Show Your Vintage Utica Tools!
LesserSon
PA USA
50-8” electrician’s side cutting
86-6” duck bill
90-6”
90-8”
90-10”
90-12”
100 BX cable cutter
260-7” end cutting nippers
511-6” heavy duty slip joint
511-8” heavy duty slip joint
LesserSon
PA USA
511-10” heavy duty slip joint
513-7” side cutting slip joint
517-5” slip joint ignition
517-10” slip joint water pump
622-5” short chain nose side cutting
650-6” long flat nose side cutting
654-6” long chain nose side cutting
777-6” long needle nose
888-6” curved needle nose
1000-8” Button’s pattern
LesserSon
PA USA
1033-6” long chain nose
1300-8” gas and burner
1300-10” gas and burner
1950S-6” heavy duty side cutting
1950-7” heavy duty side cutting (no photo)
1950S-8” heavy duty side cutting
(US military)
The display looks like this:
RedVise
Gulf Coast, Fl
I found a set of Utica 24-5 1/2 pliers. Searching did not yield any data. There is a round upper and lower jaws (?).
They might be saw sets?? Upper jaw is adjustable from the top for thickness.
Any body familiar with these ?? Thanks
GalaxyRat
Florida
I'm glad to see a dedicated thread, here's my adjustable wrenches. I'll have to wrangle up my pliers one of these days.
rdenney
My pliers drawer in my main (SAE) box has a lot of Utica pliers in it, at least a dozen. I can make closeups if any are particularly interesting. Nevermind the HF specials at upper left.
My “clean” bench tool drawer has a range of small Utica pliers, and these please me every time I hold one in my hands.
I have some newer Wilde pliers that aren’t bad, too.
Rick “my go to brand for pliers going back 45 years” Denney
I picked this Utica 90-6 6-inch adjustable out of a box earlier today.
a Utica-made PLOMB 6-inch adjustable was mentioned in the garage sale thread earlier today on which the adjuster wheel appeared to have been worn off on one side.
After wiping most of the grease off of this one, I noticed there is a "flat spot" on this adjuster wheel as well.
I don't know anything about either Utica or Plomb - the production code on this unit looks like "TL-111"
Utica 90-6 6-inch adjustable wrench
Utica Drop Forge & Tool Corp., 2410 Whitesboro St., Utica, NY
Provincial
Near Salem, OR
four.cycle, your photos show that the special wheel is a feature, not a modification. I'll bet there is advertising out there that promotes this feature for rapid adjustments. Rotate the wheel to the relieved area and slide the jaw to the desired location. Then turn the wheel to engage the jaw to hold it in position.
Now to pin down the date range of this feature. It had to have been before Plomb bought out Danielson, and probably before Plomb started buying adjustables from Danielson.
That is not a Utica number. It is a US Army Signal Corps number. They used phonetic-mnemonic prefixes. BG = Bag. CH = Chest. TL = Tool.
Plomb never bought adjustables (or pliers, end wrenches, etc) from J.P. Danielson. AA is just dead wrong about this. I've explained this before on the Plomb thread, but you must have missed it.
The source of AA's error is AA misattributing the date of Plomb's acquisition of J.P. Danielson to the date of the publication in which they found the acquisition announcement (January 1947). But Plomb acquired J.P. Danielson in October 1946. With their erroneous January 1947 acquisition date in mind, and a couple very early examples of Plomb tools made in the J.P. Danielson factory with December 1946 date codes in hand, they mistakenly concluded that Plomb must have been buying tools from J.P. Danielson before they bought them. Despite the oddity of buying the same tools from a second supplier after having sourced them from Utica for many years, and no J.P. Danielson tools ever appearing in catalogs (only Utica), AA never thought to confirm their pronouncement by re-confirming the acquisition date. No Plomb tools made in the J.P. Danielson factory have date codes that precede their October 1946 acquisition.
Ricky Joe
Roanoke, Va.
I believe these are Utica. No brand or other markings, but I am aware that Utica made box joint pliers. I have a friend who is an avid collector of box joint pliers, and is also a blacksmith. I have given him many examples over the years. He asserts that they can only be made by hand due to the method of making the joint. I know surgical tools also have box joints. The clamping force has no side pressure. These are far too perfectly made to have been made by hand. The teeth in the jaws align perfectly.
I could be wrong.
Provincial said:
"...the special wheel is a feature, not a modification..."
Oh, it's clearly a factory job - those cuts are too clean to have been done by hand.
Private Lugnutz said:
"...not a Utica number. It is a US Army Signal Corps number..."
Indicating that this unit was manufactured by Utica for a military contract, I would assume, correct? Any idea as to date range?
I made another attempt at getting a clear shot of it - the low angle of the sun last night didn't lend itself well to showing detail.
Under the "TL-111" there appears to be something of a forging mark - possibly an "S" or a "5" :headscrat:
Utica 90-6 6-inch adjustable wrench (TL-111)
Provincial
Near Salem, OR
It is interesting that the 90 series wrenches seem to have conventional adjusting wheels. Apparently, this was a modification (by Utica) that was not just an experiment. Since Old Radar's Plomb has a similar wheel, Utica had standardized it to some extent. I tried a search for "Utica quick adjust" that came up with nothing.
I see that Utica used the base number followed by a dash and the length of the wrench through 90-, 91-, and 92- series (and maybe more), so they did not appear to identify wrenches with this feature with a distinctive part number.
Fred Knox
Nor Cal
Recently picked up this Utica three triangle logo 90-15 15” adjustable wrench. I haven’t cleaned it up yet, but it still works perfectly.
LesserSon
PA USA
Picked up a pair of pliers I didn’t have before.
No1-7…
Well, that’s how they’re marked. I do not see them in the half-dozen catalog pdfs I have at hand. They appear to be a straight variant of battery pliers. Three-diamond logo (not chain links), depressed diamond grips with straight-across termination. Early, but not particularly early 1920s-30s, maybe. Not sure why I don’t see them in catalogs.
Alloy Artifacts shows a pair with no more information than the obvious.
wrenchr
I'm a sucker for quality American made tools and Bonney and Utica are no exception. Here are a few items.
Chris Christiansen
Kansas City, Kansas
Picked up this pair of nippers today. But there is no model number on it, only three diamond, UTC "pat apd for". Any idea what the primary purpose might have been and date? piano wire? The jaws are very nice.
LesserSon
PA USA
Looks like No3 Compound End Cutting Nipper, available 4-1/2, 5-1/2,7-1/2,9”. p13 of the 1939 catalog.
LesserSon
PA USA
Because they are Utica, I think the applied for patent is likely the 4th improvement on Hall’s original. But you might have to open them up to see. DATAMP has a discussion on the four patents, lawsuit / 1889 Supreme Court decision, and a suggestive mention of UTICA production. I do wonder how an 1890 patent could still be forged-in “appled for” if Utica took over manufacturing them in 1895.
btrnuthatch
Don't know if this 483 is vintage or not. I haven't been able to find any info in my brief search. I also haven't found anything about the markings -- "CUSTOM BUILT" and "MADE TO ORDER" -- on the reverse side of the model number
Below ORDER is a faintly stamped number 4 on the right handle.
Apologies if I missed a discussion that explains it.
LesserSon
PA USA
Yes, vintage: mid-1940s to late 1950s.
Since they are custom, don’t expect to find them in catalogs.
PowderKeg
Little Rock, AR
Recently completed a triple play of Utica ratchets - torque wrenches are pretty common, but standard ratchets appear not so. Have had the 1/2" for years - took a little to determine it's a Utica with the grinder marks obliterating most of the brand - and the hunt will continue for a rep in better shape. The 3/8" & 1/4" were both fished out of the bay, one shortly after the other, about the only ones I've seen for a very long while.
LesserSon
PA USA
Those are interesting. I see them in the 1967 Bonney catalog. Short run with the triwing selector, then a decades-spanning run with the straight bar selector. Maybe Kelsey-Hayes was unsure what brand to put on them at first. Advertised in Motor Age 1966; August as Herbrand, November as Bonney. The handles look like they may descend from Herbrand pearheads. “Loc-Rite” is being used as a line of tools, because the Loc-Rite patent pertains to the lobed engagement of sockets and wrench broaches on hex heads.
PowderKeg
Little Rock, AR
They're def the 1968 Rozmus patent (3372612 filed for in 1966) assigned to Kelsey-Hayes. Have several different brands - Bonney, Bon-e-con, Dayton, Herbrand, John Deere, Chrysler (awards ratchets). Have triple plays of Bonney's with both selectors, Daytons and Herbrands I have so far are tri-wing as well, with the others using the bar.
AntiqueBen
I have this pair of 8" Utica Lineman pliers stamped US. I'm curious if the government used this tool? I think these are older due to the V-Shape at the top of the handle pattern? Looks like something else is stamped next to the logo but I can't make it out. I think it says "appl'd for." Anyone know anything about these or what era?
