Show your new tool arrivals
zendriver
Indiana
Since I now have trash service with the small bins. I try to keep it full with tiny branches that fall in the yard, that I chopped into small pieces Some are a little too big for the pruners, and I don’t feel like getting out of power tool to saw through
Have an olderhand saw but the teeth aren’t all for somewhat Greenwoodthat thought I’d give this a try for $5.50
Pretty sweet and well built. Blade is thin but then pruner blades usually are and has a locking mechanism blade is 9 1/2 inches
Semi-hole mechanic
I'll give you $20 if you lick the coil wire off off a MSD box.
I was setting the timing on my ‘78 Grand Prix in HS and the timing light had somehow come unclipped from the plug wire and I reached to grab the clip and grabbed the plug wire instead and apparently there was a crack in the insulation that was causing the misfire not the timing. My right arm hurt for a couple of days.
