Ha! Even stainless and titanium transition into quivering lattice phonon vibrational modes out of fear when they see me breaking out the properly sized cobalt bits!
Good one on your graphic!
I particularly like them when I sometimes need to drill a slightly larger hole... the bit stays center as it enlarges it
Supposedly in a few days, they are having a good battery sale on the 5ah twin pack. Take the receipt back and get the difference.My first buy of the HF/Hercules 20V tool line; their grease gun. Although I haven't used it much yet, I'm pretty impressed with it. You can see I'm already invested in the Ridgid and Milwaukee 18V tools (lower left).
My Memorial Day sale Koken finally arrived today.
Koken's least skippy, most Flank-Drivey-ist, and somehow quite affordable socket set. (Fairly priced even before the big holiday sale.) 8-19mm, no skip.
Even came with a socket rail. A rail that, unlike some others I've known, doesn't fight you to the death to remove a socket.
Pardon my problems focusing at close range. Satiny down low, and the rest of the socket seems like satin that got polished a little bit. Each socket reads size, Koken, part number, made in Japan. No laser beams involved, either.
Really taking the Flank Drive (they call it Surface Drive*) concept far. I don't know how well these will work but I'll know soon enough.
_________
* Make your own Carlinesque commentary about "How else is a socket going to work?" and "surface streets", too.
I’ve had these on the list for a while. I’m curious to read your review on how they work. Are they so loose fitting thats its bothersome to hold them straight on the fastener? Enough play to use them as SAE and MM? A candidate for actual daily driver use or specialty use only?
kokenusa.com
The most aggravating underbody pans and bolts was the first generation of the Infiniti Q45, that thing was massive, front of body work all the way back to the seam where the fender ended at the door opening. Full width as well, almost the size of a pool table, needed to be there as it formed a duct to pull the air through the radiator as there was no grill opening. The fun was up here in the northeast the hardware would rust into the nuts that in most locations were threaded holes in the frame and crossmembers. Removal thus caused the head to snap off leaving no option but having to drill through the trapped rusted bolts ad then rethreading the holes. A little more plating on these bolts might have prevented or reduced this. It would have been nice if they had provided a hinged door to allow access to the drain plug and oil filter but no one at Infiniti considered that.An update from last summer! I bought these sockets for my road bag and moemc asked me questions right away:
I had no answers! Hadn't used them yet. Well, now I've used them on a project and they feel like sockets.
I was trying to remove an underbody aero pan on a used Kia and the the bolts were fighting me. One bolt broke. Here are various flats on a rusty bolt head to show what a good job they did of engaging away from the corners:
12 Piece 3/8 Sq. Dr. Surface Drive, 6 Point, Chrome, Metric Socket Set
The Ko-ken RS3410M/12 3/8" Square Drive Socket Set is a 12-piece surface drive socket collection designed for high torque applications and reduced - Ko-ken USAkokenusa.com
$65.46 at HJE, that's a bargain for you!
Koken 3/8" Drive 8MM-19MM Surface Drive Socket Set (RS3410M/12)
Koken 3/8" Drive 8MM-19MM Surface Drive Socket Set (RS3410M/12)www.harryepstein.com
I have that Koken socket set (love Koken tools!) I've had them for a few years now and the majority of my regular sockets, deep sockets, ratchets, extensions, etc. are Koken.....for me probably some the very best tools to use when working on vehicles (especially foreign).
Though I do have to admit I definitely didn't pay that price that HJE is offering them at!
Now that is definitely a very good deal!
Thanks for posting and sharing Squankum.
I used it once, pretty typical of these style kits. Not bad. Very similar ratchet to the Icon set, I think you can get a similar set by Klein as well.
Yup! They make for Matco I know and not sure who else but cheapest to get direct from mayhewMade in USA, headquarters here in MA? Thank you for posting that, I don't know what rock I've been living under, but I'll start looking for more of those when buying in the future!
Mike
Mike
I'm not sure I'd like to have drill bits that cannot be reground without major efforts.
I submitted a return, and got the replacement today, and it's worse than this one. It just spins like a fidget spinner. Disappointed in Lang for such a **** tool.
The Vortex style bit tip is designed to increase tip life, while requiring less effort to drill holes.I'm not sure I'd like to have drill bits that cannot be reground without major efforts
The intent, is likely not users who resharpen their drill bits, but more users who buy bits by the dozen in sizes they use frequently, and who bit the bits when the bits stop cutting well.
I don't know the intent, but I strongly suspect that these Vortex drills will mostly be bought by somebody who wants to try another new gizmo and use it a couple of times a year. Frankly, I cannot imagine a professional machinist or metalworker who buys his SMALL drills in multiples to fall for those.The Vortex style bit tip is designed to increase tip life, while requiring less effort to drill holes.
I have seen enough drill bits for sale on eBay from industrial close out sellers, to say that some manufacturers just buy bits in bulk in the sizes used, with the bits likely tossed in a bin when the bits get dull.I don't know the intent, but I strongly suspect that these Vortex drills will mostly be bought by somebody who wants to try another new gizmo and use it a couple of times a year. Frankly, I cannot imagine a professional machinist or metalworker who buys his SMALL drills in multiples to fall for those.
It's not to say that the drills are bad (I never tried one and don't intend to), but a combination of a center drill, step drill and a regular one on top of each other looks a bit gimmicky to me. Especially, when they are sold by a single manufacturer.
The Dewalt single step design has gone thru variations over the years, but it goes back to at least the early 1990s, with Black & Decker offering the Bullet tip drill buts, on which the step angled forward slightly, like a bad brad point bit.They are available from a multitude of brands under quite a few different names. They are a game changer in hand-held, on-site, use. They will drill pipe/round bar without wandering - and you can use them without center punching. They will also produce an actual round hole during hand-held use, every time. “SmartStep” was introduced around 2021 if I’m not mistaken. I think Ruko was the first, actual manufacturer, of these.
EVERY major player here sells them. From drill bits, actual step drill bits to combination drill/tap bits. (…)
They have also not too long ago released a new tip geometry/shape that is even more aggressive/ steps are less linear/even spread. I don’t have one of those available right now.
The German made DeWalt “Extreme2“ drill bits have a similar tip like the first generation, but only a single step, and do also work quite well.
Yes, shop bound machinists might cringe at the thought. People on site actually rejoice.
Cost is insignificant.
Kind regards,
Olli
Although that may be true, for most of what I'm doing, I am very unlikely to buy a set of specialized drill bits just for that task, especially in woodA centering drill is made for that and would produce better results.
