Hot goes on the left and **** goes downhill!Yup. 1/4" per foot is all a plumber needs to know.
Hot goes on the left and **** goes downhill!![]()
I never had enough length to ever worry about it.
so a 45ft pipe should drop about a foot??
the reason i asked this is i have a drain pipe leaking. i have a home warranty and the plumber they sent out said the copper pipe is leaking because the pipe isnt at the correct angle and the water is sitting in the pipe causing it to corrode and leak. he estimated the pipe at 45 feet. i measured and it drops almost 15 inches from from start to finish.
Also payday is Friday.
T
What year is the house/plumbing? I've got a rental built in 1978 and I've had to replace several drain lines, especially the elbows at the outlets of the toilets. The waste just sits there and corrodes thep pipes. No idea what type of copper it was. But, the failure is pretty common. My plumber called it before opening up the ceiling.
