are you planning on connecting any other buildings to this service?
Yes you could just connect #2 al to the 200a breaker as a tap.
But lets backup. What kind of loads will you have in the shop? How many people?
You have a 200a service and if theres any chance on more power use in the future you may want to just go with a large wire and be done with it since you have 200a service. all depends on loads though
1. The house will also be tapped off this 200 amp breaker.
2. One person- plans are mig/stick welding, planning on 5 hp compressor, lights are all LED. Possible blast cabinet and or plasma cutter in future- Just a hobby.
House: 1830 sq ft with 3 ton A/C heat pump/gas backup- Standard tank Electric hot water.
Wire run to shop is approx 120 ft. Approx 80' to house .
POCO has said if I ever need a larger transformer, they will provide at their cost.
Thanks for the input.
