Show Your Offset Screwdrivers, Right Angle, Plain and Ratcheting
Provincial
Near Salem, OR
Here's my cosmic contribution. A Meteor.
Has a flat screwdriver on one side and a 1/4" male square drive on the other.
Instead of a flip handle to change direction, it has a rotatable knob. The more common flip handle is easier to use than this tiny knob.
I have some Meteor ignition wrenches. They do not have any markings other than the name.
As first reported in the GS thread, I found this Cornwell SDS-43 last week at Kent's, a used tool store in Tucson, but I've been on the road and haven't had a chance to post it. It's a unique, interesting approach.
The only other examples I have seen posted here on GJ were in older whatzit threads linked here and here.
Catalog excerpt is from 1941.
I sure wish it was the whole set, but 'beggars (and in-the-wild pickers) can't be choosers'!
Picked up this teenie tiny cutie at the flea this morning. #020. The date stamp is really deep, obscuring the outline, but given the branding and the style, I'd have to say this is either 1938 or 1948.
I was happy to find this machinist's double-end double-offset at the flea this morning. It's OAL, offset configuration, and octagonal shank are perfect for the wartime GMTK specs, and it's only a little thick at 1/2" (3/8" was specified) for the diameter of the shank, but it will do just fine.
Here is a nice General ratcheting screwdriver I found at an estate sale last weekend. The good thing about it is that it is a slotted screwdriver on one side and a Phillips #2 on the other. IMG_2640.jpegIMG_2639.jpeg
  • Like
Reactions: RTM
Stubby1743
UK
A bit of a mix of old and newish.
From the top no name; CK 3&4 Pozi; two English Footprints; Vitrex No.1356 and lastly the oldest.
The oldest is the same pattern as the one in post#33. Mine is marked 'BHP' together with the UK Govt. property broad arrow and dated 1945.
R
Been a while since I've added anything here, this is a find from a toolbox of goodies, slowly working my way to the bottom, lower stuff from other hauls was getting tossed in the box, since it was a fixture near the tool desk.
Nothing two exciting, a GlobeMaster Japan #1 Phillips screwdriver, both bits are rotated 45° from the other to give you more swing in less space. Overall length is 3-1/2" so just an average tool.
Hmm, apparently there were two more from that haul that should go here, a Vaco and A Stanley Yankee Ratcheting. We'll see if they turn up anytime soon, or if I just tossed them in the toolbox.
Pexto
I spotted this on eBay and couldn’t resist it. The ratchet isn’t functioning properly but may just need some lube. Another ratchet of another brand was included.IMG_3203.jpeg
That's a really nice find! The bits look very similar to Xcelite bits like the ones that come with the XL-75. Do you know if they are interchangeable?
I’ll find out because I ordered an Xcelite ratchet to use with it. Immediately after ordering the Xcelite ratchet I found a North Bros ratchet listed and ordered that.
An odd snapon
I found a General Made In USA right angle ratcheting screwdriver still in the package at a local garage sale yesterday. It’s a little newer than I would have preferred but being still in the package seemed to make up for that. IMG_5120.jpeg
IMG_5121.jpeg-Don
Normally I wouldn’t have bought this pre Stanley Yankee 3400 screwdriver but I am a sucker for tools that come with a sleeve. I have no idea if the sleeve is original but I like it. IMG_5705.jpegIMG_5704.jpegIMG_5703.jpeg
Mintgrun
Kingston, Wa.
I brought home the largest one I've seen so far. Here it is beside the smallest one I've found.
The tiny one's marked VACO VO-1 U.S.A. I don't see any branding on the big one. It looks like there's chrome underneath the red paint, so I may wash that off. I'm guessing it's a drag link tool.
kwigly
Ontario
Mystery offset screwdriver I've had for a while.
Knurled metal shaft for gripping while you turn the nice boxwood "London pattern" handle. The driver blade is quite slim, so likely for an adjustment screw ? carburetor ? or ?
R
I would guess adjustment as well, and that the handle is a sweet addition. Mine like that have an arrow or line on the handle end so you can see how far you’ve turned. Mine drive 1/4” socket type tools tho, so not on here
Okay, first of all, that is a gorgeous tool, kwigs! :love: Wood, steel, brass - what's not to love?
If I am understanding correctly, it's for close-quarter work, where there is no space to swing a shank left or right about the head of the unit being turned. Like close-quarter ratchets where you twist the shank or a knob on the end. That is, twisting the knurled shaft doesn't turn the whole head in the same axis as the shaft, it turns the screwdriver blade in a different axis. That means some kind of knuckle joint or beveled gears to actuate.
While I can understand why you might not want to take it apart, I would love to see the innards if you're up for it. I see a couple screws. :)
I am not terribly fond of this style of offset screwdriver (rectangular bar of steel with the ends twisted and flattened into 45* blades), so I was hoping this would at least be something interesting (such as a "Pop" Walker), when I spotted it at the flea yesterday. No such luck. I had no idea when Herbrand was selling this type. Postwar for sure. And the composition is strange. Using @RTM's Indestro set (same style, post #1 page #1) as a guide, I started in the '66 cat (nope - hex shank, opposing blades, one parallel, one perpendicular, GMTK style) went back to '48 (nope - same configuration as the '66). Finally found it in the '61, which is a little odd. I guess they tried it out and then abandoned it. And the description (Chrome Tungsten Steel!) confirms it.
I have been on a bit of a Chapman run recently. I found these at a Marin County yard sale yesterday. Hard to resist the yellow. 😳IMG_9200.jpegIMG_5360.jpeg
MisterEd
Florida
Plomb 36 5/16
Mintgrun
Kingston, Wa.
This one appears to have been made out of an old screwdriver and a stainless steel swage eye, with a Phillips bit pressed into the hole. I believe they whittled down the handle, which crumbled and finally broke. It's the kind of nasty plastic that causes rust, so I was happy to remove it. The part that hadn't broken was surprisingly resistant to hammering and required a chisel to cut it off.
I have a spare handle with the right size hole, but I'm not sure I want something that bulky. My little offset screwdriver box is pretty full already.
MisterEd
Florida
Bridgeport Off Set
