Sistering joists with cracked headers
dlundblad
Indiana
The fiance and I bought a 100 year old farmhouse back in October.. 5 acres, huge garage, pole barn and pond. Many plans and to do's. A few areas in the floor are sagging and my plan is to go in and sister the floor joists, but I am not sure how to fasten them at the ends.
The first and easiest troubled area is a 16' span. 2x8 joists. 16 on center. 10 or so feet wide. The 8x8 poplar headers have cracks from I'm assuming drying out over time. Would joist hangers work in this situation? The existing joists have the traditional 2x6 chunks cut off at the end and are fitted into the headers.
Thanks guys. :beer:
manwithtools
Lebanon, TN
Pictures please. Then you might get some more pertinent answers.
It's hard to understand "The existing joists have the traditional 2x6 chunks cut off at the end and are fitted into the headers." What are traditional 2x6 chunks? What you describe as headers sound more like beams, headers go above door and window openings typically.
D
dlundblad
Indiana
Thanks. Sorry my terminology isn't the best.
Here's a photo. From what I've seen, the 2x6-ish notches at the end are typical with older homes.
manwithtools
Lebanon, TN
That is called is a mortise for a floor joist into a beam. The reason it's done that way is the floor joists are of varying height (because they are rough sawn), the pocket cut into the beam is sized to match the "notch" at the end of the joist, leaving the top flush with the beam regardless of the joist height.
Several methods of attachment are possible, what is the root problem you are trying to solve? Soft or bouncing floors? Creaking or noisy floors?
D
dlundblad
Indiana
Just visible sag. No creaking or noise. They are quite stout feeling overall.
*The PO installed tile in the bathroom.. more of a complex area. The mortar is cracking and non existent in some areas.
JRC3
Southwestern OH
To remove the sag I think thethe joist would need to be evenly jacked slowly over time to straighten, and then sister. But if you need to jack them why not just do that and just leave it instead of sistering. Basicall you're adding another beam and cutting the span of the joist in half. Looks like a crawlspace so who cares if it's obstructed. I've seen this done many times on older houses, even in open basements.
How many joist are there needing this?
D
dlundblad
Indiana
10 in the first area.
jd_1138
NE Ohio
Yeah I'd do that.
D
dlundblad
Indiana
manwithtools
Lebanon, TN
Another beam mid span, that's what I would suggest as well. One thing to consider, it took 100 years for those joists to sag and it will take time to get them to un-sag. In other words; if you use the jacking method to level them out, you need to do it a bit at a time, otherwise they will fracture.
JRC3
Southwestern OH
Steel will be expensec
I'd run 2x6 3 or 4 wide as a beam, 2x8 would be even better. Then crank the jacks over time and just leave them in place when you get things leveled out. Or at least something along those lines.
acer66
Western North Carolina
You don't need to fasten anything. The joists will simply rest on the new beam, supported at their mid-span.
Highly unlikely that they are all the same size, you would have to cut them all out level to do that or just snug the supporting beam up to the lowest one and shim the rest.
D
dlundblad
Indiana
I would think the orignal 2x8 joists would be undersized compared to the new.
manwithtools
Lebanon, TN
I'd wager they are true 2 x 8 +/- a 1/2". They are rough sawn. Not today's kiln dried, planed to size framing lumber. They will be larger than lumber available today and all different sizes. Likely harder than a rock too.
manwithtools
Lebanon, TN
That old framing lumber is some crazy stuff. Don't know what they used to use but I don't think it was yellow pine.
In the mid-west where the OP is, it was poplar, oak, butternut, chestnut and other hardwoods. Not a lot of softwoods in that area. Indigenous trees were the primary source of framing lumber. After drying, some of it is now harder than woodpecker lips :tard:
acer66
what I meant is that if they are like ones at my place which was build in 1901 the original 2x8’s will be all different in height so if you just jack up your new center support beam flush against against all of them from underneath you will end up wit a very uneven floor.
I hope that is a bit clearer, I sometimes have a hard time to convey my thoughts.
acer66
True, a friend of mine has his house almost completely framed out of oak.
They often just used what was growing close back in the day.
wrenchguy
NW Indiana
Are you removing the floor sheeting in this 10x16 area? Your prolly dealing with balloon framing, you jack up 1 joist the ends of it will prolly come up too. I wouldn't jack a 100 year old joist, i'd sister them on plane to be determined using a base line of the highest (toward living space) at the ends of all the joist. Platform or western framing the outside walls bear over the the floor sheeting, rim joist and floor joist, not the case with balloon framing.
