desertforge
I posted this a couple days ago in the vise repair thread and got no replies so I'm posting here again with pics. As you'll see in the last picture I've moved ahead with a start of a repair kind of aggressively...
Below is a pasted quote of my original post.
Anyone know how the steel slide in a Simplex vise is attached to the active jaw?... I might have discovered the weak point of these vises and why the steel slide isn't an advantage:
It looks as if the active jaw casting has a "key" cast in (with the bore for the screw) that fits a dovetail in the interior of the slide. It may be simply press fit. The action of tightening the vise levers the active jaw away from the passive, the force of rotation tending to bend the slide down and resisted only by the cast key in that dovetail. The key on mine appears to be broken about half way from the end and the slide bent at that point. I'm trying to figure if there's any reasonable fix or if it's junk...
In the first couple of pictures you can see the deflection in the slide and the point where the casting is broken. What you don't see is that under a load it keeps moving- that is the active jaw keeps rotating away from the work. I might have located a pin about 3/16" in diameter that holds the slide in place, but if so, the active jaw is either rotating around it, or it's broken.
My first attempt toward getting it back was to cut a couple of spacers which I placed below the screw between the active and passive jaws and tightened against them as much as I could without bending the handle. Did some but not enough. With heat I got the deflection down from about 3/16" to about a 32nd over a foot which I think is acceptable.
I've decided against trying to remove the slide so now that it is close to straight unstressed, I plan to drill and tap several pins to keep the jaw casting from moving against the slide.
Tell me why that's a terrible idea.
