Siding for a houseboat
denis4x4
Durango CO
Just finished doing Trex over a waterproof membrane on the upper and lower decks of my houseboat. Now I want to do some siding to breakup the slab look. First off, what ever I use has to be light weight and easy to install. I personally like the look of corrugated steel as I have it on my house. However, I'm not sure it will work in a marina environment. Here's a photo of my 900 sf tiny houseboat!
jwhcars
Central PA
Spray it with rubber paint, paint it with marine grade paint or wrap it with stainless steel.
MScott
Eastern Ontario
You pretty much described vinyl siding.
I think you're correct about metal being a bad choice for your environment.
Tom
Unless it's salt water, aluminum siding would also work. Might even be able to find some that looks like your corrugated steel.
