Not trying to knock your purchase but I had a set of those and anything that was stuck would spread the wrenches every time.
I would have bought the usa ones but nothing on the shelf.Not trying to knock your purchase but I had a set of those and anything that was stuck would spread the wrenches every time.
Wanted to ask what set do you have now?Which? Originals were SK, then Ideal SK, then China.
Ill just have to use the vice grip trick when i do the brake line.Yea those Craftsman flare nut wrenches aren’t good... did you save the receipt?
This was about 4 or 5 years ago so not sure who made them as I traded them in on matco ones as soon as I could.Which? Originals were SK, then Ideal SK, then China.
Yeah you gotta buy what's there, maybe you'll have good luck with them but living in the rust belt they couldn't take the pressure needed to break stuff loose.I would have bought the usa ones but nothing on the shelf.
Sent from my SM-N960U using Tapatalk
A few Facebook Marketplace finds today, all USA, Proto 21 Piece 1/4 socket set, Armstrong 1/4 ratchet, 3 SK extensions and 1 Williams extension, all for $20. Gives me a weekend project to clean and lube everything.
Hey Real Philbert:
Is that PROTO spline combination wrench US made?
For less than half the cost of block/thread prep at a machine shop, I bought this kit. I have a couple of stripped threads/holes on a motor I’m working on, and I’m hoping this will re form the threads back to usable. If not, I can helicoil. I’m trying to avoid that, as it’s in a water jacket/hole, and I don’t know it the helicoil will seal (helicoil to block). I can always goop it up, but original threads are always better.
This set is by Lang. I bought their spindle thread repair set earlier this year and was impressed by it, and I’m sure this won’t let me down either
Once this storm passes, I’ll get out there, uncover the motor and try these out...
Snap On
Snap On and the other truck brands all sell this same kit with their sticker on it. It also is/was sold as craftsman and probably other companies as well. If you find yourself needing to replace single pieces you can buy them from the snap on website for a couple dollars each.
Great minds, huh? Haha
I had a break in the weather, and was able to go out there and use the 3/8 tap. It made the damaged threads BEAUTIFUL again, like they were never even damaged. Definitely just earned their keep and paid for themselves today. Saved me a trip to the machine shop!
I remembered something like that when I got the spindle thread repair dies. I remembered that someone here posted that Lang manufactured stuff that was rebranded, so I searched for Lang
Good tip on buying the singles from Snap on. I doubt I’ll wear these out (famous last words, right? Haha) but if I do wear them out, I now know where to get replacements. Thank you![]()
with all the flare nut wrench talk. What is the best (no flex) set of flare nut metric wrenches?
Thanks
