Sink plumbing question
Reit38
Iowa
So the pipe from the left comes from the CLOTHESwasher. We get a sewer smell up the sink when the washer runs. Do I need to add a trap below the sink also.
EDIT: This is for a clothes washer
Sent from my SM-G930R4 using Tapatalk
txvwnut
Bedford, Texas
Re: Sinknolumbing question
I’d say relocate the washer drain connection to after the trap. I’m no expert but most of the washer drain setups I’ve don’t have a trap in them.
joey1320
NE Ohio
*I'm not a plumber*
I have never seen a hard piped dishwasher drain. I have ever only seen the smaller, flexible hoses, about an inch and a half or so. Those hoses are run as high as possible within the cabinet and looped down onto the drain to create an air gap. Maybe replacing the PVC pipe and adding a flexible one will fix your issue.
Another thing you can try to do is add an Air Admittance Valve (AAV) to the drain line to facilitate with the pressures within the pipes.
510ebl
Southern New Jersey
Unless I misunderstand, this is from a clothes washing machine next to a lavatory sink. Nothing kitchen in the image.
And it isn’t vented properly, IMO.
Shiftless
East Bay SFO
Mine is plumbed like this. The air gap is on the sink with provision to shoot the dishwasher drain water into the sink if the hose connection gets clogged up.
R
Reit38
Iowa
Yes this is from a clothes washer
Previously where the clothes washer line ran into the pvc there was a y. One side had drain line and the other end was open.
Kaizen
New England
Agree no vent plus the forced rush of the washer is blowing any water out of the sink trap. Is there a trap where the washer hose is before this? Not sure if those under island air inlet things will work due to amount and pressure from washer
The Cobbler
I'm assuming the washer is coming in from the left side of your picture?
I am guessing the overflow in your lav sink needs a good clean . when the washer discharges it puts a bit of pressure in the drain and causes a "backflow" of the old soap scum smell etc that has built up
paredown
Pomona, NY
For the final word, I'd post your pic on Terry Love's forum, but I would think that the sink trap should be for the sink only, and that washer should also have a trap of it's own, and hit lower down. Plus I see no evidence of a vent for either.
My guess is the rush of water from the washer is hitting hard enough that it creates suction--then ***** the water from the trap on the sink--hence the stink...
You could fix the vent for the sink by adding a dry vent/ "mechanical air admittance device" like is used with island sinks as someone has mentioned... which would be easier than trying to vent to outside from what I can see. The washer though still might create more suction that one of those could handle, and not eliminate the odor.
Washers generally discharge into a standpipe with a wet trap at the bottom--and from there the discharge goes into the stack/main waste. You have large amounts of water discharging, and the stand pipe allows the rush of water to drain quickly--and also "vent" by drawing in air vertically as the rush hits--so maybe both sink and washer would need venting in your case.
You might get away with sizing down the p-trap on the sink, and squeezing in a separate trap for it--with a mechanical vent in place--but I think the washer discharge would still want to suction that water out of it when the washer discharges
It would be worth it to run it past the guys on Terry's forum for the best fix...
dutchgray
Dorset. England.
In the UK that would be fine provided the washer connection was sealed otherwise it would need its own trap and the whole thing would need to drain into a vented stack or externally with an air gap into the drain.
rslaback
Westcentral Wisconsin
You can't see it in these images but I would bet 5 bucks that where the pipe exits the cabinet on the right side and goes into the wall, the vent stack goes up inside the wall. I don't think venting is your problem. The design of the plumbing seems ok to me. Have you checked the drain system in the washing machine? Most of them now have a filter in them that gets absolutely disgusting and the waste water gets that same nasty smell as it goes through the system. With that trap where it is, there shouldn't be any way that you get actual sewer gas.
Norcal
Nothing looks right in that photo and whoever did it used water pipe fittings to make it worse, a washer needs a 2” drain also.
crf731
Put the drain plug in the sink before doing laundry.
CombatNinja
There is no way in hell that is to code anywhere in America.
But whatever. I just clicked on this thread to see what a "sinkolumbing" was. Thought it was something from IKEA.
yeldogt
Did a plumber do that ?
My washers have 2" drains -- unless that was built for the washer ... what's in the wall? If it's a sink setup -- it will drop down to 1.5"
Also -- have never seen a common trap on a washer.
Typically the washer will have 2" pipe to the main and they have a dedicated trap.
R
Reit38
Iowa
This is how it's set up. I thought adding a p trap below the sink would help but not sure if the pressure from washer would blow the water in the trap back out586306c92381e76c773689bacde623a6.jpg339548ba665422e2276989522d5af0ef.jpg
Eric S.
Vancouver Island, BC
Can you verify if the washing machine is causing the P- trap to siphon out? Could just be stinky washing machine water you are smelling. If it is not siphoning out then I would just split the sink and washing machine lines and have a trap for each....FYI I am not a plumber.
Although guess is it was the washers water smelling it would still come up the standpipe for it. lol Maybe just need to clean the machine.
Bert_
NW Iowa
I'm confused. Is the latest post photo yours or is it the one in the first post? They are quite different and the latest one doesn't even have a trap.
The first picture looks like it's inside the vanity, it's what's between the second two pictures...
Bert_
NW Iowa
The whole thing really doesn't look bad except the pressure 90*s.
A shared trap is pretty uncommon I would say but I don't really know why it would be a problem since the sink and washer are so close.
nmk_61802
Central IL
Since your sink does not have it's own trap, it is effectively acting as the vent for the washing machine (why it smells when you wash). It has no choice since it is the first vent in the string.
I would move your current trap toward the washing machine, behind the sink tie in, and allow it to be the primary path to drain, keeping it at the same elevation. I would then put a deep trap on the sink line and wye it into the washer drain.
This allows each fixture to have it's own trap, as shared traps are not generally allowed either.
You may still have an issue with the shared stack/ vent and the sink trap being sucked dry due to the overall distance from the washing machine, however the above is a good start.
