Simple Wireless Switch
PCustoms
VT
I have re-wired the whole house in the past few years. Since it was an unplanned, evolving project I missed a few "nice ta haves", such as a switch for undercabinet lights.
I can get a switch in, but it won't make sense with the kitchen layout. With all the sprayfoam and blow in its a PITA to run across the kitchen to the bank of switches.
I need a simple wireless switch. Doesn't have to (prefer not to) be wifi compatible. Would like it to look like a normal wall switch, and be great if I can add it to the current 3-gang box.
jlv03
SE IA
I believe this switch would need the wiring all in place already, these switches have a separate hand held remote that controls the switch which is hardwired in the circuit
There is a plug in dimmer module, if the undercabinet lights just plug in (and are dimmer capable).
pbon
Seems like some wireless switches actually need to tie into the neutral wire — you don’t have to run a switch wire. Then there is the question of power. Some use batteries. Some need to tie into the power wire. And some make their own power from flicking the switch. I have one light for which I would like a true wireless switch, meaning battery or switch powered but no wiring.
pioneer1
Kansas City, MO
Do you already have under cabinet lights? Or are you adding them? Where are you thinking to get power?
P
PCustoms
VT
Lights are not in, planning them now as I get ready to install counter and backsplash.
Ideally can pick up power of the counter outlets, and run a new box hidden in one of the cabinets. I want to add the remote switch across the kitchen, inside the box for all the other lights, that is on its own circuit. There is a neutral in the box.
pioneer1
Kansas City, MO
What style switches are you trying to match? Rocker or Toggle. Got a pic?
pioneer1
Kansas City, MO
I could not find a Toggle wireless switch, I'm sure they might be out there. Leviton has what you need , BUT they are Rocker style. Might have to change to those for your other switches.
I would call Leviton & Lutron and see if they have 1
02chuck
Collegeville, Ca
I use the Z-wave product for outside lights. we are up to 6 at this time. Wife loves being able to turn the lights on before we get home.
Chuck
