Simple Welding Project
Provincial
Near Salem, OR
I made a simple tool yesterday. It is an adapter to mount a Honda GX620 engine on my engine stand. I wanted to hold the engine away from the adjustable arms of the stand and also be able to use 5/16 bolts to mount the engine to the stand.
It consists of two pieces of 2x2x1/4 angle iron 10" long each with two 1/2" holes drilled to match the spacing of the stands adjustable arms when placed horizontal and parallel. I mounted these pieces vertical and spaced the inboard leg just under 12" apart, parallel to each other and with the upper ends even.
I then cut two pieces of 1/4x2 flat bar 12" long and drilled two 3/8" holes to match the spacing of the width of the mounting bolts of the engine. These holes were centered on the bar and 3/4" from one edge.
I welded the first flat bar even with the top of the angle iron. I then spaced the lower bar to put the holes the correct distance from the first holes, matching the bolt pattern of the engine.
When I laid out the holes in the flat bar, I scribed the locations very large, so the scribe lines extended far past the holes after they were drilled. This allowed me to use a square and rule to verify that the holes were spaced properly and square.
It was a simple project, but made working on the engine very easy. I made an adapter some time ago to work on a Ford 4R100 transmisson. It is shown in the second photo.
Oregon rock crusher
West of Salem
Looks good Provincial. Being able to make or modify the tools you need to get the job done is always rewarding. Far better than having to run off to town for every little need. Ed.
