dcg9381
Building a home. I've got a guest shower that we may put a glass door on.
The glass guys came by and said that I have to hinge the shower door on the "wrong" side as there is an outlet about 12" off the shower corner.
Glass guy said that he' can't install a door in a manner that would allow someone to walk out and touch an outlet. (I get it). I have to put the hinge on the side with the outlet, as it would prevent someone from touching it easily.
Thing is, this outlet is low voltage. It's got a "garage door opener" type single button, wired with CAT6. It's actual function is to close a low voltage switch that triggers a re-circulation pump. My guess is that low voltage doesn't count, but I'm not sure.
Anyone point me in the right direction on NEC that covers this?
