Buy the original... I bought a knockoff years ago... thing "released" on me while at height... was lucky I have all my fingers still attached.
20 mm is used more than 12 mmNice looking wrench set. Although, I find it odd that the set doesn't have a 12 mm but, it gives you a 20 mm. Is 20 mm popular in Europe?
Original as in Little Giant ? Or the bigger version ?Buy the original... I bought a knockoff years ago... thing "released" on me while at height... was lucky I have all my fingers still attached.
Now I own 4 of them... Super Quality.
Little Giant... I have a 3' 4' 6' 8' step ladder... the POS I had was an ext ladder (similar to yours) but lousy design. The clips that held the thing extended slipped and the whole ladder slid down like an old radio antenna with me attached. I swear I'm still 2 inches shorter after that event.Original as in Little Giant ? Or the bigger version ?
I already have two 24' ext ladders, an 8', 6' & 3' step ladders. This will replace the six footer I believe.
Found this knee mill on FaceBook MarketPlace earlier in the week. So a friend and I went he ended up buying it for $1k. Luckily the shop had a overhead crane to load it on the trailer and was kind enough to weight it for us - 1956 lbs. So luckily the aluminum gantry, gantry trolley, and chain fall were rated for 1 ton and we are sure there is a generous safety factor in there… But it was successfully unloaded in his shop and we got the stuck B&S tool holder out of the cartridge by freezing it, a pickle fork, and a few raps on the draw bar. Now to start cleaning it up and order some replacement parts (yes they still make and sell this model and even provided the order paperwork from 1966!)
I read the later threads.. duh Index..Is it an Index? I cant quite make out the brand....
This is the listing I ordered from: https://www.amazon.com/gp/product/B08H8DJ8ST/?tag=atomicindus08-20
I found a few with a search on ebay for '27 piece auto pry set' - definitely still available under a few names.Unfortunately, it says currently unavailable. I don't have any experience with the other listing that was shared, but I wouldn't be surprised if these are all coming out of the same factory.
Did you read the context in which the question was asked? I'm not saying they're unobtainable; the Amazon listing I bought them from had them for $6 shipped, which is why he's asking for the url.I found a few with a search on ebay for '27 piece auto pry set' - definitely still available under a few names.
grumpy...Did you read the context in which the question was asked? I'm not saying they're unobtainable; the Amazon listing I bought them from had them for $6 shipped, which is why he's asking for the url.
Disappointed to see made in China on Starrett but this showed up today
What makes are included with the adapters? I've got Mini, Honda and BMW to deal with...
Chrysler, GM, Ford/Mazda, Honda, Toyota/Lexus, Subaru adapter and another Toyota/Lexus attachment.What makes are included with the adapters? I've got Mini, Honda and BMW to deal with...
That brings back memories. Bad ones. A "Jointer Pal" (the steel one) saves hours of frustration with knives but even so a Byrd Shelix (or other) ends that task forever. Planer, too. I'd never go back to knives. A helical is also way smoother cutting and doesn't sound like a helicopter in your shop.Got a OneWay Multi-Gauge for setting the knives on my jointer. Knives should be delivered tomorrow so I can try this thing out!
There are a ton of NAPAs in my area and several have it in-stock, so I think I'll just go pick one up. Thanks for the reply!Chrysler, GM, Ford/Mazda, Honda, Toyota/Lexus, Subaru adapter and another Toyota/Lexus attachment.
Most of the bmws (well most German cars) listed in the guide use Toyota/Lexus attachment though some use the GM. Mini isn't listed but I assume it's a BMW fit? Most of the other Japanese imports use the Honda one.
Hard to beat for $44 and free shipping
I already ordered a Byrd Shelix but it won’t be delivered until November or December. This is just a temporary solution.That brings back memories. Bad ones. A "Jointer Pal" (the steel one) saves hours of frustration with knives but even so a Byrd Shelix (or other) ends that task forever. Planer, too. I'd never go back to knives. A helical is also way smoother cutting and doesn't sound like a helicopter in your shop.
10 piece metrix 3/8ths flex/universal Toptul.
I have morse holesaws that are made here in Ohio, Klein hacksaw blades also US made - don't believe morse makes an oops arborStarrett definitely feels like it's slowly moving towards that direction. The quality of their metrology equipment feels like it's slowly starting to slip as well. We've been migrating more towards Mitutoyo at work for inspection tools.
I would look into Sandvik for this sort of stuff if you are picky about COO. I recall buying sandvik hacksaw blades, and they were made in Switzerland. Snap On's blades are still made by Sandvik in Switzerland if I'm not mistaken.
Porsche mechanic here, our go to for the lower control arm eccentrics outside of the special tool(T10188 which connects to a Stahlwille 730/40 torque wrench) for them is a 3/8 21mm socket on a 18" ratchet. I'm assuming you were replacing the arms due to worn rear bushings and accessing the bolts from the wheel well, but if you were doing the alignment than the extension on that Gearwrench box end may not be deep enough to clear the subframe from underneath while on the rack.Gearwrench 21mm zero offset flex head, would have saved me a lot of time on stupid Porsche cayenne lower control arms that leave room for nothing but a wrench, or maybe a pass through set. Props to my wright 2.0s for standing up to the wrench on wrench to get those SOBs loose. Gearwrench, I work on all, I don't need a 20, 23, or 25, maybe throw us a 27 instead of those, or a 30. Then you have the complimentary second set.
The only time I use 23mm is Mazda differential plugs, which is dumb to begin with, considering it's been ford for years.
Most importantly, lifetime warranty on all. The tool truck store, Manassas, VA, shout out.
Got a link to the funnel set? Thanks
Carlyle oil funnel setGot a link to the funnel set? Thanks
I associate Martin tools with automotive body tools as well as service wrenches. I'm sure they make a ton of stuff, but that's what I usually see their name on. I don't know if they make those hex bit sockets in house or if they source them, but I've never heard bad things about their tools so either way I'm betting they're good quality.I have never heard of Martin tools nor have I ever met anyone that has anything by them. I believe they are made in the US as the hex bit has USA marked on the side. Figured I’d give them a try. I ordered metric and standard sets. The standards arrived this afternoon but I am still waiting on the metrics (which would have come in handy at the shop today). Can’t wait to get these dirty!
Yes.Are those flex socket joints riveted?
