Sill plate anchor bolts
Wiebster
Rapid City, Sd
I’m just getting started on my shop build and already got questions. I’ve always had j bolts set in concrete when still wet. I let my concrete contractor talk me into leaving them out for easier finishing. Now I’m ready to anchor down the sill and not 100% sure on the process. I’m familiar with code for depths and spacing but not s few in anchors. I ordered 5/8” x 8” Simpson screw in anchors, but do I need large washers also or is their head large enough. Any advice on their use would be appreciated.
Wolley
Maine
Simpson usually has clear instructions on their website. I bet those are a lot more expensive than j bolts.
Hooked
League City, Texas
Have you considered all thread rod and epoxy to set them? May save any 'oops' with hole size using screw-in anchors.
Personally, I would use a large washer with the screw-in anchors.
OccupantRJ
Eastern North Carolina
I have an anchor drill and plenty of anchors and threaded rod around, so I drilled for cinch anchors and ran them through the base block, sole plate and out through the top plate every four feet and clamped that baby down. There is 1/2” OSB sheathing on the outside and 1/2” plywood on the inside. I live in hurricane country.
jack stand
Lakes Region Maine
Those Simpson "bolts" are tapcons on steroids. Their website should answer your question about approval for your sill plates.
No matter your method at this point, your drilling a hole. I'd just cordless impact the Simpson into the hole vs wedge, epoxy or any other after pouring solution.
LopezBart
Lopez Island, WA
For my steel-framed building, I drilled 9/16" holes and used Simpson epoxy to glue in 1/2" rods. There are procedures for cleaning the holes, etc. that must be followed. I did have to slightly oval out one of the holes when the SDS drill drifted on a hard junk of aggregate. I've also added a couple of wedge anchors which worked fine as well. Follow the directions on the epoxy or anchors. Those screw-in Simpson anchors need washers.
JasonMcElroy
San Jose by way of Philly & NYC
I just had a pad done for a small outdoor space I'm building.
Some of the poured-in j-bolts ended up interfering with my framing layout so I cut them off flush and put in wedge bolts.
Simple enough.
What are some of the reasons one would prefer j-bolts other than price?
Thanks,
Jason
LopezBart
Lopez Island, WA
Then if there's rebar in the slab. I always seem to find it when drilling! 😅
BEFORE they pour concrete, double check hole location w/ rebar placement. If you need to, either move (or have them move) the rebar slightly to avoid this problem. There are also drills made that will apparently deal with both concrete and rebar successfully; I've not needed to do so. "Prior planning prevents piss poor performance" is a real thing when it comes to concrete :).
Innovate1
Simple enough.
Thanks,
Jason
Less work than others. Just stick them into the wet concrete. No drilling or other fuss.
LopezBart
Lopez Island, WA
This works well for stick-built places, since exact j-bolt location for sill plates isn't critical and you can mark out the spots on the forms ahead of time. Hold downs for shear do require more accurate positioning. For steel buildings, the anchors bolts aren't always located on the perimeter, and locations tolerances are tighter in order to match the holes in the framing. Precisely locating anchor bolts is tricky; I did end up using a 1/2" diameter carbide burr in a die grinder to oblong a couple of holes (out of 48) for a better fit.
Innovate1
I added a couple anchors for shear on the wall with the OHDs. I doubt the AHJ would have said anything but it seems like a good idea with the amount of door area in that wall. As I recall I used epoxy that was in a caulking tube type package.
