Single project/one time used tools
mike93lx
Richmond, VA
I'm cleaning up the garage a bit and came across the megger I bought a few years ago when I was installing a heated tile floor. Used it once, for about 10 seconds, tucked it away and it hasn't seen the light of day since. Credit to the cheap Chinese batteries that haven't leaked in all that time.
boom_bap
Idaho
Astro on car wheel bearing press and hub rotor and drum pullers. Dealer wanted and arm and a leg to do a bearing so I just did it myself.
Probably tons of other examples. If its cheaper to get the tool and do it myself I normally go that route if its something I'm comfy with or willing to learn. I don't mind having the extra tools lying around yet.
bwringer
Indianapolis
Harbor Freight paint sprayer.
Although technically I've used it three times, to paint my house, garage door, and deck.
The thing worked great, and having actually followed the cleaning instructions and used the proper storage fluid, I can be pretty confident it'll work again if I ever need it.
Speaking of paint, I stopped bothering with cleaning paint rollers long, long ago. It's well worth spending a few bucks on new ones with every job. I'll put a sealed bag or a cover over a wet roller for continued use the next day, but washing all the paint out of a quality roller takes absolute ages, hundreds of gallons of water, and besides you never actually get all the paint out. So that's more a disposable tool than a one-time use.
As the mechanical tools, I got pissed off and bought a hydraulic press to do a wheel bearing after Numpty McNumbNuts at a local machine shop ignored my explicit directions and markings and pressed one in backwards, ruining an $80 bearing (and then wouldn't even refund the $40 for the service). I thought it would be one of those one-time tools, but it's actually been extraordinarily useful.
Another tactic is the buy/sell -- I once bought an engine lift, used it for a few weeks for a project, then sold it on CrackList within minutes for $40 less than I had paid. MUCH cheaper than renting. I wanted to keep it for assorted hoisting duties, but it took up way too much room, even folded up.
Debcrow
New Mexico
Inner tie rod tool for ford focus rack and pinion steering Original tie rods do not have the two flats on them to use the "loan-a-tool" from the parts store to remove them. Had to buy a U-Bolt serrated clamp on tool to remove it. Probably will never use it again, $24 tool plus tax on the shelf.... just because you never know......
NUTTSGT
Northern Central Ohio
HF ball joint press and 5 lb slide hammer.
Used them once, on the same job, one to try and get a hub off an Explorer and the other when the whole assembly went back on.
gtae07
Fayetteville, GA
Nailgun and palm nailer for building my shop
Compactor for building the shop, sold on CL
Engine stand for storing airplane engine - still gotta sell that one
Oscillating multitool for cutting airplane canopy
Various hole saws
Laser level for aligning airplane parts (I'll probably use that again though)
Ring compressor, cylinder nut adapters, micrometer set, and special sockets to build airplane engine
PassnThru
Bowling Green KY
Lisle spark plug remover. Bought before I changed the spark plugs in my 07 4.6L Explorer at around 75K miles for the first time. Those are the plugs that like to break. Not only have I not used it since - I didn't even use it then. All eight plugs came out in one piece.
full
RMERR
Northern CA
I bought a scrollsaw about 8 years ago to make a 2 inch cut in a small piece where I needed the thinest kerf I could get. It's under a work bench haven't used since. Have a Fein oscillating tool I bought for trimming a fiberglass sculpture, worked great, also not used since. Neither take up much space though, so no plans to get rid of. We all know the line..."hey you never know".
cgrutt
Oh. where to begin lol... I've built a pretty nice collection of tools over the past several decades under the philosophy I'd rather spend the money on a nice tool than pay somebody else to do the job for me. Most recently I suppose was a $400 HF transmission jack and $200 transmission adapter for engine stand when I rebuilt my F150 transmission. I purchased both fully hoping I'd never need to use them again but have them in case I need to or help a friend, etc. I have no problem buying good tools for the project at hand regardless of how many times I expect to use them in the future. More often than not I find a use for them sometime down the road...
Fedwrench
Valley of the sun
full
The Ford spark plug removal tool is one of those tools that's it's better to have on hand and not need it than to need it, and not have it :lol: Like a fire extinguisher in many respects. We have great luck with decarbing the engine then popping those plugs out with a 3/8 cordless impact.
On a side note, I'll get my *** kicked doing a certain job, discover that there's a tool to make that job easier, get the tool, and never get that job again :wtf: :bounce:
richfinn
Leeds, Yorkshire, England
Vehicle specific special tools are the greatest Insurance policy ever invented, you struggle a couple of times and end up buying the tool for "next time".
It never comes, I have special toolbox full of that stuff.
I keep these "investments" close by for five years or so "just in case" before relegating to the special "waste of money toolbox" that is locked away in a garage on an industrial estate that I go to twice a year looking for weird tools to get other idiots out of the sh*t 🤐
cgrutt
Fine, you win :)
Oh didn't mean it like that just has me thinking about "tools you use once".
To be fair there's more to the story...
I bought a Spraytech EPX2155 to paint my townhouse before my son was born, in 2005. About 5 years ago had planned to paint a friend's house with it but couldn't get it to prime... needed a repacking kit which I had to order but was stuck in middle of project so picked up a Titan440, roughly equivalent but a bit nicer to finish my friend's house. I bought a Graco 1Qt sprayer for another project because the other machines use too much paint. I have used the handheld on a couple of projects now that I think about it. Recently was working on a cabin and was planning to hand paint the roof sheathing and rafters (underside) but decided it would be easier to spray it. I was about an hour from home so picked up a smallish Graco at Home Depot. I hope to use the Graco on future projects it's more manageable when you only need just a gallon or two.
I bought the Fuji early 2000s when I built the kitchen cabinets for a vacation house I used to own. Had plans to use that for future woodworking projects (still do) but so far haven't built anything that needed it.
vwpieces
Hills, PA
I am sure there is more but one tool that comes to mind, as the boiler just kicked on...
Is the $130 digital meter for measuring water column. Bought to adjust the gas valve on my DIY NG hydronic boiler install.
Used it once and have Zero regrets buying the tool because I saved over $10K by DIY than the lowest quote I was given. Learned a lot and if and when it quits I am confident I could get it running again.
vavet
Ashland, VA
Low speed high torque ridgid drill. I bought it to mix grout and thin set for a bathroom project. I’ve installed two additional bathroom floors since then, but just never wanted to mess with doing tile again.
mike93lx
Richmond, VA
All kinds of them... The Triton plug puller comes to mind, I actually used it on 2 different Fords, truly saved my ***... this was years ago, I thought about getting rid of it, then common sense kicked in, and hell, I'd rather have it and not need it then need it and not have it. The alternative is way worse....
I think the alternative is not buying another Triton, but I guess you never know when you will trip and fall into one, right?
Lassen Forge
Exactly! Best part was neither were mine... I wouldn't pay to own one, but if one were given to me, well... I'd probably wonder what I did to piss that person off. 🤣
Actually I hear once you swap plugs once the problem goes away. I like my solution better - don't own one in the first place, and you won't worry about it happening a second time, because you won't worry about it happening the first time.
Junkdrawer Dog
LV NV
A 1/2" corded drill. When we moved, I thought I had sent my 3/8" drill with the movers and kept my 1/2" with me . Wrong! I did it the other way around. So one of my fix up jobs (new deck rails) required a 1/2". I bought the cheapest, skankiest corded drill I could find along with a bit, used it one day and dropped it off at Habitat on the way out of town. Kept the bit though, it was expensive.
Kuma601
Cali
Wagner power roller. Skil corded hammer drill. Others that are in the depths of the garage that are hidden from sight.
dscheidt
I've got all sorts of tools that have been used for a single job. For the most part, that's fine. The tool makes it easier or possible, and most of them aren't that expensive compared to the labor saved (or the cost of paying soimeone to do the work.). What are more bothersome to me are the tools I've never used, many bought after I finished a job where they would have been useful.
isb cornbinder
I bought some Dynabrade air tools 6 years ago. Dynabrade are very pricey. I have not been out in the shop very much and these tools are languishing in a cabinet.
metaldad
nw indiana
engine hoist. used once. took up too much room
aluminuminum 2 1/2 tier complete scaffold. took up waaaay too much room
wet tile saw. used twice. space waster.
delta scroll i came across
every tool, hand or electric, that i have in multiples.
snakeeyes
Those and engine hoists are a PIA. I had a group of friends that we shared an engine hoist between. Anyone was welcome to it, but you had to store it until the next guy needed it.
Have two complete engine hoists and another that is just the tubing. Can confirm they take up space.
However my father showed me the way to remove shrubs and small trees was with the engine hoist lol. Works suprisingly well just have to put down some boards for the rollers to spread out the load.
mike93lx
Richmond, VA
My method of shrub removal is to call Ezequiel. He will usually take care of it the same day he mows my lawn.
A lot easier on the back
whitesco
Pittsburgh, PA (ish)
Tools I’ve only used one time? I can beat that I've bought tools I’ve never used. Seemed like the puchase was a good idea at the time.
Glad it’s not just me…
Most recent one-time use tool was the exhaust pipe expanding tool from HF after I bashed my face open to the tune of 7 stitches trying to open one just a hair to slip fit a replacement cat in. Unless you count the stitches themselves as one time use :LOL:
MushCreek
Upstate South Carolina
I bought various tools for building our house that I won't use again, mostly nail guns. I have a siding nailer (that crapped out), a flooring nailer, and a positive placement strap nailer. I have a drywall sander that I'm going to use to finish the garage 'some day'. I bought a corded circular saw, but just use the cordless, so I should sell it. I haven't used the paint sprayer, either. I find I prefer to use a regular roller set-up instead. I bought a used block plane for building a boat, but it might get used again...some day. Time for a yard sale!
AffableCurmudgeon
Triad Area NC
A number of tools mentioned here are available in AutoZone as loners. I just get things like ball joint pullers etc. from them when I need them.
dlwilson
West Palm Beach, FL
A Harbor Freight ratcheting pipe threader. I had smelled gas for a long time, then it got worse, so I went under the house and found a dime-sized hole rusted in a galvanized gas pipe. One plumber wanted to replace every gas pipe in the house, and the other wouldn't even consider the job. I found a left/right threaded coupling on Amazon, cut out the bad section of pipe, threaded the cut ends, and installed the coupling. And I learned something.
