Show your vintage Lufkin tools
Beerhippie
Far NE Oregon
I added another Lufkin Red End w/extension to my user collection:
I picked it up last weekend for a buck and I've already put it to use. Great tool for transferring inside dimensions.
Beerhippie
Far NE Oregon
Yours is cleaner than the one I have. I just learned the ease of use of that extension in the very recent past.
It's a lot cleaner than the one that's been carried in my tool bucket or bags for decades, too.
I used to use mine for transferring inside measurements when casing windows/doors. Mostly--it has lots of other uses.
Discovered this collapsible yardstick in my desk the other day. It's a Lufkin and I would guess late 1990s due to the name of the credit union which changed in the 90s. This would have been a patron gift at an annual credit union meeting.
This sounded very familiar, Jim. :)
If anyone else is interested in the patent (2,956,795, Oct 18, 1960), it was for the underlying mechanism at work, a spring constructed of a flat band or ribbon wound into a coil, and not owned by Lufkin. The inventor (Foster, Austin, TX) intended it for many uses, such as a retractable lamp. He did include a tape measure in his diagrams.
@PelicanPines posted one to the Rules and Tape Measures thread. His, too, was a complementary gift, from a funeral home of all places!
kwigly
Ontario
Found a couple of folding rules to add to the accumulation this week:
- small 12 inch 3-fold "Patent Pending" Lufkin No. 2071, boxwood with a level, (goes with a couple of other styles/makes of boxwood+level rules I've found)
- big 6 ft 12-fold Lufkin 1206 (same as Beerhippie's favorite folding rule, post #50) It has a nifty folding hook at one end
kwigly
Ontario
^Nice! I've never seem the tri-fold with level before!
Researching this level/rule I found Lufkin also made a similar 2 foot tri-fold rule with a level, No. 2062, and another 12" No.2051. God knows how many other models/makes were on the market...
But more stuff to look out for :D
kwigly
Ontario
The patent for the 3-fold level/rule seems to be the Dec 8 1914 Pat # 1120443
and for the nifty end hook on the 12-fold 6ft rule; June 13 1916 Pat # 1186853
bazzz
Heathsville Virginia
Here’s my small Lufkin collection. Two of the three folding rulers are broken but the other end still works 🤣
Ayrhead
Ontario
My latest Lufkin Tape Measure. A Mezurall #926. Made in Windsor, Ontario. Patents from 1932 to 1936. I’m thinking that this tape is from the late 30’s. Back then you could add 2 inches for the case…
Ayrhead
Ontario
This is a fun comparison. Mine has patent numbers, instead of dates, with one more pending.
Otherwise, the case is the same. I'm guessing yours is a little older.
I’m guessing the difference might be that mine is Canadian and yours is American. There might have been different rules to follow. But then I’m only guessing.
Ayrhead
Ontario
Ah, I'm guessing you're right. I should have looked closer at the other side of mine. They are indeed different.
It is interesting though that they both are No.926… I think it’s just the same unit but one is made in USA & the other in Canada 🇨🇦
DetailSeeker
South-eastern Ontario
FWIW, the US one was made after January 15, 1935 and before June 26, 1951. The Canadian one was made after June 1936 and definitely no later than November 8, 1949. Some Mezuralls had patent numbers on the tape itself, as well; that could help narrow it down more.
Both were probably made before 1949 (1947 is the last Lufkin catalog that shows plain steel cases on the Mezurall; the 1949 catalog shows inset plates on the sides).
At the time these patents were granted, the expiry was 17 years from the day the patent was granted, in both the US and Canada. (US patent 1,964,280 was granted on June 26, 1934, so would not have appeared after June 26, 1951, and so on.)
For the US, the Pat. Pending unfortunately doesn't help; it means Lufkin filed for another patent, but unless there's another Mezurall 926 with a later patent number, there's no way of knowing if it was granted, and there is no way I know of to look up rejected patent applications.
The Canadian one is different because it has patents that were filed in Canada, and while the term was still 17 years, the rules for dispolaying them on items were different. The November (8th), 1932 patent is 327477; that was the only patent that month assigned to the Lufkin Rule Co of Canada. It's the Canadian version of US patent 1,973,843. (Yes, it was granted nearly two years before the US patent; both applications were filed in 1931, the Canadian one was just granted faster.)
The July (30th), 1935 patent is at least 352026 (equivalent to US 1,964,280). Patent 352027 (equivalent to US 2,022,756) was also granted to Lufkin Canada that same date, but I don't know if both patents were used for the Mezurall.
On June (9th), 1936, Lufkin Canada was granted four patents - 358400, 358397, 358398, and 358399 (this last one is equivalent to US 1,987,652, and I am calling that good enough because it's nearly lunchtime).
Mintgrun
Kingston, Wa.
When the little 90 degree lip at the end of the tape gets bent, the tape is no longer going to be accurate. It's a little tricky to grip the leg that's attached to the tape due to the curved shape, but it is not too difficult to straighten them back out if you're careful.
Ayrhead
Ontario
Unfortunately my tape is not the cleanest. The only marking I could find was the Lufkin logo just past the 2” mark on the tape. I pulled it out to 58 inches.
When I spotted this push button Lufkin at yesterday’s estate sale, I didn’t hesitate adding it to the bag. Oddly the tape has been replaced by a Stanley. Oh well, it will be an excellent user. IMG_8251.jpeg
Ayrhead
Ontario
Just picked this one up… a Lufkin Dial Test Indicator #399A, it still had the little brochure/phamphlet in the wooden box…
Ayrhead
Ontario
The gentleman also had a depth micrometer… it’s a Moore & Wright in a metal case…
Lastly a vernier caliper in a wooden case. The manufacturer name looks like Mauser made in Germany…
I saw one of the ones in your last picture yesterday and passed on it because I couldn’t figure out how to operate it. It was made in West Germany.
