Shower plumbing
SHELCO
Medford Mass
I have a commercial building that has a old bathroom that we want to add a shower in. My question is we removed the toilet that will not be reused. Can I install a standup shower over the toilet flange? I checked out the piece together units in home depot over weekend. quite simple to install with base etc.
I am sure its not up to code.. neither is the rag jammed in the flange now Is there a adapter that will allow me to accomplish this?
rlitman
Long Island
Can you get under the flange, or is this on a slab? A toilet flange does not include a trap, as it is expected for the toilet to provide one. A shower expects a trap under it.
If you have the height, I suppose you could build a platform under the shower for a trap to fit into the toilet drain, but the better way would be to remove the flange and connect the trap directly to the drain.
SHELCO
Medford Mass
It is on a slab. I could easily make a pee trap if I could find a adapter that would bolt on to toilet flange.
I guess the shower would be 8-9 inches off the ground, which is no big deal
Thanks!
rlitman
Long Island
Thanks!
Bolt to the flange, no. But if the pipe is PVC under the flange (and not a lead bend), you could use a rubber Fernco push-in bushing.
dcg9381
Austin, TX
I'm no plumber, but personally, I'd do it. How I'd do it is "elevate" the shower floor enough to be able to access the plumbing and install a P-trap (if necessary). I'd make sure I had an "access panel" if I ever needed to get under there. Up to code? I have no idea. Handicap accessible? Probably not.
You can do some really cool things with moen diverter valves to make quite the fancy shower (mulit-head) for not that much money..
nadogail
Coronado, CA
I would not be giving up a toilet, I would put the shower pan on a pedestal with an accsss and drain the shower into the toilet vent stack.
My advice is guaranteed to be worth exactly what you are paying me for it.
mike93lx
Richmond, VA
Stepping up and down 9" to get in or out of a wet shower feels like a slip and fall waiting to happen. If you do it, set it up carefully.
No desire to cut the slab and modify the plumbing?
Bert_
NW Iowa
Aren't those made to fit in a hub?
no704
I suppose ya could get another toilet flange and bolt that to the current one. Going to need some steps.
TRWham
East Cobb County, Georgia
You are going to need some horizontal distance from the shower trap to the closet flange to allow sufficient trap arm length to avoid creating an S trap. A toilet is by definition an S trap.
We do about 20 showers a week and would trench the slab to install this.
Bert_
NW Iowa
You can add as much horizontal distance as you want, unless you install a vent it's still an s trap.
CraigStu
Blacksburg, Va
Our previous house had had the basement finished before we bought it. I have no idea what was under the raised shower but I wasn't happy w/ the step up from a safety standpoint. So I got an outdoor mat something like this.
I cut it down to match the step width and set it on the step w/ this stuff.
I put the left over part of the mat on the floor w/ more of the no slip stuff.
