Sika Crack Fix, not hardening?
jeff000
So I bought some Sika Crack fix, to fix a small crack in my walkway, probably 3' long and 1/4" wide. I jammed some rubber moulding into the crack so I wouldn't lose it all and then filled the crack up.
The first third and last third of the crack are solid, rock hard. but the center is like a glue stick in consistency.
What the heck happened? And how do I fix this now? It's been 9 days, the hard parts were hard the next morning. Temps were above 15C. Although now they are hardly above freezing, I'm worried if I don't fix it next week when it's supposed to warm back up I won't get another chance before winter.
Any help would be great.
NUTTSGT
Northern Central Ohio
Honestly, the best advice you'll probably get on this is to shoot an email off to Sika and include a date code of the tube if you still have it.
J
jeff000
I unfortunately do not have the tube, I used it up, and tossed it, garbage came the next day. I didn't really expect this could be an issue. I had used 3 tubes in my garage to fix spalling a month or two ago and it worked excellent.
I sent them an email on Wednesday, with no reply. And calling the only information I was able to get was what they have available on the pdf and being asked stupid questions like if I cut the tube open and mixed it with something before application or if I tried to thin it out (it's damn near thinner than water already).
Garage Flooring
Grand Junction, CO
Use there Facebook page and post pics.
audioworks04
Olathe KS
Sika normally provides a very good product and will stand behind it. I am sure that if you get ahold of them they can provide you with a remedy, sadly I bet it will require removing the "bad" filler.
