bob_the_builder
- Joined
- Apr 25, 2010
- Messages
- 404
After many hours of planning I finally had my two post lift installed this weekend. I have been very busy getting the garage read for the lift therefore I have not updated my garage build for some time but I am planing on doing that in the next week or two.
I hope this is in the correct spot but I wanted to get a second opinion on the best way to lift my 2003 Silverado Extended Cab Truck. I spoke with a mechanic and he recommended this way but I found the truck to have some bounce to it so I wanted to get a second opinion.
By the way, the lift is a Rotary SPOA10 installed in the wide configuration.
I followed the Rotary recommendation and parked the truck just past the spotting dish as noted in the manual.
This post the posts just behind the mirrors and in front of the door handle.
I put the front arm as far forward as I could before the frame curves up.
I put the rear arm as far back as I could before the frame curves up.
With the truck parked in this position I am about 6" too short from reaching the rear leaf spring hanger. This leaves with with the arms under the cab only and the 6.6" box is hanging past the rear pick-up point.
I just wanted to double check with everyone if this is correct. I could always put a stand under the rear axle to take the bounce out of the truck.
Any comments would be greatly appreciated.
Bob
Bob
