere. I am ordering a 2nd one to have in the kitchen drawer. Made in Canada/Taiwan. I got mine on eBay.
Lee
Awww... ain't that just the cutest lil' thang?
Now I’m with you!! Thanks!! Is the bit adapter Snap On? Seems like I didn’t find a low profile adapter when I got my ratchet, but it’s been a while.You were saying?
It's Simply the best...Awww... ain't that just the cutest lil' thang?
Ha! Mostly agree. A little more standardization would help. But i find it really helps to be resigned to a few min of careful study and approach contemplation before moving to disconnect. Stubborn electrical connectors can be truly exasperating.Thanks for the tips. I mostly just compose an angry letter to the manufacturer in my head, along the lines of "How many different types of electrical connectors do you really need?!"
Short bits hereThe set which this ratchet is part of comes with a low profile bit holder. Snapon also sells a set of short bits.
Snap-on Store
shop.snapon.com
Did you buy the set of bits or did you buy the ratchet set? Cuz the ratchet set should come with the adapter.Now I’m with you!! Thanks!! Is the bit adapter Snap On? Seems like I didn’t find a low profile adapter when I got my ratchet, but it’s been a while.
edit - I see the Snap On link. Now I have to figure out why I don’t have one (bought the set).
They are gorgeous though, aren't they?? $40 of toolbox jewelry if nothing else... (though I am actually a fan of using T handles). Video link below is queued up right to the Koken spinner part...Koken 3715SLK spinner T-Handle. I think pfbz posted this maybe on YouTube. Its just so nice, I had to get one to never use.
When I first opened it, I was holding the 2 halves, staring at the oval hole for the handle.. thinking "aww man, this one got smashed on the endThey are gorgeous though, aren't they?? $40 of toolbox jewelry if nothing else... (though I am actually a fan of using T handles). Video link below is queued up right to the Koken spinner part...
Thanks, I appreciate it...
That ruler has all the presidents on the back, ends with Clinton.Thanks, I appreciate it...
And you appear to be a philatelist... Based on your ruler... Then again, if you made those decisions based on some of the rulers I have, you might assume that I am really, really old, a know-how to wind electrical motors... Or that I was a tool and die maker... Depending upon which grandfather's ruler I was using.
