$100?, my dealer sold em for $80
I passed on the flex heads because they don't make metric and i read on here a lot of people don't like the locking wrenches.
I couldn't pass them up, I have an older 8 piece craftsman ratchet wrench set that I have beat on. I used the 3/4 almost all day everyday. they were rained on and dropped and they still work good as new with a little bit of wd40
put a pic of your a-dub as a placeholder! I miss my 88 something terrible. /derail
I sold my 15" Wilton floor drill press and replaced it with a 20" Jet floor model that arrived on Friday afternoon. There was nothing wrong with the Wilton other than there have been a few times where I needed a little more throat distance between the column and the center of the chuck as well as a little more power. The Wilton drill press was the first "new" piece of equipment that I had purchased when I built my new shop at home back in 1995. Most of the tools/equipment I had at the time I transferred from my shop at my parents farm to my home shop but the drill press was my dad's so I couldn't take that with me. I had gotten really used to using a drill press between my dad's and the one we had at work so I figured I had better get one vs. freehand drilling with an electric drill motor and a vise.
I finished my shop in the fall of 1995 and bought the Wilton drill press for Christmas that year. It has served well but time to get a little bigger one with a little more power.
I ended up with a Jet 20" floor model with a 1-1/2 hp motor and 5/8" drill chuck. I also purchased a 5/8" Jacobs ball bearing chuck at the same time as I have heard the chucks on these are not the highest of quality. I did the same thing when I bought my Wilton and it gave me no issues in the past 17 years. I threw the 15" Wilton up for sale Friday night and got a call within about 20 minutes of listing it. The first guy that called and came to look at it Saturday morning bought it and was ecstatic with it.
Anyway, my son and I are taller than average, me being 6'2" and my son being 6'5" so I had to modify the new drill press. It measured 57" to the bottom of the drill chuck and I felt like I was bent over or needed to kneel down to use it. I fabricated a 6" extension for the bottom much like I had done to my Wilton many years ago. This way I can stand normally and not be uncomfortable while drilling. This put the drill chuck right at 63".
Mike.
Here is the before after just taking out of the box and standing up.
Trueing a piece of 4" O.D. x .250" wall thickness tubing measuring 5" in length.
Two 7" x .500" pieces of steel plate.
Both pieces welded on either side of the tube with holes drilled to match the bolt pattern of the base of the drill press.
I painted the spacer a textured black to match the finish on the base of the drill press.
Bolted together and ready to use.
They are pretty nice.
Nice spacer and drill press. I would have built a base and bolted it down using the holes in the plate but that only goes to say I have less skill than you.
Mike.
picked up a set of SK long pattern metric 8-24. Used for 75$.
Also, I got a few SnapOn wrench rails
@durallymax: nice quality tool haul !!!!![]()
