simple sanded plywood top for my toolbox
Hotrod Addiction
Ellsworth AFB, South Dakota
So I finally got sick of the dirty old rubber mat that was the top of tool box. So Sunday I took the kid and went to Menards. Picked up a 2'x8' piece of 3/4 sanded plywood and some gloss polyurethane and a couple other things I needed. Cut the plywood to length and it turned out the box I thought was 24" deep was actually 25" deep.IMG_0875.jpgIMG_0876.jpgIMG_0877.jpg So I had to cut one inch strips to glue along the back.IMG_0879.jpgIMG_0880.jpgIMG_0881.jpg
NUTTSGT
Northern Central Ohio
It looks good and you'll soon forget about the strips on the back. You did learn a valuable lesson, measure twice, cut once. It sounds monotonous but it is a simple thing that avoids alot of trouble later on.
H
Hotrod Addiction
Then I block sanded it with 320 till I was happy with the finish.IMG_0882.jpg Then began the coats of poly. Coat, wait 3-4 hours, sand, and recoat. Repeat.
IMG_0883.jpg I drilled and countersunk holes in the top for allen head cap screws so I could attach it to the top for added sturdiness.
:rocker: This is my latest and greatest acquisition. Now I can finally paint in my garage. 60 gal. compressor from Runnings farm and fleet. Still gotta finish plumbing it up like I want. Need to get a regulator and desicant. IMG_0878.jpg
H
Hotrod Addiction
Well they sold sheets of sanded plywood in 4'x8' or 2'x8' so I bought the 2'x8'
I should have bought the 4'x8' but I was trying to be fiscal. I may still go back later on and get the 4'x8' sheet to do it over again.
gahrajmahal
Cincinnati, Ohio
Don't sweat the short board. Cut a new piece 6" wide turn it perpendicular and make a backstop. Save your $$ for some new air tools.
Spam16v
B-low NY
I ripped down a work bench and did the same thing. Had a 6" piece of scrap... hrmmm backsplash!
turbowoodworker
Apex NC
An old woodworking trick to cover up small errors like that would be to rout a bevel on the front edge and make the front look like you planned it that way. And it will ease the edge making it less prone to splinters, damage etc. A hardwood strip on the front could be used alternatively to cover the plywood edge.
NUTTSGT
Nah, I wouldn't do that, not reason to redo it. . .. as others have posted.
Yep, I'd add something to make a back stop.
Good advice, I've done it a few times. Put a nice trim piece on it to avoid the dreaded plywood splinters. It's not a bad idea and does cover your **** for the small errors. :bounce:
