Hey guys,
I can't seem to find the right answer, I'm looking to do an overhaul on my compressor and I am looking for a new pump.
I will need a pump that can help me finish my paint job using a HVLP gun and then sandblast, but I will also need to use an air DA sander which is an air hog.
Most pressures I will be using will be between 23-50PSI for the HVLP and 90-110PSi for sand blasting. My HVLP requires 13CFM@23PSI, and the Sandblasting cabinet calls for 10CFM@100PSI.
What I got from searching so far is 2 stage is better for higher CFM at higher PSI over 150, but single stage will produce higher CFM at lower PSI. Since I will not be using anything near that pressure, and my cut off is set to 145psi anyways, am I better off with a single stage?
Or will the 2 stage will be better because of lower noise, heat, etc.?
BTW the pump I am looking at is rated for 17CFM@175PSI, can I expect at least 15CFM@90PSI with this of pump? Also this is a 60 gallon tank I am using.
Thank you for the help.
