Simple Aluminum Toolbox Project
BreeStephany
Oregon
I wanted to practice my riveting abilities so I decided to fabricate up a quick, simple aluminum toolbox out of .040" T3 Alclad aviation-grade aluminum plate and AN470 2117-T3 universal head rivets. I used a 3X pneumatic rivet gun and bucking bar to drive all of the rivets and a 1/8" radius box/pan brake to bend up all of the pieces and then started riveting them together.
View media item 69135
View media item 69133
View media item 69136
View media item 69132
View media item 69134
View media item 69131I used the NACA method to flush rivet the doubler onto the lid of the toolbox and countersunk the rivets at 82 degrees to half of the depth of the .070 doubler plate, riveted them and then attempted to mill off the shop heads, however, I was unable to get any of the microshavers into the tight space, so, since its only a toolbox, I used a dremel with a cutting wheel to get them close, then used a right angle die grinder with a gray scotchbrite wheel to try to clean up the edges as best as possible.
View media item 69130After doing all of my bend calcs, I spent a few minutes and drew up each panel in autocad. I was using my micrometer to dimension all of the panels as I fabricated them, so I kept all of my bend calcs and the drawings to the precision of the micrometer, which is +/-0.0005".
View media item 69128Side panels
View media item 69129Lid strike plate
View media item 69127Lid panel. I made two 20 degree bends and a 70 degree bend to fabricate the lid.
jimgood
Marshall, VA
That's really nice! I recently "restored" an old Craftsman toolbox with copper rivets. It came out great.
tvtaurus
Indiana
Nice to see the drawing that made the box. How long did you spend calculating bend allowances and getting measurements vs. Actually bending the metal in the brake.
BreeStephany
Oregon
I spent probably about 45 minutes ~ hour doing all of the calcs and drawing it up in Autocad.
tvtaurus
Indiana
I've done some work with sketch-up. But have never worked with Autocad. When I took my metallic structures course we had to do it all by hand with pen and paper. Cad just makes for a much cleaner and easy to read drawing.
BreeStephany
Oregon
I've taken architectural and manufacturing drafting courses where we have had to do both CAD and hand drafting. I like both and I think that hand drafting should still be taught, as it helps for field work / modifications and also helps people have a better understanding of drafting, but with that said, CAD based drafting is MUCH cleaner and MUCH quicker. I would have spent well over an hour ~ hour and a half doing the drawings for that toolbox if I had to draw them out.
And the nice thing is when I have to make a change, it takes a few seconds vs. completely starting the sketch over.
gearhead1
NC
Great craftsmanship, which is becoming a lost art these days. Super work!
muddywater
East TN
Looks sweet.! I built a range hood a while back for a customer with cooper and brass rivets. Was my first rivet job and it came out nice.
I'm from the old school of drawing by hand (civil eng). I have done finish carpentry though almost exclusively since out of school. I think I get a lot of jobs by listening to the customer and drawing perspectives while we work through a design. A disappearing skill.
Hammer1963
Kentucky
Absolutely impressive work. The end cab was great and this is equally impressive as well. It's nice to see good craftsmanship
BreeStephany
Oregon
How did the aluminum get cut? Did you send it out to a laser cutter?
All of the straight cuts were done on a shear. I used a right angle bench notcher to make the angled cuts and to do the majority of trimming on the doublers and then used a square punch die in a sheet metal punch to trim and clean up the edges on the doublers.
BreeStephany
Oregon
She probably used a common sheet metal shear. The trick is getting the piece lined up just right to get the cut where you want it, and not at a angle.
THIS!
With a shear, a notcher, a punch and a beverly shear its amazing what you can make, and how precise you can be with sheetmetal with a little bit of practice.
I also have a whole new level of LOVE for my greenlee hydro punch. If I do much sheetmetal once I am in the field, I see it coming to great use.
BreeStephany
Oregon
Thanks for sharing the drawing, maybe we can also have a try, great work, and nice profile photos
Absolutely! Would love to see pictures if you do!
With that said, it is important to keep in mind that these dimensions only apply to .040 Alclad being bent on a 1/8" radius brake.
If you have a different radius brake or are using different thickness metal, your numbers will be a little bit different, but its still pretty easy to figure out.
If you are not familiar, with how to calculate setbacks and bend allowances for sheetmetal, here is a quick tutorial of sorts I guess.
To calculate the layout, you start with the mold dimensions, which are the exterior dimension of the toolbox, or really any project you wish to layout.
I then calculate my setback and bend allowances, which are as follows.
For 90 degree bends
Setback is calculated using the formula
SB=T+R
SB = K(T+R) where K is your K-factor, T is the thickness of your material and R is the radius of your bend, which is also the radius of your brake. Because the K-Factor for a 90 degree bend is 1, we can simply the formula to be SB=T+R,
Bend allowance is calculated using the formula
BA =(2π (R + 1/2 T)) /4
BA =(2π (R + 1/2 T)) /4 where T is the thickness of your material and R is the radius of your bend, which is also the radius of your brake.
Once you know the setbacks and bend allowances, you can calculate your leg distances for layout.
On a piece of sheetmetal that you are making a single 90 degree bend, you would calculate the distance of the legs by taking the first leg of the bend and subtracting a setback, then measure your bend allowance distance and then add the second leg distance minus another setback.
For bends other than 90 degrees
To calculate bends which are other than 90 degrees, you need to know the K-Factor. You can either calculate the K-Factor or you can use a K-Factor Chart
Once you know the K-Factor, you can calculate your setbacks and bend allowances. It is important to remember that you need to calculate setback and bend allowance for EVERY angle you bend and to make sure to use the correct values for the correct angles when doing your layout.
To calculate setback for bends other than 90 degrees
SB=K(T+R)
To calculate bend allowance for bends other than 90 degrees
BA = (0.01743R + 0.0078T)N
Bend allowance = (0.01743R + 0.0078T)N where R is the radius of the bend, T is the thickness of the metal and N is the number of degrees in the bend which you wish to make.
On a piece of sheetmetal that you are making a single bend, you would calculate the distance of the legs by taking the first leg of the bend and subtracting a setback, then measure your bend allowance distance and then add the second leg distance minus another setback.
Once you have all of these dimension, you can make your layout, much like this
For reference, the toolbox's mold lines are 18" x 7" with a 4" front and a 5" back. Using a 1/8" radius brake, my bend allowance for .040" alclad is 0.2280" and setback is 0.165"
Now the easiest thing to do is take a micrometer and a sharpie and begin laying out everything on a piece of sheetmetal. Make all of your cuts and relief holes first and then you are ready to start bending everything up.
To layout your bends as they will be positioned in the brake, measure the distance of the radius of the bend, in my case, 1/8" or 0.125" from the intersection of the leg line / bend allowance line which is sitting under the brake. This measurement is your sight line, which you will align to the front of the brake edge. You should just see your sight line and it should be tight to the front of the radius. Lock in your brake and make your bend.
Its important to remember that if you want precision for your final product, you need to keep every aspect of your precision within the tolerances you set for the project. I kept all of my measurements on layout to +/- 0.0005", however, I know that there was error from using a ultra fine tip sharpie for layout, in that even though they do have a pretty precise tip, its line thickness can vary dependent upon pressure, ink flow, etc.
To prevent cumulative error, remember that its best to set a reference edge to make all of your measurements off of and make all of your measurements from that edge when possible. This will prevent gain in length because you are not having to estimate exactly where the center of your sharpie line is from which to base your next measurement.
For rivet layout, its important to keep a good edge distance and good equal spacing, as you don't want your rivets to be too close to the edge, but you also want them to appear symmetrical and visually appealing.
I used 2D spacing for my rivets, which means 2 times the diameter of the shank of the rivet, which in my case was a #4 or 1/8" rivet. I found my edge spacing, marked out all of my end rivets, then measured the distance between end rivets in a given rivet line and divided it by the total number of desired rivets in the line, minus 1 rivet. I would then use this number to determine the spacing to be used between rivets.
To determine proper rivet diameter, take the thickness of the thickest sheet to be riveted (not the total thickness, but single thickest sheet), multiply it by 3 and then multiply that by 32.
In my case, having two sheets of .040" material, I took 0.040 x 2 = 0.12 x 32 = 3.84/32" or 4/32 = 1/8" or a #4 rivet.
To determine proper rivet length, take 1.5 x the diameter of the rivet being used and add that to the total thickness of all materials being riveted together, then multiply that by 16.
In my case, on joints where I had two 0.040" thick pieces of material and was using a 1/8" rivet, I took (1.5 x 0.125) = 0.1875+(0.040+0.040) = 0.2675 x 16 = 4.28 = #4 length rivet.
Thus, the majority of rivets I used were 4-4 rivets, but again, this is all dependent upon the material you use and only applies when using solid aluminum rivets.
Just my two cents.
SuperCat
Sacramento, CA
Wow, superb workmanship. Anyone would be proud to walk into any shop with a toolbox like that. Have you thought about riveting on a custom nameplate with your own fab shop name?
On a related note, Aero-1946 makes a very cool riveted tool tote, they have posted a thread on their shop projects. Machine_Punk has a great project thread also.
You rock the technical, the aesthetic, and the practical all at the same time!
