hey guys,
i figure this would be the relevant thread to ask a question about garage sink setups. One of the walls in my garage is exactly where my laundry room is (on the other side of the wall from the garage) and so it's a perfect location for me to tap into the hot/cold water source and drain pipe. I have a mobile tool cabinet/workbench (FYI, the 72" Whalen from Costco) in front of that wall and I was actually thinking of installing a small 15" x 15" x 8" (deep) sink into the cabinet (into where the cabinet door of the workbench is, if you're familiar with it).
My question is, what products are available to allow for a flexible hose/pipe for the hot/cold water source *and* drain pipe? I'd like to be able to shut off the water source, disconnect and be able to move the mobile cabinet/workbench around. And then be able to move it back and reconnect as needed. This isn't something I'll be doing every day, but probably 2-3 times a year as needed.
What I'm envisioning in my mind is to tap into the hot/cold water source and drain from the laundry room and have those sticking out the wall on the garage side with shut-off valves. Similarly, run the plumbing from the sink/faucet out the back of the workbench/mobile cabinet. And then have some sort of flexible hose/pipe connecting them together during normal use.
Would appreciate any suggestions on what I can use to make that happen.
