FredWanaker
Have standard 2 car garage with a side door to the back yard. The door is steel and was replaced about 2004 or so. The original prior door had a window and typical thin panel like many 50's - 70's side doors were. That rot was all around the floating panel. I probably got the steel replacement at Home Depot. The sill came loose right away so it is bolted now to the concrete below it, and there is some rot in the jamb on one side at the bottom. A new door is like $260 plus the time or expense to install it and paint it, transfer locks etc.. I haven't gone to look at it yet to be sure the dimensions are the same, but it looks like it will work. A custom door built by a local door company to fit the opening would be about $700. Another option is I can cut the existing door jamb at the bottom with a miter cut, and put a new piece of jamb in, some caulk and paint it. Might not be a perfect match but it would only cost about $50. What would you do? Am in my early 70's and I don't know how long I will stay here. Been here 32 years already and tired of how crazy this place is now. Have no idea what a home inspector might say on a home inspection if he caught a jamb repair vs an intact door and jamb.
